  2. VOXL SDK and Software
  3. Multiple Critical Bugs in voxl-imu-server: Incorrect FIFO Latching and HiRes Indexing (ICM-42688)
voxl-sdk
4 Posts 2 Posters 2.3k Views 2 Watching
  • IgorI Offline
    IgorI Offline
    Igor
    While auditing the IMU driver logic for the QRB5165 (icm42688.cpp), I identified two significant logical errors in how the ICM-42688-P FIFO data is retrieved and parsed. These bugs affect data integrity and 20-bit precision.
    Bug 1: Incorrect FIFO_COUNT Latching Sequence (Race Condition)
    Location: src/drivers/icm42688.c (inside read_imu_fifo)
    The current implementation reads fifo_count starting from FIFO_COUNTH (0x2E).
        // first read how many bytes are available using the fifo_count register
        ret = voxl_spi_read_reg_word(bus, count_address, &fifo_count);
    but acording to IMU document we must read FIFO_COUNTL to latch the data
    Bug 2: Index Mismatch in 20-bit HiRes Packet Parsing
    Technical Detail:
    When parsing Packet 4 (20-byte), the code maps the extension bits (lower 4 bits) incorrectly for the accelerometer.
    		ax32 = ((int32_t)ax16 << 4) | ((base[11] & 0xF0) >> 4);
    		ay32 = ((int32_t)ay16 << 4) | ((base[12] & 0xF0) >> 4);
    		az32 = ((int32_t)az16 << 4) | ((base[13] & 0xF0) >> 4);
    It uses byte indices 11, 12, and 13, but these correspond to Gyro Z and Temperature data. The correct indices are 17, 18, and 19.
    • IgorI Igor
      Technical Detail:
      Hello @Igor ,
      After a quick look your concerns seem valid to me. We will investigate this further and get back to you soon.
      Thank you for reporting the issue.
        Hello @Igor ,
        @Igor ,
        You are absolutely correct about the incorrect parsing of the accel data. This is a typo and it was not detected because the effect of it is very small (4 LSB of the 20-bit number). The accelerometer noise in flight will dominate and these bytes will have no effect. We will fix this bug.
        Regarding the order of the reading of FIFO_COUNT, we looked at many other sources, including the reference code from TDK and all the implementations read the FIFO_COUNTH first, so we suspect that the documentation has a typo (which makes sense, otherwise the implementation would have to have separate transactions for reading the H and L parts).
        Thank you again for your bug report.
        IgorI 1 Reply Last reply
          @Igor ,
          IgorI Offline
          IgorI Offline
          Igor
          @Alex-Kushleyev Hi Alex,
          Thank you for the clarification.
          That makes sense regarding the accel parsing—agreed that a 4 LSB discrepancy on a 20-bit value is negligible compared to in-flight noise, but it’s good to see it will be corrected.
          Appreciate you taking the time to investigate and confirm.
          Igor
