Pre-purchase questions: VOXL 2 Mini, aircraft-side VTX, and camera connection accessories
Hello ModalAI team,
I contacted your sales team about purchasing the items below, and they directed me to this forum for technical questions. Before proceeding with a quotation, I would like to confirm the required components and their compatibility.
Planned purchase
1 × VOXL 2 Mini — including a power module
1 × IMX412 camera (MSU-M0161) — with a 3.24 mm lens, IR-cut filter, and an 80 mm micro-coax cable
1 × MVX FPV Video Receiver (VRX) set — without goggles, including a DisplayPort-to-Mini-HDMI adapter, battery, and XT30 Y power cable
1 × IMX664 camera (MSU-M0186) — including an M12 lens and a micro-coax cable
Our main questions concern how to purchase the aircraft-side VTX and whether all accessories needed to connect the cameras to VOXL 2 Mini are included. -
Aircraft-side VTX hardware and purchasing information
I found the VRX listed for sale, but I could not find the corresponding aircraft-side VTX product. This is one of the main reasons for my inquiry.
What VTX hardware is required to transmit video from the VOXL 2 Mini to the VRX? Please provide the purchase link or part number for the required hardware.
Please also identify any necessary antennas, cables, adapter boards, and other accessories. We would like to add the required transmitter components to our planned VOXL 2 Mini purchase without buying duplicate VOXL boards or cameras.
- Included camera connectors, cables, and adapter boards
We plan to connect the IMX412 and IMX664 cameras to the VOXL 2 Mini.
If we purchase the camera configurations listed above, will all connectors, cables, and adapter boards required to connect each camera to the VOXL 2 Mini be included?
Can the supplied micro-coax cables connect directly to the VOXL 2 Mini, or are separate adapter boards or additional cables required? If additional components must be purchased, please provide the part numbers and quantities needed for each camera.
Can both cameras be connected to and operated on a single VOXL 2 Mini simultaneously? If so, please specify the required ports and any limitations.
- Bidirectional MAVLink communication with a laptop GCS
We plan to use a laptop-based ground control station (GCS) for autonomous flight. We therefore need bidirectional MAVLink communication between the aircraft and the GCS, including telemetry reception, command transmission, parameter access and modification, and mission uploads.
Does the recommended VTX/VRX configuration support these functions, including while the aircraft is armed and in flight?
Please explain any required settings or unsupported functions. If a separate telemetry radio or communication link is necessary, please recommend a suitable configuration.
- Recommended SDK, firmware, and pre-shipment configuration
The documentation we reviewed mentions SDK 1.8.0. Is this version appropriate for the proposed configuration?
Please recommend mutually compatible stable versions of the VOXL SDK, flight controller firmware, and VTX/VRX software that support the listed cameras.
Can the equipment be supplied with these versions preinstalled and the necessary configuration completed before shipment?
- IMX664 availability and quotation process
The IMX664 product page indicates that availability must be confirmed. Could you please confirm its availability and estimated lead time, or let us know if these questions should be handled directly by sales?
Once the technical configuration is confirmed, we would like to send it back to sales for a quotation. We would appreciate a complete parts list covering the planned items, required VTX hardware, and all camera connection accessories.
Thank you for your assistance.
