    Extract Depth From Depth Image
    Image Sensors
    • A
      amiranda
      I have a pmd tof sensor and I am able to see its imagery using voxl-portal or rosrun image_view but how can I extract the depth of the points in mm? Is there an easy way to do that while I do some testing or do I have to write something up to subscribe and print the various points out?
      Is there a handy logging tool of somesort that could give me an array of depth points?
        We have a feature in the works for our voxl-logger project that would allow it to log tof data to a file. In the meantime, you can use voxl-inspect-points to look at a subsample of the points, or copy and modify the source to process the data however you'd like.
        • A
          amiranda
          Thanks @Alex-Gardner ,
          If I enter voxl-inspect-points tof_pc -n then is the z axis supposed to be depth in mm? Is there a scale that is supposed to be applied to get between float and distance?
          Also is something like the following the expected output? It just says Float XYZ.
          timestamp(ms)| # points | # bytes | Format
          8104565 | 38528 | 462336 | Float XYZ
          8104628 | 38528 | 462336 | Float XYZ
          8104696 | 38528 | 462336 | Float XYZ
          8104758 | 38528 | 462336 | Float XYZ
          I can start going through the source, I just want to make sure I understand everything so I can get the correct depth in distance extracted.
          Thanks for your help.
            Hey @amiranda,
            For the tof points, each axis is measured in meters, no scaling is needed.
            • A
              amiranda
              Okay, in the meantime, I ended up creating a subscriber for the tof_pc and I managed to extract the x,y and z points. Im assuming that the z point that I extracted from the voxl_mpa_to_ros is the same as the one used in voxl-inspect-points, so that z axis is also reported in meters correct?
              Thanks for you help so far.
