<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[voxl-dfs-server failing to run]]></title><description><![CDATA[<p dir="auto">I installed the latest voxl-suite and system image 3.3, and I noticed that voxl-dfs-server is failing to run. I'm getting the following output:</p>
<pre><code>yocto:/# opkg list-installed | grep opencl
opencl - 0.0.2
yocto:/# systemctl status voxl-dfs-server -l
● voxl-dfs-server.service - voxl-dfs-server
   Loaded: loaded (/usr/bin/voxl-dfs-server; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 1970-01-01 00:00:07 UTC; 51 years 9 months ago
  Process: 2114 ExecStart=/usr/bin/voxl-dfs-server (code=exited, status=127)
 Main PID: 2114 (code=exited, status=127)
Jan 01 00:00:07 apq8096 systemd[1]: Started voxl-dfs-server.
Jan 01 00:00:07 apq8096 systemd[1]: voxl-dfs-server.service: Main process exited, code=exited, status=127/n/a
Jan 01 00:00:07 apq8096 systemd[1]: voxl-dfs-server.service: Unit entered failed state.
Jan 01 00:00:07 apq8096 systemd[1]: voxl-dfs-server.service: Failed with result 'exit-code'.
Jan 01 00:00:08 apq8096 voxl-dfs-server[2114]: /usr/bin/voxl-dfs-server: error while loading shared libraries: libOpenCL.so: cannot open shared object file: No such file or directory
yocto:/#
<p dir="auto">any thoughts as to what could be the problem?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.modalai.com/topic/515/voxl-dfs-server-failing-to-run</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 07:27:38 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/515.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Oct 2021 19:57:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to voxl-dfs-server failing to run on Tue, 26 Oct 2021 21:09:26 GMT]]></title><description><![CDATA[<p dir="auto">Seemed like a weird fluke... I reinstalled the system image + voxl suite this time from the install script, then removed the packages individually and reinstalled my built versions, and it worked...</p>
<p dir="auto">Thank you though!</p>
<p dir="auto">Lynn</p>
]]></description><link>https://forum.modalai.com/post/2422</link><guid isPermaLink="true">https://forum.modalai.com/post/2422</guid><dc:creator><![CDATA[Lynn Koudsi]]></dc:creator><pubDate>Tue, 26 Oct 2021 21:09:26 GMT</pubDate></item><item><title><![CDATA[Reply to voxl-dfs-server failing to run on Tue, 26 Oct 2021 17:30:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi Lynn,</p>
<p dir="auto">That should be built in to system image 3.3 and shouldn't show up in opkg. Can you paste the output of <code>voxl-version</code> to make sure everything is set up properly. Additionally, you can check if the libraries exist manually in /usr/lib or /usr/lib64 by running:</p>
<pre><code>yocto:/usr$ find | grep -i opencl
./include/CL/opencl.h
./include/adreno/CL/opencl.h
./include/opencv4/opencv2/core/opencl
./include/opencv4/opencv2/core/opencl/opencl_info.hpp
./include/opencv4/opencv2/core/opencl/ocl_defs.hpp
./include/opencv4/opencv2/core/opencl/opencl_svm.hpp
./include/opencv4/opencv2/core/opencl/runtime
./include/opencv4/opencv2/core/opencl/runtime/opencl_clamdblas.hpp
./include/opencv4/opencv2/core/opencl/runtime/opencl_svm_definitions.hpp
./include/opencv4/opencv2/core/opencl/runtime/opencl_svm_hsa_extension.hpp
./include/opencv4/opencv2/core/opencl/runtime/opencl_svm_20.hpp
./include/opencv4/opencv2/core/opencl/runtime/opencl_clamdfft.hpp
./include/opencv4/opencv2/core/opencl/runtime/opencl_gl.hpp
./include/opencv4/opencv2/core/opencl/runtime/opencl_core.hpp
./include/opencv4/opencv2/core/opencl/runtime/opencl_core_wrappers.hpp
./include/opencv4/opencv2/core/opencl/runtime/opencl_gl_wrappers.hpp
./include/opencv4/opencv2/core/opencl/runtime/autogenerated
./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_clamdblas.hpp
./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_clamdfft.hpp
./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_gl.hpp
./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_core.hpp
./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_core_wrappers.hpp
./include/opencv4/opencv2/core/opencl/runtime/autogenerated/opencl_gl_wrappers.hpp
./include/tensorflow-2-2-3/tensorflow/lite/delegates/gpu/cl/opencl_wrapper.h
./lib/libOpenCL.so
./lib64/libOpenCL.so
./share/cmake-3.3/Help/module/FindOpenCL.rst
./share/cmake-3.3/Modules/FindOpenCL.cmake
./share/licenses/opencv4/opencl-headers-LICENSE.txt
yocto:/usr$
]]></description><link>https://forum.modalai.com/post/2419</link><guid isPermaLink="true">https://forum.modalai.com/post/2419</guid><dc:creator><![CDATA[[[global:former_user]]]]></dc:creator><pubDate>Tue, 26 Oct 2021 17:30:08 GMT</pubDate></item></channel></rss>
