  2. Software Development
  3. GPS-denied Navigation (VIO)
  4. setting up VIO on VOXL2 (custom frame)
Scheduled Pinned Locked Moved GPS-denied Navigation (VIO)
2 Posts 1 Posters 2.0k Views
  • P Offline
    P Offline
    psafi
    wrote on last edited by psafi
    I am trying to set up VIO for a custom frame which has two ar0144 (down and front) cameras.
    I have followed this sequence so far:
    1- voxl-camera-serveris up and running and I can see both camera feed in portal and using voxl-inspect-cam
    2- saved Extrinsics to /etc/modal/extrinsics.conf
    3- made sure vio_cams.conf exists and information makes sense
    4- following instructions as outlined here: https://docs.modalai.com/open-vins/ (with the exception of my SDK version which in my case is 1.5.0)
    here is the default content of voxl-open-vins-server.conf:
     * This file contains configuration that's specific to voxl-open-vins-server.
     * *NOTE*: all time variables are measured in seconds
    	"en_auto_reset":	true,
    	"auto_reset_max_velocity":	20,
    	"auto_reset_max_v_cov_instant":	0.20000000298023224,
    	"auto_reset_max_v_cov":	0.20000000298023224,
    	"auto_reset_max_v_cov_timeout_s":	0.5,
    	"auto_reset_min_features":	1,
    	"auto_reset_min_feature_timeout_s":	3,
    	"auto_fallback_timeout_s":	3,
    	"auto_fallback_min_v":	0.600000023841858,
    	"en_cont_yaw_checks":	false,
    	"fast_yaw_thresh":	5,
    	"fast_yaw_timeout_s":	1.75,
    	"yaml_folder":	"/usr/share/modalai/voxl-open-vins/VoxlConfig/starling2",
    	"using_stereo":	0,
    	"takeoff_alt_threshold":	0.5,
    	"takeoff_occlude_stereo_left":	false,
    	"takeoff_occlude_stereo_right":	false,
    	"sync_config":	true
    5- I see voxl-open-vins-server process is not running and when I try to run it manually I get the following warning/error:
    WARNING: cal file opencv_tracking_front_intrinsics.yml is missing or invalid
    run voxl-check-calibration to see what calibration files are missing
    WARNING: cal file opencv_tracking_down_intrinsics.yml is missing or invalid
    failed to find cam cal for vio cam tracking_front
    ERROR cam_config_file_read
    QUIT REQUESTED
    Shutting down cameras...
    Camera shutdown complete
    error code: -1
    I am currently in the process of calibrating the camera but I am unable to complete it. I can see the overlay in the portal and all corners being detected but calibration is not progressing beyond %0
    P 1 Reply Last reply
    • P psafi
      	"using_stereo":	0,
      	"sync_config":	true
      QUIT REQUESTED
      error code: -1
      P Offline
      P Offline
      psafi
      @psafi Here are the steps I am taking for camera calibration:
      1- run the following command:
      voxl-calibrate-camera tracking_down -f -s 6x9 -l 0.022
      2- look at the overlay in portal (see the screenshot below)
      3- calibration process is not progressing automatically even though it seems like the checkerboard is detected
      e47c8511-c92f-4ce7-83f6-49d59dd89e7d-Screenshot from 2025-10-14 11-14-52.png
