  2. VOXL Compute & Autopilot
  3. VOXL 2 IO
  4. TBS Crossfire on VOXL 2 IO
Scheduled Pinned Locked Moved VOXL 2 IO
4 Posts 2 Posters 1.2k Views 1 Watching
  • Roy WoodR Offline
    Roy WoodR Offline
    Roy Wood
    The VOXL 2 is compatible with TBS Crossfire radio receivers through the UART on J19 connector; however, the UART is needed to connect to VOXL 2 IO expansion board. The VOXL 2 IO expansion board has a dedicated connector for Spektrum receivers. In the VOXL 2 documentation, both Spektrum and TBS Crossfire are connected to the UART on J19 connector. Does this imply that the dedicated connector for Spektrum receiver on the VOXL 2 IO expansion board can be used to connect to TBS Crossfire radio receivers?
    (VOXL 2 IO expansion board is necessary to connector to 6 external ESC's)
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @Roy-Wood ,
      The VOXL2 IO board runs PX4IO code, and it's hard coded to SBUS and DSM on those two ports... so at this point CRSF isn't supported on the VOXL2 IO or planned.....
      Link Preview Image
      File not found · modalai/px4-firmware
      PX4 Autopilot Software. Contribute to modalai/px4-firmware development by creating an account on GitHub.
      favicon
      GitHub (github.com)
      BTW, when VOXL2 IO is connected to J19, the px4io PX4 side driver runs, which is here: https://github.com/modalai/px4-firmware/tree/voxl-dev/src/drivers/px4io
      • Roy WoodR Offline
        Roy WoodR Offline
        Roy Wood
        wrote on last edited by Roy Wood
        Does PX4 expect the radio link to come from the VOXL 2 IO expansion board or can the radio link be connected through a different connector, like "E" in the included diagram?
        • modaltbM Offline
          modaltbM Offline
          modaltb
          Hi @Roy-Wood ,
          Natively, the RC and PX4IO drivers are looking at UART on J19.
          The ESC driver natively looks to J18 (E in the diagram). We've not tried RC on that UART and it's not "easily" configurable through a PX4 param, although I'm pretty sure modifying code could get it going... let me know if you are opening the hood up to the code base and I can point ya towards areas.
