  3. M0184 ELRS no CRSF data after SDK 1.6.4 upgrade
4 Posts 2 Posters 44 Views
  • chiu pkC Offline
    chiu pkC Offline
    chiu pk
    wrote last edited by
    Hi ModalAI team,
    I am troubleshooting an ELRS/CRSF issue on a Starling 2 with the
    original M0184 ELRS receiver.
    IMPORTANT:
    The M0184 ELRS was working normally with VOXL SDK 1.6.3.
    This problem started after upgrading from SDK 1.6.3 to SDK 1.6.4.
    After the upgrade, the receiver still powers on and can enter binding
    mode, but PX4 never receives any CRSF frames.
    Hardware:
    • Drone: ModalAI Starling 2 (D0014)
    • VOXL2: M0054
    • SKU: MRB-D0014-4-V1-C26-T8-M36-X0
    • tx config: 8 (elrs_m0184)
    • ELRS receiver: M0184
    Software version:
    • Previous SDK: 1.6.3 (ELRS working)
    • Current SDK / voxl-suite: 1.6.4
    • system-image: 1.8.08-M0054-14.1a-perf
    • voxl-px4: 1.14.0-2.0.142
    • voxl-elrs: 1.1.6
    • libfc-sensor: 1.0.12
    • modalai-slpi: 1.2.3
    Full voxl-version output is attached below.
    Configuration / services:
    After the SDK upgrade I ran voxl-configure-mpa.
    The detected hardware configuration is correct:
    family code:   MRB-D0014 (starling-2 (D0014))
    compute board: 4 (voxl2)
    cam config:    26
    modem config:  36 (Bots Unlimited WiFi (M0213))
    During voxl-configure-mpa, the ELRS configuration failed:
    executing: voxl-elrs configure
    elrs: px4 running but no crsf data
    Error: initialize ELRS: communication channel closed
    FAILED TO EXECUTE:
    voxl-elrs configure
    PX4 was correctly configured as:
    GPS=AUTODETECT
    RC=CRSF_RAW
    I then fully power-cycled the Starling 2.
    What I am trying to do:
    Restore the M0184 ELRS functionality that was working before the
    SDK 1.6.3 -> 1.6.4 upgrade.
    What actually happens:
    After a full power cycle, PX4 starts the CRSF driver normally:
    RC: CRSF_RAW
    Starting CRSF RC driver
    crsf_rc start -d 7
    [crsf_rc] Crsf serial opened successfully
    [crsf_bridge] Created pipe 'crsf_raw' on channel 3 with control pipe enabled
    However:
    voxl-elrs ping
    returns:
    And px4-listener input_rc always shows:
    timestamp_last_signal: 0
    rc_total_frame_count: 0
    rc_failsafe: True
    rc_lost: True
    link_quality: -1
    Therefore, the QUP7/CRSF driver appears to open successfully, but PX4
    does not receive even a single valid CRSF frame.
    Troubleshooting already performed:
    1. Original configuration:
      M0184 -> QUP7
      crsf_rc start -d 7 opens successfully, but no CRSF frames are received.
    2. To rule out QUP7, I temporarily disabled GPS and moved the M0184
      UART signals from QUP7 to QUP6:
      J19 Pin 10 (QUP7 TX) -> Pin 2 (QUP6 TX)
      J19 Pin 11 (QUP7 RX) -> Pin 3 (QUP6 RX)
      Power and GND were unchanged.
    3. I started:
      px4-qshell crsf_rc start -d 6
      Again:
      but input_rc remained:
      rc_lost: True
    4. I restored the original wiring:
      • GPS -> QUP6
      • M0184 -> QUP7
      GPS communication on QUP6 works normally after restoration.
    5. I ran voxl-configure-mpa, performed a full power cycle, and tested
      again. The ELRS behavior remains unchanged.
    Questions:
    1. Since the M0184 was working with SDK 1.6.3 and stopped working after
      upgrading to SDK 1.6.4, are there any known M0184 / CRSF / SLPI
      compatibility or configuration changes between these SDK versions?
    2. Could the SDK 1.6.4 upgrade or voxl-elrs configure have changed or
      updated the firmware/configuration on the M0184?
    3. Does rc_total_frame_count: 0 in this situation indicate that no
      UART data is being received from the M0184, or could this also be
      caused by a CRSF protocol/baud/configuration mismatch?
    4. Is there a recommended way to test the M0184 UART independently of
      QUP6/QUP7?
      For example, can I connect a 3.3V USB-UART adapter to the VOXL2 USB
      host and run:
      voxl-elrs -p /dev/ttyUSB0 -b 420000 ping
      with:
      M0184 TX -> USB-UART RX
      M0184 RX <- USB-UART TX
      GND      -> GND
      M0184 powered separately from 5V
    5. If the above USB-UART test is supported, is 420000 baud / 3.3V UART
      the correct electrical and serial configuration for the M0184?
    Thanks.
    Ben LinneB 1 Reply Last reply
    • chiu pkC chiu pk
      Hi ModalAI team,
      IMPORTANT:
      Hardware:
      • VOXL2: M0054
      Software version:
      • voxl-elrs: 1.1.6
      cam config:    26
      FAILED TO EXECUTE:
      voxl-elrs configure
      GPS=AUTODETECT
      RC=CRSF_RAW
      RC: CRSF_RAW
      crsf_rc start -d 7
      However:
      voxl-elrs ping
      returns:
      rc_failsafe: True
      rc_lost: True
      link_quality: -1
        M0184 -> QUP7
      3. I started:
        Again:
        rc_lost: True
        • GPS -> QUP6
        • M0184 -> QUP7
      Questions:
        QUP6/QUP7?
        host and run:
        with:
        GND      -> GND
      Thanks.
      Ben LinneB Offline
      Ben LinneB Offline
      Ben Linne
      @chiu-pk
      Can you report back the LED status? If the red LED is performing a triple blink then it's a teamrace/model mismatch issue.
      If you try to stop px4 with systemctl stop voxl-px4, does voxl-elrs ping work?
      Is the issue strictly with PX4 not getting the RC data?
      1. I believe both SDK's should work
      2. Yes the FW updated ELRS to 3.5.3.23
        https://docs.modalai.com/sdk-1.6-release-notes/#sdk-164-full-changelog-from-sdk-163
      3. I think if it's not bound, but the most reliable method is to use voxl-elrs ping
      4. Yes, but you need a USB-UART adapter that supports 420000 baud, the FT232R is what I typically use
      5. 3.3V is the correct UART voltage
      chiu pkC 1 Reply Last reply
      • Ben LinneB Ben Linne
        @chiu-pk
        chiu pkC Offline
        chiu pkC Offline
        chiu pk
        @Ben-Linne
        Hi Ben,
        Thanks for the information.
        1. The red LED is NOT triple blinking. It is double blinking repeatedly:
          blink-blink -> pause -> blink-blink -> pause
          This appears to be the normal ExpressLRS waiting-for-binding pattern,
          rather than the triple-blink teamrace/model mismatch indication.
        2. I stopped PX4 completely and tested voxl-elrs directly:
          $ systemctl status voxl-px4
          Active: inactive (dead)
          $ voxl-elrs ping
          elrs: auto-detection: voxl-px4 crsf_rc is not running, using qup7
          Error: get device info: no response from device (is it connected and powered?)
        So the issue does not appear to be limited to PX4 receiving RC data.
        voxl-elrs also cannot communicate with the M0184 directly over QUP7
        when PX4 is stopped.
        The M0184 is powered and its red LED shows the double-blink
        waiting-for-binding pattern.
        Since this started immediately after upgrading from SDK 1.6.3 to 1.6.4,
        and you mentioned that the upgrade updates the ELRS firmware to 3.5.3.23:
        • Could the M0184 firmware update have caused the receiver to lose its
          previous binding/configuration?
        • Is it expected that voxl-elrs ping gets no response while the receiver
          is waiting for binding?
        • Is there a recommended recovery/reflash or reconfiguration procedure
          for the M0184 in this situation?
        Thanks.
        • chiu pkC chiu pk
          @Ben-Linne
          Hi Ben,
            $ voxl-elrs ping
          Thanks.
          Ben LinneB Offline
          Ben LinneB Offline
          Ben Linne
          @chiu-pk
          The LED status is good, this receiver should be recoverable assuming the wiring is correct.
          • Could the M0184 firmware update have caused the receiver to lose its previous binding/configuration?
          Yes some updates will unbind the receiver. If you want to put the receiver back in bind mode and voxl-elrs doesn't work, hold the button for 5 seconds and it should enter bind mode indicated by the led status rapid double blink
          • Is it expected that voxl-elrs ping gets no response while the receiver is waiting for binding?
          voxl-elrs ping should work in both cases, but to be sure try to bind and see if it works
          • Is there a recommended recovery/reflash or reconfiguration procedure for the M0184 in this situation?
          Try to get voxl-elrs working if possible, if not then using the expresslrs configurator pointed to our custom fork of ELRS with a USB serial adapter that supports 420000 baud will allow you to update
          https://docs.modalai.com/elrs-configurator/
