  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. Unable to start voxl-dfs-server
3 Posts 3 Posters 587 Views 1 Watching
  • Tamas Pal 0T Offline
    Tamas Pal 0
    I am trying to use collision prevention feature of voxl2, but I am not able to start voxl-dfs-server.
    The is the terminal output.
    oxl2:/etc/modalai$ voxl-configure-dfs
    Starting Wizard
    Do you want to reset the config file to factory defaults?
    1) yes
    2) no
    #? 1
    wiping old config file
    Creating new config file: /etc/modalai/voxl-dfs-server.conf
    do you want to enable or disable voxl-dfs-server
    1) enable
    2) disable
    #? 1
    enabling  voxl-dfs-server systemd service
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-dfs-server.service → /etc/systemd/system/voxl-dfs-server.service.
    starting  voxl-dfs-server systemd service
    Done configuring voxl-dfs-server
    voxl2:/etc/modalai$ voxl-inspect-services
     modallink-relink     | Disabled  | Not Running |
     voxl-camera-server   |  Enabled  |   Running   |     0.0
     voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
     voxl-dfs-server      |  Enabled  | Not Running |
     voxl-imu-server      |  Enabled  |   Running   |     0.0
     voxl-mavlink-server  |  Enabled  |   Running   |     0.0
     voxl-portal          |  Enabled  |   Running   |     0.0
     voxl-px4-imu-server  | Disabled  | Not Running |
     voxl-px4             |  Enabled  |   Running   |     0.0
     voxl-qvio-server     |  Enabled  |   Running   |     0.0
     voxl-softap          | Disabled  | Not Running |
     voxl-static-ip       | Disabled  | Not Running |
     voxl-streamer        | Disabled  | Not Running |
     voxl-tag-detector    | Disabled  | Not Running |
     voxl-tflite-server   | Disabled  | Not Running |
     voxl-vision-px4      |  Enabled  |   Running   |     0.0
    voxl2:/etc/modalai$ systemctl start voxl-dfs-server
    How to fix it?
    • Johnny KeelerJ Offline
      Johnny Keeler
      Hi Tamas...
      you started it correctly and i'd like to ask if you've followed it up with a couple other steps to just check the situation.
      First after the configuration is set up, which you've done correctly, the device usually needs a full restart to begin working.
      After the restart, check 'voxl-inspect-services' again to make sure the service is Enabled and Running, just to check.
      If that passes the check, run 'ifconfig' to get your ip and post it in a web page browser. Among the available selections should be 'VOA PC' and should give you some positive results.!
      Screenshot from 2022-10-27 11-36-44.png Screenshot from 2022-10-26 17-42-25.png
      • ? Offline
        Can you try to run the server manually: voxl-dfs-server and see what the output says
