  2. VOXL Compute & Autopilot
  3. VOXL
  4. mpa to ros voxl-tag detector
Scheduled Pinned Locked Moved VOXL
7 Posts 5 Posters 1.7k Views 2 Watching
  • Mostafa NikpourM Offline
    Mostafa Nikpour
    I am trying to get voxl-tag detector data by tracking camera in host PC, but it gives me some weird numbers that are not related to tag detection data. I use the roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch in voxl and rostopic echo /tracking_tag_overlay in PC.Screenshot from 2022-09-06 16-06-03.png
    • ? Offline
      You're echoing the tracking tag overlay, which is an image stream with the original image annotated with any detected tags, not a ros packet with information about the tags. You'll want to view this with rviz or rqt_image_view.
      Patrick HincheyP 1 Reply Last reply
        Mostafa Nikpour
        Hi Alex,
        How can I remotely access the data displayed by voxl-inspect-tags? I noticed that there were several ROS topics available:
        /imu0
        /imu1
        /qvio_overlay
        /rosout
        /rosout_agg
        /stereo_tag_overlay/left
        /stereo_tag_overlay/right
        /tracking
        /voa_pc_out
        but none of those (tracking and tracking_tag_overlay) seem to be what I need.
        • Nicolas BrissonneauN Offline
          Nicolas Brissonneau
          I'm also interested in accessing this data, I noticed the voxl-inspect-tags code manages to access it but I'm not sure what is the proper approach to send it through MAVROS/Mavlink to an external flight controller. I tried the following things:
          • adding the libraries from voxl-inspect-tags that open the pipe associated with tags to a CMakeLists file in a ROS package, though it doesn't compile with an error message stating they're incompatible when running catkin_make
          • reading the "/tracking" ROS msg from within the kinetic docker and then:
            (1) use a standard ROS package for AprilTag detection, doesn't work as it requires catkin build which fails.
            (2) catkin_make a ROS package for AprilTag detection, but I didn't have any luck with compiling OpenCV in the docker.
          My ultimate goal would be to send this data to PX4 via UART for precision landing but so far I'm a bit lost and would truly appreciate an opinion on this. Would it be simpler to copy the process from voxl-inspect-tags and use mavlink directly to send it to the separate flight controller? If so how would one add mavlink messaging capabilities to the .c code? Or am I way off?
          Jose Alfredo Rosas CordovaJ 1 Reply Last reply
          • Patrick HincheyP Offline
            Patrick Hinchey
            Did anything come of this?
            I'm also trying to access AprilTag location in ROS, but there's nothing obvious in rostopic list.
            I can't find any documentation on it either.
            @modaltb
            • ? A Former User
              Patrick Hinchey
              @Alex-Gardner Is there any way to get the tag X.Y.Z coords in ROS?
              • Nicolas BrissonneauN Nicolas Brissonneau
                Jose Alfredo Rosas CordovaJ Offline
                Hello, @Nicolas-Brissonneau:
                I am trying to do the same thing as you and am stuck with the same problem. Did you manage to solve it?
