  2. VOXL Compute & Autopilot
  3. Flight Core
  4. Flight core integrate with a Wifi module?
Scheduled Pinned Locked Moved Flight Core
3 Posts 3 Posters 1.4k Views
  • D Offline
    D Offline
    DarkKnightCH
    Hi, is it possible that I buy a Wifi module and connect it to the Telem2 port in flight core so that the QGC in my laptop can communicate with PX4 through this Wifi? and in this case, my laptop will work as the companion computer instead of the VOXL.
    • Steve TurnerS Offline
      Steve Turner
      Not out of the box -- you would need software running on the WiFi module to turn the serial/UART into packets to send over wifi in much the same way the VOXL does through voxl-vision-px4 and the mavlink server.
      Something like https://www.seeedstudio.com/grove-uart-wifi-v2-esp8285.html?gclid=CjwKCAjwrNmWBhA4EiwAHbjEQAItVDD1g2yzKCTEn6CQgcpUFMOcq_KO3P3pyJJhrzkPx51yIZ2hCRoCrg4QAvD_BwE might work, but I haven't tried. Or a similar ESP-based board with a UART and Wifi included. Ublox makes the Nina line of chips as well that you could build something to do this for you.
      • m4v3rM Offline
        m4v3rM Offline
        m4v3r
        Hey the answer is yes.
        I use DroneBridge for ESP32 but I believe there's a ton of other similar mavlink apps for ESPs.
        cheers
        Ch.B.
