  2. VOXL Accessories
  3. Image Sensors
  4. Extract Depth From Depth Image
Scheduled Pinned Locked Moved Image Sensors
5 Posts 3 Posters 1.2k Views
  • A Offline
    amiranda
    I have a pmd tof sensor and I am able to see its imagery using voxl-portal or rosrun image_view but how can I extract the depth of the points in mm? Is there an easy way to do that while I do some testing or do I have to write something up to subscribe and print the various points out?
    Is there a handy logging tool of somesort that could give me an array of depth points?
      We have a feature in the works for our voxl-logger project that would allow it to log tof data to a file. In the meantime, you can use voxl-inspect-points to look at a subsample of the points, or copy and modify the source to process the data however you'd like.
      • A Offline
        amiranda
        wrote on last edited by amiranda
        Thanks @Alex-Gardner ,
        If I enter voxl-inspect-points tof_pc -n then is the z axis supposed to be depth in mm? Is there a scale that is supposed to be applied to get between float and distance?
        Also is something like the following the expected output? It just says Float XYZ.
        timestamp(ms)| # points | # bytes | Format
        8104565 | 38528 | 462336 | Float XYZ
        8104628 | 38528 | 462336 | Float XYZ
        8104696 | 38528 | 462336 | Float XYZ
        8104758 | 38528 | 462336 | Float XYZ
        I can start going through the source, I just want to make sure I understand everything so I can get the correct depth in distance extracted.
        Thanks for your help.
          Hey @amiranda,
          For the tof points, each axis is measured in meters, no scaling is needed.
          • A Offline
            amiranda
            Okay, in the meantime, I ended up creating a subscriber for the tof_pc and I managed to extract the x,y and z points. Im assuming that the z point that I extracted from the voxl_mpa_to_ros is the same as the one used in voxl-inspect-points, so that z axis is also reported in meters correct?
            Thanks for you help so far.
