  3. Compile and test voxl-mapper code and visualize trajectory in voxl-mapper using docker containers only ?
1 Posts 1 Posters 609 Views
  • A Offline
    ahmed-mustahid
    wrote on last edited by ahmed-mustahid
    I have been trying to input a sequence of goal points programmatically by changing and then compiling the voxl-mapper code, instead of using voxl-portal and then clicking by mouse.
    Currently, in order to test how my modified code is behaving, I need to use the environment inside the seeker to run voxl-mapper by ssh ing into it.
    Is it possible to use only docker container to test the changed codes of voxl-mapper and then visualize it (the goal points and the trajectories) using voxl portal?
