    voxl-dfs-server failing to run
    Modal Pipe Architecture (MPA)
    • Lynn KoudsiL
      Lynn Koudsi
      I installed the latest voxl-suite and system image 3.3, and I noticed that voxl-dfs-server is failing to run. I'm getting the following output:
      yocto:/# opkg list-installed | grep opencl
      opencl - 0.0.2
      yocto:/# systemctl status voxl-dfs-server -l
      ā— voxl-dfs-server.service - voxl-dfs-server
         Loaded: loaded (/usr/bin/voxl-dfs-server; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Thu 1970-01-01 00:00:07 UTC; 51 years 9 months ago
        Process: 2114 ExecStart=/usr/bin/voxl-dfs-server (code=exited, status=127)
       Main PID: 2114 (code=exited, status=127)
      Jan 01 00:00:07 apq8096 systemd[1]: Started voxl-dfs-server.
      Jan 01 00:00:07 apq8096 systemd[1]: voxl-dfs-server.service: Main process exited, code=exited, status=127/n/a
      Jan 01 00:00:07 apq8096 systemd[1]: voxl-dfs-server.service: Unit entered failed state.
      Jan 01 00:00:07 apq8096 systemd[1]: voxl-dfs-server.service: Failed with result 'exit-code'.
      Jan 01 00:00:08 apq8096 voxl-dfs-server[2114]: /usr/bin/voxl-dfs-server: error while loading shared libraries: libOpenCL.so: cannot open shared object file: No such file or directory
      yocto:/#
      any thoughts as to what could be the problem?
        Hi Lynn,
        That should be built in to system image 3.3 and shouldn't show up in opkg. Can you paste the output of voxl-version to make sure everything is set up properly. Additionally, you can check if the libraries exist manually in /usr/lib or /usr/lib64 by running:
        yocto:/usr$ find | grep -i opencl
        ./include/CL/opencl.h
        ./include/adreno/CL/opencl.h
        ./include/opencv4/opencv2/core/opencl
        ./include/opencv4/opencv2/core/opencl/opencl_info.hpp
        ./include/opencv4/opencv2/core/opencl/ocl_defs.hpp
        ./include/opencv4/opencv2/core/opencl/opencl_svm.hpp
        ./include/opencv4/opencv2/core/opencl/runtime
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_clamdblas.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_svm_definitions.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_svm_hsa_extension.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_svm_20.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_clamdfft.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_gl.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_core.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_core_wrappers.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/opencl_gl_wrappers.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/autogenerated
        ./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_clamdblas.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_clamdfft.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_gl.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_core.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_core_wrappers.hpp
        ./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_gl_wrappers.hpp
        ./include/tensorflow-2-2-3/tensorflow/lite/delegates/gpu/cl/opencl_wrapper.h
        ./lib/libOpenCL.so
        ./lib64/libOpenCL.so
        ./share/cmake-3.3/Help/module/FindOpenCL.rst
        ./share/cmake-3.3/Modules/FindOpenCL.cmake
        ./share/licenses/opencv4/opencl-headers-LICENSE.txt
        yocto:/usr$
        • Lynn KoudsiL
          Lynn Koudsi
          Seemed like a weird fluke... I reinstalled the system image + voxl suite this time from the install script, then removed the packages individually and reinstalled my built versions, and it worked...
          Thank you though!
          Lynn
