  3. Unable to get accurate depth and camera_info from TOF on Starling 2 Max
3 Posts 2 Posters 748 Views 1 Watching
  • Jing YuJ Offline
    Jing YuJ Offline
    Jing Yu
    I’m using the Starling 2 Max with VOXL 2 and I’m trying to access depth information from the onboard TOF sensor.
    I am subscribing to /tof_depth, which publishes sensor_msgs/Image in mono8 format. However:
    I don’t know how to convert the 8-bit gray value to actual depth in meters. Is there a LUT or scale factor available for this sensor?
    The topic /tof_depth/camera_info returns zero intrinsics (all zeros in the K matrix), so I cannot project the depth image into a point cloud.
    I couldn’t find any calibration or intrinsics related to the TOF sensor in /etc/modalai .
    Could you please advise how to:
    Obtain the proper depth scale or conversion formula from mono8
    Get or generate accurate camera_info for the TOF sensor
    Thanks in advance!
    • Jing YuJ Jing Yu
      Thanks in advance!
      @Jing-Yu , the tof_depth image is a 8-bit image where each pixel represents a scaled depth. this may not be the best way to use the output of TOF sensor.
      You can subscribe to the point cloud directly.
      Here is the code that handles the output of the TOF sensor and publishes it to MPA clients. This shows how the different images are generated, including how the TOF depth is scaled to produce an image : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/dev/src/hal3_camera_mgr.cpp?ref_type=heads#L3214 ( RoyaleDataDone function).
      Here is an example for receiving the TOF point cloud using an MPA client. it is very basic, but you can update it. The data that is sent out is an array of XYZ float points : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-tools/-/blob/master/tools/voxl-inspect-points.c?ref_type=heads
      and finally here is another example in voxl mpa-to-ros library, which handles conversion from the MPA messages to ROS. It has a few point cloud formats, but the one you need is the XYZ : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros/-/blob/master/catkin_ws/src/src/interfaces/point_cloud_interface.cpp?ref_type=heads
      Jing YuJ 1 Reply Last reply
        Jing YuJ Offline
        Jing YuJ Offline
        Jing Yu
        Thanks for the explanation — I now understand how to use the TOF sensor.
        I’ll use the ROS point cloud directly for my research.
