ROS_DOMAIN_ID Change
Dear Researchers and Developers,
I can see PX4-related ROS 2 messages even without explicitly running any ROS 2 nodes myself.
It looks like these messages are visible under ROS_DOMAIN_ID=0.
Could you please share guidance on how to change the ROS 2 domain ID for these PX4-related messages?
Hey @yunwool
I would recommend writingexport ROS_DOMAIN_ID=1in your~/.bashrcand then restarting all terminals so the change takes effect. This should prevent other ROS 2 messages from appearing in your environment, since you’ll effectively be using your own domain.Optionally, you may want to look into the ROS_LOCALHOST_ONLY variable as well, since I do believe if someone else sets their domain ID to 1, you would see their messages.
@ApoorvThapliyal
Thank you for the reply.
Did you happen to add export ROS_DOMAIN_ID=1 to your ~/.bashrc?
When I do that, ROS 2 topics disappear in the VOXL shell.
However, on my laptop where ROS_DOMAIN_ID=0, I can see the ROS topics.
That’s why I posted this. -
Hey @yunwool
Did you try setting the ROS_LOCALHOST_ONLY variable to limit the topics to your local device?
