  3. docker on voxl flight deck stop working
3 Posts 1 Posters 582 Views
  • Dong LiuD Offline
    Dong LiuD Offline
    Dong Liu
    Docker suddenly stops working on my voxl flight deck. The docker daemon won't start.
    Here is the error message
    voxl:/$ systemctl status docker-daemon -l
    Oct 09 03:45:44 apq8096 docker[4238]: time="2022-10-09T03:45:44.540007000Z" level=warning msg="Could not delete local endpoint clever_babbage during endpoint cleanup: endpoint with name clever_babbage id c039c8337246d161b9242a1a51e1c700b934fd54b4de97e1b2f286b2ae8782d7 has active containers"
    Oct 09 03:45:44 apq8096 docker[4238]: time="2022-10-09T03:45:44.548364000Z" level=fatal msg="Error starting daemon: Error initializing network controller: could not delete the default bridge network: network bridge has active endpoints"
    Oct 09 03:45:44 apq8096 systemd[1]: docker-daemon.service: Main process exited, code=exited, status=1/FAILURE
    I googled this error. Many people suggested that rm -r /var/lib/docker/network should fix it. But it didn't work. Everytime I tried to start the docker daemon, a new socket file was created under /var/lib/docker/network/files
    Dong
    • Dong LiuD Offline
      Dong LiuD Offline
      Dong Liu
      If I want to reset docker to the initial state. What should I do?
      Will
      rm -r /data/containers
      rm -r /data/overlays
      do it?
      • Dong LiuD Offline
        Dong LiuD Offline
        Dong Liu
        after mkdir /data/docker and /usr/bin/docker daemon -g /data/docker, I saw there is file /data/docker/network/files/local-kv.db. So I just rm /data/network/files/local-kv.db. Now the docker daemon will start.
        But anyway I think it is better make change in /etc/systemd/system/docker-daemon.service, from
        ExecStart=/usr/bin/docker daemon -g /data
        to
        ExecStart=/usr/bin/docker daemon -g /data/docker
        So next time if we want to remove all docker images and clean up the docker, just remove everything under /data/docker.
