  3. Building voxl-mapper from scratch. voxl-mapper: error while loading shared libraries: libceres.so.1: cannot open shared object file: No such file or directory
2 Posts 2 Posters 766 Views
  • A Offline
    ahmed-mustahid
    wrote on last edited by ahmed-mustahid
    I have been trying to install voxl mapper from scratch into voxl by building it from voxl-mapper gitlab master branch :
    1. Install dependencies
    voxl-cross:~/voxl-mapper(master)$ ./install_build_deps.sh apq8096 dev
    using apq8096 dev repo
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//Packages.gz.
    Updated source 'dev'.
    installing:
    libmodal-json
    libvoxl-cutils
    voxl-ceres-solver
    voxl-nlopt
    voxl-mpa-tools
    libmodal-pipe
    voxl-voxblox
    voxl-vision-px4
    voxl-mavlink
    voxl-eigen3
    Installing libmodal-json (0.4.3) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//libmodal-json_0.4.3_202209281920.ipk.
    Configuring libmodal-json.
    Installing libvoxl-cutils (0.1.1) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//libvoxl-cutils_0.1.1_202210072353.ipk.
    Configuring libvoxl-cutils.
    Installing voxl-ceres-solver (1.14.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-ceres-solver_1.14.0-9_202208221901.ipk.
    Configuring voxl-ceres-solver.
    Installing voxl-nlopt (2.5.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-nlopt_2.5.0-4_202210072358.ipk.
    Configuring voxl-nlopt.
    Done installing nlopt
    Installing voxl-mpa-tools (0.7.5) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-mpa-tools_0.7.5_202210072124.ipk.
    Configuring voxl-mpa-tools.
    Installing libmodal-pipe (2.6.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//libmodal-pipe_2.6.0_202210052046.ipk.
    Configuring libmodal-pipe.
    Installing voxl-voxblox (1.1.3) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-voxblox_1.1.3_202209261707.ipk.
    Configuring voxl-voxblox.
    Done installing voxblox
    Installing voxl-vision-px4 (1.4.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-vision-px4_1.4.0_202210072317.ipk.
    Configuring voxl-vision-px4.
    //usr/local/var/lib/opkg/info/voxl-vision-px4.postinst: 10: //usr/local/var/lib/opkg/info/voxl-vision-px4.postinst: systemctl: not found
    Collected errors:
     * pkg_run_script: package "voxl-vision-px4" postinst script returned status 127.
     * opkg_configure: voxl-vision-px4.postinst returned 127.
    Installing voxl-mavlink (0.1.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-mavlink_0.1.0_202207052152.ipk.
    Configuring voxl-mavlink.
    Collected errors:
    Installing voxl-eigen3 (3.4.0) on root.
    Downloading http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64//voxl-eigen3_3.4.0_202208222129.ipk.
    Configuring voxl-eigen3.
    Collected errors:
    Done installing dependencies
    which install dependencies with multiple errors.
    1. Build
    voxl-cross:~/voxl-mapper(master)$ ./build.sh apq8096
    -- The C compiler identification is GNU 4.9.3
    -- The CXX compiler identification is GNU 4.9.3
    -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9 - skipped
    -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9 - skipped
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/root/voxl-mapper/build64
    [  2%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/motion_defines.cpp.o
    [  5%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/polynomial.cpp.o
    [  8%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/rpoly_ak1.cpp.o
    [ 13%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/timing.cpp.o
    [ 13%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/segment.cpp.o
    [ 16%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/vertex.cpp.o
    [ 19%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory_sampling.cpp.o
    [ 22%] Building CXX object server/mav_trajectory_generation/CMakeFiles/mav_trajectory_generation.dir/src/trajectory.cpp.o
    [ 25%] Linking CXX shared library libmav_trajectory_generation.so
    [ 25%] Built target mav_trajectory_generation
    [ 27%] Building CXX object server/mav_planning_common/CMakeFiles/mav_planning_common.dir/src/yaw_policy.cpp.o
    [ 30%] Building CXX object server/mav_planning_common/CMakeFiles/mav_planning_common.dir/src/visibility_resampling.cpp.o
    [ 33%] Building CXX object server/mav_planning_common/CMakeFiles/mav_planning_common.dir/src/color_utils.cpp.o
    [ 36%] Linking CXX shared library libmav_planning_common.so
    [ 36%] Built target mav_planning_common
    [ 38%] Building CXX object server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/src/loco_smoother.cpp.o
    [ 41%] Building CXX object server/voxblox_planning_common/CMakeFiles/voxblox_planning_common.dir/src/path_shortening.cpp.o
    [ 50%] Building CXX object server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/src/polynomial_smoother.cpp.o
    [ 50%] Building CXX object server/voxblox_planning_common/CMakeFiles/voxblox_planning_common.dir/src/gain_evaluator.cpp.o
    [ 52%] Building CXX object server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/src/path_smoother_base.cpp.o
    [ 52%] Building CXX object server/mav_path_smoothing/CMakeFiles/mav_path_smoothing.dir/src/velocity_ramp_smoother.cpp.o
    [ 55%] Linking CXX shared library libvoxblox_planning_common.so
    [ 55%] Built target voxblox_planning_common
    [ 58%] Linking CXX shared library libmav_path_smoothing.so
    [ 58%] Built target mav_path_smoothing
    [ 61%] Building CXX object server/mav_local_planner/CMakeFiles/mav_local_planner.dir/src/conversions.cpp.o
    [ 63%] Linking CXX shared library libmav_local_planner.so
    [ 63%] Built target mav_local_planner
    [ 66%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/local_planners/global_smoother.cc.o
    [ 69%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/global_planners/rrt_connect.cc.o
    [ 72%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/local_planners/local_a_star.cc.o
    [ 77%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/main.cc.o
    [ 77%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/config_file.cc.o
    [ 80%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/obs_pc_filter.cc.o
    [ 83%] Building C object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/rc_transform.c.o
    [ 86%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/planner_utils.cc.o
    [ 88%] Building C object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/rc_transform_ringbuf.c.o
    [ 94%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/timing_utils.cc.o
    [ 94%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_mapper.cc.o
    [ 97%] Building CXX object server/voxl-mapper/CMakeFiles/voxl-mapper.dir/voxl_planner.cc.o
    [100%] Linking CXX executable voxl-mapper
    [100%] Built target voxl-mapper
    1. Inside voxl:
      a. Installed voxl related packages
    voxl:~$ opkg list-installed | grep voxl
    libvoxl-cutils - 0.1.1
    voxl-camera-calibration - 0.1.5
    voxl-ceres-solver - 1.14.0-7
    voxl-cpu-monitor - 0.2.6
    voxl-docker-support - 1.2.4
    voxl-gphoto2-server - 0.0.10
    voxl-jpeg-turbo - 2.1.3-4
    voxl-libgphoto2 - 0.0.4
    voxl-libuvc - 1.0.6
    voxl-logger - 0.1.2
    voxl-mapper - 0.1.5
    voxl-mavlink - 0.1.0
    voxl-mavlink-server - 0.1.1
    voxl-modem - 0.16.0
    voxl-mongoose - 7.6.0
    voxl-mpa-to-ros - 0.3.2
    voxl-mpa-tools - 0.7.2
    voxl-nlopt - 2.5.0-4
    voxl-opencv - 4.5.5-1
    voxl-portal - 0.2.8
    voxl-qvio-server - 0.4.6
    voxl-streamer - 0.3.1
    voxl-suite - 0.7.0
    voxl-tag-detector - 0.0.4
    voxl-tflite-server - 0.2.3
    voxl-utils - 1.1.4
    voxl-uvc-server - 0.1.1
    voxl-vision-px4 - 1.0.5
    voxl-voxblox - 1.0.4
    voxl-vpn - 0.0.6
    b.
    voxl:~$ opkg list-installed | grep libmo
    libmodal-cv - 0.1.0
    libmodal-exposure - 0.0.7
    libmodal-json - 0.4.2
    libmodal-pipe - 2.4.0
    libmount1 - 2.26.2-r0.3
    Finally inside voxl, when I execute voxl-mapper, I get the error
    voxl:~$ voxl-mapper -d
    Is it happening due to the errors that occured during dependency installation (Step 1) ? How can I resolve this error?
      Hey @ahmed-mustahid,
      This is a version mismatch error. The voxl-ceres-solver (v1.14.0-7) package on your voxl is two versions behind what you built against (v1.14.0-9) since you pulled in the latest from dev. When building our packages from source, make sure you use the same repo that your voxl is sourcing packages from via opkg otherwise issues like this will arise.
