    Voxl not connecting to QGC
    VOXL
    1231
    • PawelJP
      PawelJ
      I have gone through the quickstart process and can ssh into my voxl m500 drone, but it does not automatically connect to QCG. I installed qcg using the instructions here for Linux. I am on Ubuntu 20.04. My desktop has two ethernet ports and a wifi card. I tried following the steps in this forum post, but it does not appear to be helping.
      I tried running with the default voxl-vision-px4 and I tried setting up a new one with voxl-configure-vision-px4. I've tried with my ethernet connection both enabled and disabled. In the forum post I linked above, the solution was to input the ethernet ip into the voxl-vision-px4 config, but this does not make sense to me as the connection is happening over wifi. However, I tried with both the ethernet and the wifi ip's of my desktop. In all cases I reset the system with systemctl restart voxl-vision-px4 and have also tried power cycling my desktop.
      Desktop Wifi IP
      VOXL with WIFI IP
      Desktop ethernet IP
      VOXL with ethernet IP
      I have also checked the QCG debugging steps here, and do not have any of the connection messages in the QCG console log, however I am able to connect from my computer to the drone over ssh and wifi.
      Please let me know if there is any other information that can be useful for debugging.
      Cheers,
      Pawel
        tom admin
        Hi @PawelJ
        Can you try power cycling your drone and then providing the output of systemctl status -l voxl-vision-px4
        • PawelJP
          PawelJ
          @tom said in Voxl not connecting to QGC:
          Sorry for the delay, I had to shift work for a few weeks. I was also able to get the drone to connect to my windows laptop, however I am still facing the same problem when connecting to my ubuntu 20 desktop. I just went through the connection process again and added my desktops ip given by the voxl-m500, and power cycled as you asked.
          ~ # systemctl status -l voxl-vision-px4
          ā— voxl-vision-px4.service - voxl-vision-px4
             Loaded: loaded (/usr/bin/voxl-vision-px4; enabled; vendor preset: enabled)
             Active: active (running) since Thu 1970-01-01 00:00:08 UTC; 23s ago
           Main PID: 2869 (voxl-vision-px4)
             CGroup: /system.slice/voxl-vision-px4.service
                     └─2869 /usr/bin/voxl-vision-px4
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [-1761534639]ns, Apps ClockType[CLOCK_MONOTONIC]
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [7.963379] SNAV INFO: IMU sensor finished initializing.
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [7.963522] SNAV INFO: IMU sensor settings retrieved.
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [7.963537] SNAV INFO: Creating IMU thread.
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [7.963627] SNAV INFO: Creating VISLAM processing thread.
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [7.963682] SNAV INFO: Creating VISLAM publishing thread.
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [7.963682] SNAV INFO: ImuManager thread has tid = 3052, nice = -15
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [7.963762] SNAV INFO: VISLAM processing thread has tid = 3053, nice = -5
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: Init complete, entering main loop
          Jan 01 00:00:09 apq8096 voxl-vision-px4[2869]: [7.968099] SNAV INFO: VISLAM publishing thread has tid = 3054, nice = -5
          I am still not automatically connecting to QGC, please let me know if there is any other information I can send you.
          Cheers
            tom admin
            @PawelJ It looks as though you are using the correct IP in your config file and voxl-vision-px4 is running correctly. Is it possible that you have some custom firewall setup on your host PC that is blocking traffic on that port?
            tomT 1 Reply Last reply Reply Quote 1
              tom admin @tom
              @tom I've seen this happen on Windows with QGC, I believe it can happen on Ubuntu devices as well.
              • PawelJP
                PawelJ
                Ah now I feel silly, it turns out my firewall was blocking the connection. Thanks for getting back to me so quickly. Can you confirm if it's port 14550 that I need to allow for the connection?
                  tom admin
                  @PawelJ Yep, it should be either 14550 or 14551.
                  • PawelJP
                    PawelJ
                    Thanks for sorting that out šŸ™‚ Is there a way I can mark the question as resolved? I don't see the option anywhere.
                      tom admin @PawelJ
                      @PawelJ There isn't, we like to keep all posts visible in case other users run into the same issue.
                      • PawelJP
                        PawelJ
                        @tom that sounds great, this forum has already been incredibly useful in my initial setup šŸ‘ Just to clarify, I was asking if there was a way to mark the question as having an answer, vs being an ongoing issue. This is helpful when searching through the forum as well.
                          tom admin @PawelJ
                          @PawelJ There isn't an exact way to do that, if you want you could edit your initial question and add a [SOLVED] section at the top and describe the solution.
