  3. Near-zero feature extraction (single camera)
voxl-2-mini
3 Posts 2 Posters 1.7k Views
  • Y Offline
    Y Offline
    Yonim
    Hi ModalAI team,
    I'm running voxl-open-vins-server on a VOXL2 Mini (SDK 1.6.2) with two AR0144 tracking cameras in a non-overlapping front + down configuration (not stereo). I would appreciate guidance.
    ENVIRONMENT
    • VOXL2 Mini, SDK 1.6.2
    • voxl-open-vins-server, internal tracker (en_ext_feature_tracker not used; voxl-feature-tracker disabled)
    • 2x AR0144, front + down, non-overlapping FOV
    • estimator_config.yaml (fpv): use_stereo: false, max_cameras: 2, use_klt: true, use_gpu: true, num_pts: 50, fast_threshold: 15, min_px_dist: 10, histogram_method: HISTOGRAM
    • vio_cams.conf: both cams enabled
    The issue is Near-zero feature extraction (single camera): I disabled the down camera. However, even during motion over textured, well-lit scenes, voxl-inspect-vins reports only ~1 feature, quality 0%, state OKAY, and T_imu_wrt_vio runs away (tens of meters). The estimator loop is healthy but the tracker extracts almost nothing.
    What I've verified / ruled out:
    • Both camera feeds live and clean at the pipe level: 1280x800 @ 30fps, RAW8, reasonable exposure/gain (voxl-inspect-cam).
    • Intrinsics present and valid (fisheye, both cams); extrinsics validated incl. body -> imu_apps (voxl-inspect-extrinsics passes).
    • IMU vibration at rest all green (voxl-inspect-vibration).
    • Tried histogram_method HISTOGRAM and NONE; min_px_dist 50 -> 10; use_gpu true/false (CPU path "sticks"); switched tracking pipes off the _ion variants to plain *_misp_norm. None of these moved the feature count off ~1.
    Questions:
    1. For the single-camera case, what would cause the internal tracker to return ~1 feature on a sharp, textured image with the config above?
    2. Is there a recommended way to visualize the internal tracker's extracted features for OpenVINS (the cameras-tab feat_overlay pipe is empty since voxl-feature-tracker is disabled — is ov_overlay under the VIO tab the correct view)?
    3. Is there updated AR0144 driver / SDK guidance for non-overlapping multi-camera VIO on the VOXL2 Mini?
    Best regards,
    Yoni
    zauberflote1Z 1 Reply Last reply
    • Y Yonim
      Hi ModalAI team,
      ENVIRONMENT
      Questions:
      Best regards,
      Yoni
      zauberflote1Z Offline
      zauberflote1
      @Yonim Hello,
      Quick question: Are you using a development drone? If not, have you calibrated your extrinsics and intrinsics properly?
      • zauberflote1Z zauberflote1
        @Yonim Hello,
        zauberflote1
        wrote on last edited by zauberflote1
        Regarding the feature track tab, I recommend upgrading to the latest available SDK, features should show on voxl-portal.
        The correct overlay is under VIO indeed
