  3. VOXL 2 Camera Connected but Not Feed
18 Posts 4 Posters 2.8k Views 1 Watching
  • Wesley GunawanW Wesley Gunawan
    @tom ^ (Reminder)
    I Offline
    I Offline
    itsnav
    @Wesley-Gunawan Hi Wesley, I faced a similar issue recently. I was using IMX678 Hires Camera in J7U. The camera was detected when I run voxl-camera-server -l, even the green led light on the sensor glows but I didn't get any data run I run voxl-inspect-cam -a. I had an alternate IMX678 camera and without changing any config, I replaced it and it worked. I don't know what is wrong with the first sensor. I should probably do RMA, but yeah, if you have another sensor, give it a try!
    ModeratorM 1 Reply Last reply
    • I itsnav
      @Wesley-Gunawan can you please share a picture of your setup? It needs to match a camera config found here: https://docs.modalai.com/voxl2-camera-configs/
      Often when a camera can't be found:
      1. it's installed backwards
      2. the cable isn't fully connected or the connector is damaged
      3. the wrong camera config has been configured during setup
      Wesley GunawanW 1 Reply Last reply
      • ModeratorM Moderator
        Wesley GunawanW Offline
        Wesley Gunawan
        @Moderator
        Hi, the camera is connected correctly because when the configuration or installation setup isn't correct, voxl-camera-server wouldn't even detect the camera's connection, in this case it does, but no input from the camera has ever been acquired. Here is the image of the setup:
        Is there any other information you need to help me debug this issue? It's been over a week and I need it working as soon as possible or else I have to return the whole kit. As for the camera defect possibility suggested by a user in this forum last week, I already tried swapping the camera and it still doesn't work.
          @Moderator
          @Wesley-Gunawan It looks like you are using a C08 config. https://docs.modalai.com/voxl2-camera-configs/#c8---hires-only
          Have you tried voxl-configure-cameras 8 ?
          voxl-camera-server documentation for troubleshooting recommends running voxl-camera-server -d0. Can you try that and paste the output?
            Wesley Gunawan
            @Moderator It is camera configuration 8, the board wouldn't detect the camera otherwise (tried that before) so I'm assuming the camera configuration is correct.
            voxl2:~$ voxl-camera-server -d0
            detected system image 1.7.8
            using new imx412 defaults
            configuration for 1 cameras:
            cam #0
            sensor type: imx412
            isEnabled: 1
            camId: 0
            camId2: -1
            fps: 30
            en_rotate: 0
            en_rotate2: 0
            en_preview:          0
            pre_width:           640
            pre_height:          480
            en_raw_preview:      0
            en_small_video:      1
            small_video_width:   1024
            small_video_height:  768
            en_large_video:      1
            large_video_width:   3840
            large_video_height:  2160
            en_snapshot:         1
            snap_width:          3840
            snap_height:         2160
            exif_focal_length:   0.000000
            exif_focal_len_35mm_format:0
            exif_fnumber:        0.000000
            ae_mode:             isp
            msv_exposure_min_us: 20
            msv_exposure_max_us: 33000
            standby_enabled:     0
            decimator:           1
            independent_exposure:0
            fsync_en: 0
            fsync_gpio: 109
            DEBUG: Attempting to open the hal module
            DEBUG: SUCCESS: Camera module opened on attempt 0
            DEBUG: ----------- Number of cameras: 1
            VERBOSE: cci-direct: using voxl_platform_mod config 0 layout
            DEBUG: Cam idx: 0, Cam slot: 2, Slave Address: 0x0034, Sensor Id: 0x0577
            connected to mavlink pipe
            DEBUG: ------ voxl-camera-server: Starting 1 cameras
            Starting Camera: hires (id #0)
            DEBUG: Checking Gain limits for Camera: hires
            DEBUG: Using gain limits min: 100 max: 1600
            DEBUG: cam ID 0 checking for fmt: 35 w: 1024 h: 768 o: 0
            DEBUG: ==> option 0: format= 34 width=4056 height=3040 is_input=0
            DEBUG: ==> option 4: format= 34 width=4056 height=3040 is_input=1
            DEBUG: ==> option 8: format= 35 width=4056 height=3040 is_input=0
            DEBUG: ==> option 12: format= 35 width=4056 height=3040 is_input=1
            DEBUG: ==> option 16: format= 33 width=4056 height=3040 is_input=0
            DEBUG: ==> option 20: format= 34 width=4000 height=3000 is_input=0
            DEBUG: ==> option 24: format= 34 width=4000 height=3000 is_input=1
            DEBUG: ==> option 28: format= 35 width=4000 height=3000 is_input=0
            DEBUG: ==> option 32: format= 35 width=4000 height=3000 is_input=1
            DEBUG: ==> option 36: format= 33 width=4000 height=3000 is_input=0
            DEBUG: ==> option 40: format= 34 width=3840 height=2160 is_input=0
            DEBUG: ==> option 44: format= 34 width=3840 height=2160 is_input=1
            DEBUG: ==> option 48: format= 35 width=3840 height=2160 is_input=0
            DEBUG: ==> option 52: format= 35 width=3840 height=2160 is_input=1
            DEBUG: ==> option 56: format= 33 width=3840 height=2160 is_input=0
            DEBUG: ==> option 60: format= 34 width=3264 height=2448 is_input=0
            DEBUG: ==> option 64: format= 34 width=3264 height=2448 is_input=1
            DEBUG: ==> option 68: format= 35 width=3264 height=2448 is_input=0
            DEBUG: ==> option 72: format= 35 width=3264 height=2448 is_input=1
            DEBUG: ==> option 76: format= 33 width=3264 height=2448 is_input=0
            DEBUG: ==> option 80: format= 34 width=3200 height=2400 is_input=0
            DEBUG: ==> option 84: format= 34 width=3200 height=2400 is_input=1
            DEBUG: ==> option 88: format= 35 width=3200 height=2400 is_input=0
            DEBUG: ==> option 92: format= 35 width=3200 height=2400 is_input=1
            DEBUG: ==> option 96: format= 33 width=3200 height=2400 is_input=0
            DEBUG: ==> option 100: format= 34 width=2976 height=2976 is_input=0
            DEBUG: ==> option 104: format= 34 width=2976 height=2976 is_input=1
            DEBUG: ==> option 108: format= 35 width=2976 height=2976 is_input=0
            (Too much to show, at the end of the output):
            VERBOSE: Dumping GBM flags
            DEBUG: Found flag GBM_BO_USAGE_CPU_READ_QTI
            DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI
            DEBUG: Allocated BO with width=25054814 height=1 stride=25054814 aligned_w=25054814 aligned_h=1 size=25054814 flags=0x20003 format=GBM_FORMAT_BLOB fd=226 vaddr=0x7fe8aaae70
            DEBUG: Successfully set up pipeline for stream: SNAPSHOT
            DEBUG: Started Camera: hires
            ------ voxl-camera-server: Started 1 of 1 cameras
            VERBOSE: Entered thread: cam0-result(tid: 2676)
            VERBOSE: Entered thread: cam0-request(tid: 2675)
            VERBOSE: added request for small video stream
            VERBOSE: Sending request for frame 0 for camera hires for 1 streams
            VERBOSE: Received 0 buffers from camera hires, partial result:1
            VERBOSE: finished sending request for frame 0 for camera hires
            VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera hires
            VERBOSE: Sending request for frame 1 for camera hires for 1 streams
            VERBOSE: finished sending request for frame 1 for camera hires
            VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera hires
            VERBOSE: Sending request for frame 2 for camera hires for 1 streams
            VERBOSE: finished sending request for frame 2 for camera hires
            VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera hires
            VERBOSE: Sending request for frame 3 for camera hires for 1 streams
            VERBOSE: finished sending request for frame 3 for camera hires
            VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera hires
            VERBOSE: Sending request for frame 4 for camera hires for 1 streams
            VERBOSE: finished sending request for frame 4 for camera hires
            VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera hires
            VERBOSE: Sending request for frame 5 for camera hires for 1 streams
            VERBOSE: Received result from HAl3 for frame number 2
            DEBUG: Value of standby_active is: 0
            received SIGINT Ctrl-C
            ------ voxl-camera-server: Camera server is now stopping
            DEBUG: Stopping Camera: hires
            Killed
              cam #0
              sensor type: imx412
              isEnabled: 1
              camId: 0
              camId2: -1
              fps: 30
              en_rotate: 0
              en_rotate2: 0
              en_preview:          0
              pre_width:           640
              pre_height:          480
              en_raw_preview:      0
              en_small_video:      1
              en_large_video:      1
              en_snapshot:         1
              snap_width:          3840
              snap_height:         2160
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
              fsync_en: 0
              fsync_gpio: 109
              Killed
              @Wesley-Gunawan that looks like it's running properly. Can you open another terminal and run voxl-inspect-cam -a ?
                Wesley Gunawan
                @Moderator I already tried that in the past, even before I consulted this forum, the output has always been like thisScreenshot_20241025-132204.png
                  #15
                  @Wesley-Gunawan Can you please set and run inspect-cam again?
                  "en_preview": true,
                  "en_snapshot": false,
                    "en_preview": true,
                    Wesley Gunawan
                    @Moderator voxl-camera-server -d0
                    cam #0
                    sensor type: imx412
                    isEnabled: 1
                    camId: 0
                    camId2: -1
                    fps: 30
                    en_rotate: 0
                    en_rotate2: 0
                    en_preview:          1
                    pre_width:           640
                    pre_height:          480
                    en_raw_preview:      0
                    en_small_video:      1
                    en_large_video:      1
                    en_snapshot:         0
                    snap_width:          3840
                    snap_height:         2160
                    ae_mode:             isp
                    standby_enabled:     0
                    decimator:           1
                    fsync_en: 0
                    fsync_gpio: 109
                    (Too long, in the end):
                    VERBOSE: Entered thread: cam0-request(tid: 2735)
                    DEBUG: ------ Last request frame for hires: 0
                    VERBOSE: Leaving hires request thread
                    DEBUG: ------ Last hires result frame: -1
                    VERBOSE: Leaving hires result thread
                    DEBUG: ------ Last frame encoded: -1
                    DEBUG: OMX_EventCmdComplete
                    DEBUG: Deleting buffers for hires preview stream
                    DEBUG: Deleting buffers for hires small video stream
                    DEBUG: Deleting buffers for hires large video stream
                    DEBUG: Deleting buffers for hires snapshot stream
                    free(): invalid pointer
                    Aborted
                    voxl-inspect-cam -a output is the picture attached
                      cam #0
                      sensor type: imx412
                      isEnabled: 1
                      camId: 0
                      camId2: -1
                      fps: 30
                      en_rotate: 0
                      en_rotate2: 0
                      en_preview:          1
                      pre_width:           640
                      pre_height:          480
                      en_raw_preview:      0
                      en_small_video:      1
                      en_large_video:      1
                      en_snapshot:         0
                      snap_width:          3840
                      snap_height:         2160
                      ae_mode:             isp
                      standby_enabled:     0
                      decimator:           1
                      fsync_en: 0
                      fsync_gpio: 109
                      Aborted
                      @Wesley-Gunawan did voxl-inspect-cam show anything while voxl-camera-server was running? it looks like you restarted voxl-camera-server while voxl-inspect-cam was running.
                      I think the proper steps are:
                      1. update config (done)
                      2. reboot VOXL 2
                      3. run voxl-inspect-cam -a
                        2. reboot VOXL 2
                        Wesley Gunawan
                        This is after power cycle (poweroff -f, power source off, turn on again)
