  3. error compiling voxl-vision-px4 from source
8 Posts 2 Posters 2.1k Views 2 Watching
  • Aldo Castro FreireA Offline
    Aldo Castro Freire
    it says cannot find -lsensor_imu and not sure how to fix it !!
    • tomT Offline
      See this thread to see if the solution works for you.
        Aldo Castro Freire
        I still have this errors :
        CMakeFiles/voxl-vision-px4.dir/fixed_frame_pipe.c.o:fixed_frame_pipe.c:function fixed_frame_pipe_init: error: undefined reference to 'pipe_sink_set_data_cb'
        CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o:px4_shell.c:function px4_shell_init: error: undefined reference to 'pipe_sink_set_data_cb'
        • tomT Offline
          Are you building from master? Which version of voxl-emulator are you using?
            Aldo Castro Freire
            I am building from tag v0.6.8 because when I build from master I got this error while pushing to the companion computer:
            voxl-vision-px4 is crashing on the voxl right now. I am not sure how to fix it !!
            • tomT Offline
              I would rebuild using the master branch and do the following:
              You can use the opkg server in order to install the dependencies.
              In /etc/opkg/opkg.conf uncomment the line #src/gz dev http://voxl-packages.modalai.com/dev.
              Then, call opkg update
              • Install libmodal_json with opkg install libmodal_json
              • Install voxl-mpa-tools with opkg install voxl-mpa-tools
              • Back on your host pc, run ./install-on-voxl.sh
                Aldo Castro Freire
                Thank you, that one work and I can changed the port for qgc
                • Aldo Castro FreireA Aldo Castro Freire
                  @Aldo-Castro-Freire Great to hear!
