    voxl-docker-mavsdk-python build problems
    Software Development
    • Sebastian LaPointeS
      Sebastian LaPointe
      Hi, I'm using voxl-docker-mavsdk-python as a base to make a docker container for the Voxl. Currently I have renamed it and added some files to the docker containers home folder. The problem is when trying to build the image on the Voxl I get a bunch of depreciation warnings when compiling MAVSDK and finally exit with out building the docker with this error
      Makefile:129: recipe for target 'all' failed
      make: *** [all] Error 2
      The command '/bin/sh -c cmake --build build/default --target install -- -j 4' returned a non-zero code: 2
      some more information is included in the two screen shots sense I can't upload a text file with the logs
      • modaltbM
        modaltb ModalAI Team
        Let me take a look at this tomorrow, maybe something changed and we need to update.
        • modaltbM
          Hi @Sebastian-LaPointe , we've replicated the error and will get a solution in place and give you an update.
          • Joseph MartinsonJ
            Joseph Martinson
            @Sebastian-LaPointe, I have updated the GitLab repository with changes that should fix this issue. Please let us know if the issue persists
