    ROS_DOMAIN_ID Change
    • Y
      yunwool
      Dear Researchers and Developers,
      I can see PX4-related ROS 2 messages even without explicitly running any ROS 2 nodes myself.
      It looks like these messages are visible under ROS_DOMAIN_ID=0.
      Could you please share guidance on how to change the ROS 2 domain ID for these PX4-related messages?
      • A
        ApoorvThapliyal @yunwool
        Hey @yunwool
        I would recommend writing export ROS_DOMAIN_ID=1 in your ~/.bashrc and then restarting all terminals so the change takes effect. This should prevent other ROS 2 messages from appearing in your environment, since you’ll effectively be using your own domain.
        Optionally, you may want to look into the ROS_LOCALHOST_ONLY variable as well, since I do believe if someone else sets their domain ID to 1, you would see their messages.
        Y 1 Reply Last reply Reply Quote 0
        • Y
          yunwool @ApoorvThapliyal
          @ApoorvThapliyal
          Thank you for the reply.
          Did you happen to add export ROS_DOMAIN_ID=1 to your ~/.bashrc?
          When I do that, ROS 2 topics disappear in the VOXL shell.
          However, on my laptop where ROS_DOMAIN_ID=0, I can see the ROS topics.
          That’s why I posted this.
          • A
            Hey @yunwool
            Did you try setting the ROS_LOCALHOST_ONLY variable to limit the topics to your local device?
            • Y
              @ApoorvThapliyal
              Thank you again for the reply!
              We are setting up a multi-robot system, so we are using ROS_LOCALHOST_ONLY=0.
              For example, we want to set the ROS_DOMAIN_ID of drone 1 to 1 and the ROS_DOMAIN_ID of drone 2 to 2.
              However, for both drones, PX4-related messages still appear under domain ID 0.
              Have you tried this with two or more drones?
              • A
                Hey @yunwool
                Just to be clear, consider only your first drone, if you run export ROS_DOMAIN_ID=1, then run ros2 topic list, you aren't seeing any topics right?
                After you set the ROS_DOMAIN_ID of a drone to 1, to get the PX4 topics to show up, on QGC > Analyze Tools > MAVLink Console, run the following commands:
                param set XRCE_DDS_DOM_ID 1
                param save
                Then power cycle the drone, give it like 15s after boot up, then the topics should come up directly when running ros2 topic list on that drone.
