    ADB Device Not Detected After Connecting J2
    • M
      marzaga
      I plugged in the IMX377 4K hi-res sensor to J2 and I am unable to get any adb device to show up, nor ssh into the voxl over wifi. Is there a configuration file or software package I need to make this sensor work? Or is it possible I have a bad sensor?
        This usually occurs when the connector is plugged in upside down. Can you make sure that the camera is plugged in right-side up, the physical connector can fit both ways but only one is correct.
        M 1 Reply Last reply Reply Quote 1
        • M
          marzaga @Guest
          @Alex-Gardner Thank you, that fixed the issue.
