  3. Streaming video over LTE
15 Posts 3 Posters 2.4k Views 3 Watching
  • Aldo Castro FreireA Offline
    Aldo Castro Freire
    Is there any tutorial on how to do that? Or is there any recommendation on how to get started. Wifi is not good enough for long distances.
    Is there a way to modify voxl-rtsp or do I have to forward the stream somewhere?
      If the VOXL is connected to a VPN via LTE, then you should use the VOXL's endpoint IP as the RTSP video server for a video client (QGC, VLC, etc) connected to the same VPN. voxl-rtsp would be one way to stream the video
        Aldo Castro Freire
        Hi Chad, how do I change the endpoint for the voxl-rtsp I think right now is only sending to the local area network 192.168.8.1. I am not sure of where to change that ?
          Aldo Castro Freire
          Nevermind As long as the setup is fine, the rtsp will send it using the LTE.
          PS: you need to connect your local machine to the VPN also.
          Now my question is: is this the order I must follow To allow streaming over LTE I have to connect to the VPN and then start streaming ? is there a way to set up a script to activate like a minute after LTE connection is established to connect to the VPN and then start streaming. Otherwise, if I start streaming before I connect to the VPN it won't work. ? if so is there documentation on how to write a service?
            It's a standard Linux service, take a look at the voxl-modem service for an example
            • Aldo Castro FreireA Aldo Castro Freire
              @Aldo-Castro-Freire The services that we use to start LTE and VPN on bootup are voxl-modem, as Chad mentioned, voxl-time-sync which is a simple script which loops until the date / time is correct, meaning a connection to the internet has been established, and voxl-vpn, which will then start the OpenVPN service after voxl-time-sync has finished.
                Aldo Castro Freire
                Does voxl-vpn works with the new version of openvpn because I update mine to the 2.4.6
                Also is this a service? Or does voxl-vpn sets up the service as voxl-configure-modem does? I haven't seen anu documentation for voxl-vpn.
                • tomT Offline
                  voxl-vpn is just a wrapper for calling OpenVPN, it's not required, you can use OpenVPN on its own. We haven't tested with 2.4.6 but I don't see why it wouldn't work. All you should need to do is modify the key path in the service file.
                    Aldo Castro Freire
                    Okay. So basically use voxl-modem.service as a sample and exec voxl-vpn instead voxl-modem-start.sh .And start this service after voxl-modem.service
                    • tomT Offline
                      All the voxl-modem.service does is call voxl-modem-start.sh.
                      So what I would recommend and what works for us is:
                      Start voxl-modem service -> Gets LTE connection up and running
                      Start voxl-time-sync sevice -> Verifies connection to internet
                      Start vpn-start service -> Connects to VPN
                      If you have all three of these enabled they should start at the correct times to get you going.
                        @tom OpenVPN will fail if the date / time is not set correctly, that is why we use voxl-time-sync to have OpenVPN wait until the date / time is correct. This sometimes takes a couple seconds after the modem has connected to the network
                          Aldo Castro Freire
                          wrote on last edited by Aldo Castro Freire
                          #12
                          Is there a command called vpn-start? I cannot find it in my voxl. Or should I make a script that opens the vpn?
                          • tomT Offline
                            wrote on last edited by tom
                            #13
                            vpn-start is a service file that you can find at /etc/systemd/system/vpn-start.service. You can modify the KEY_FILE parameter with the path to your OpenVPN key file and enable the service using systemctl enable vpn-start.
                              Aldo Castro Freire
                              Hi is there an easy way to open and read a file in Voxl such as nano and vim ?? it is a pain to have to transfer files between machines
                              • tomT Offline
                                Yes you can use vi on VOXL
