  3. Starling Position and Manual Mode dysfunctional
starling
20 Posts 3 Posters 3.8k Views 1 Watching
    @ijones2 Can you attach a log from the manual mode flight? (Perhaps with the messed up propellers so that you don't break the new ones)
    ijones2I Offline
    ijones2I Offline
    ijones2
    Hey!
    Here is the flight log in manual mode. I also uploaded the videos of the drone in Manual mode they are really short simply because it would flip violently then I had to stop it really quickly. Also on the last attempt at the drone in manual it flipped then 2 of the propellers snapped off. So I have to change those along with the torn one. I hope this helps!
    • ijones2I ijones2
      Hey!
      @ijones2 It's best to get manual mode working well before trying any of the more advanced flight modes such as VIO position hold. The log shows that after you arm with the left stick down and toward the center in manual mode the stick goes back to center position. You need to keep the throttle all the way down and then slowly increase to takeoff. Also, for testing in manual mode, try changing the parameter EKF2_EV_CTRL to 0 in case bad VIO data is corrupting the state estimation.
      ijones2I 1 Reply Last reply
      • ijones2I ijones2
        Hey!
        @ijones2 But the log also shows RPM being commanded to 10K even when the throttle is all the way down so that is confusing. We're still investigating.
        • ijones2I ijones2
          My name is Ivy and I am using the Starling drone for research at my university. So, whenever I would arm it in position mode, it would immediately take off and hover 2 inches above the ground-would not get any higher than that-and hover to the left and would not receive any input from the commando 8 controller. Then, if you put it in manual mode and arm the drone, it would rise 2 inches off the ground and do an aggressive flip and crash-again not receiving any input from the controller. I recalibrated the drone through QGC and recalibrated the commando 8 controller and it would still veer to the left. Before, it worked as normal where you arm it and just the propellers would spin and received input from the controller. Before I flew the drone I looked for physical damage to the propellers or motors and there was not any. During the flights where it kept flipping I was checking the propellers and it was fine. Then after many flips and crashes one of the propellers tore a little bit on the front right motor. But the drone was veering to the left and flipping way before the propeller tore. I honestly have no clue how to fix the reason its veering to the left and immediately taking off when armed. I ordered new propellers but I don't think that is the solution for what's going on any help would be great!
          Ivy ❤
          Here is the tear in the front right propeller
          Here is the left side of the drone
          @ijones2 said in Starling Position and Manual Mode dysfunctional:
          So the drone did work as expected in the past? Was there anything obvious that happened before it stopped working? Does it have the same SDK installed that it was shipped with or has that been changed?
            ijones2I Offline
            ijones2I Offline
            ijones2
            @Eric-Katzfey said in Starling Position and Manual Mode dysfunctional:
            Yes but after arming the drone, the drone would no longer receive any input from the controller. That was what I was originally doing but once I and few of my other colleagues gave it try, moving the sticks in every direction, the drone was not responding. Even when we would try to unarm it right stick down the drone was not responding.
              ijones2I Offline
              ijones2I Offline
              ijones2
              Yes the drone operated normal. I got to a point where I would arm it in position mode have it hover 7 feet, and then perform figure eights. In practicing landing it would the floor but the floor in my lab is foam matting which is better than hitting the concrete. To be honest it has 2 or 3 rough landings but after checking after each landing, I nor my colleagues inspected any physical damage. The SDK has been updated 1.3.3. it originally had 1.1.3. I think until I updated it last month.
              • ijones2I ijones2
                @ijones2 Did you have any good flights after updating to 1.3.3?
                  ijones2I Offline
                  ijones2I Offline
                  ijones2
                  Yes!
                  I had several good flights with 1.3.3. I also had good flights with 1.1.3 as well.
                  • ijones2I ijones2
                    Yes!
                    @ijones2 Might be worth a try then to do a fresh installation of 1.3.3 and see if that helps. Perhaps a file got corrupted somewhere and a fresh installation will clear it out. Can you also inspect the motors carefully? It's possible some debris got into one of them and it's causing it to occasionally get hung up. Really not sure what's going on but I think the fresh installation of 1.3.3 would be a good start.
                      ijones2I Offline
                      ijones2I Offline
                      ijones2
                      Ok! Will do? How might I go about a fresh installation on a package I already have?
                      • Zachary Lowell 0Z Offline
                        Zachary Lowell 0
                        @ijones2 you can download the most recent SDK from the following: https://developer.modalai.com/
                        Download the voxl2 most recent SDK and then untar the .gz file and open up a terminal, cd into the untarred directory and run the ./install.sh script - this will prompt you to wipe the voxl2 and upgrade the SDK and give you the abiltiy to assign it the necessary parameters for the starling!
                        ijones2I 2 Replies Last reply
                          ijones2I Offline
                          ijones2I Offline
                          ijones2
                          @Zachary-Lowell-0
                          Awesome! Thank you! I will do that then!
                            ijones2I Offline
                            ijones2I Offline
                            ijones2
                            @Zachary-Lowell-0 @Eric-Katzfey
                            Hello!
                            So I have updated the starling to VOXL Suite 1.3.5. However when it was done updating it said:
                            "FAILED TO EXECUTE THE FOLLOWING STEPS: VOXL-CONFIGURE-CAMERAS 6"
                            Which I temporarily ignored until I checked the web portal camera, the qvio overlay was blank and it was the only option that showed up. The feed said "ERR: CAM_MISSING_STALLED". Also, in QGC it said
                            "SWITCHING TO POSITION CONTROL IS CURRENTLY NOT POSSIBLE. NO VALID LOCAL POSITION ESTIMATE."
                            The drone flew fine in manual mode, but its not arming in position mode. How can I fix this?
                              Zachary Lowell 0
                              Sounds like the cameras were not configured properly - @ijones2 can you run voxl-configure-cameras hit enter and select the option that matches your sensors and locations for mipi placement.
                              Also once this is done what is outputted when you run voxl-camera-server directly from the command line?
                                ijones2I Offline
                                ijones2I Offline
                                ijones2
                                wrote on last edited by ijones2
                                #18
                                So i went into the voxl-configure-cameras and saw the list:
                                • 26 - M0173 with Tof imx412 and dual AR0144
                                • 27 - M0173 with Tof imx412 and triple AR0144
                                • 28 - M0173 with Dual IMX412 and Dual AR0144
                                • 29 - M0173 with TOF dual IMX412 and Dual AR0144
                                • 30 - M0173 with Dual TOF DUAL IMX412 and dual AR0144
                                • 36 - M0173 with imx412 and dual AR0144
                                • 37 - M0173 with Tof imx412, dual AR0144, and boson
                                • c - use user defined custom camera config in
                                • q - quit
                                I selected 26 and 27 then ran voxl-camera-server and it said "ERROR: Found zero cameras connected, need at least one" after each selection.
                                hmmmm I'm a little lost now
                                  Zachary Lowell 0
                                  @ijones2 if you check the belly of the voxl2 you will be able to tell if the M0173 is connected into the voxl2 base (which based off your photos above I do not believe it is) - this is the m0173(https://www.modalai.com/products/m0173?variant=48528274391344) - if you do not have that base board, then you have selected the wrong option. It might be easier to do a custom camera config - if you run voxl-configure-cameras C and then it will spit out that you need ot fill out a custom file, you can the use vim or nano to open the custom_camera_config.txt file in /data/modalai/ and then populate the J6,J7,J8 MIPIS with your camear setup and then run voxl-configure-cameras C again.
                                  Otherwise if this is too complicated, you can also just select the version of voxl-configure-cameras that isnt 26/27 since it seems like you are not using the M0173 adapter as well.
                                    ijones2I Offline
                                    ijones2I Offline
                                    ijones2
                                    @Zachary-Lowell-0
                                    Hello! I was able to reinstall 1.3.5 and that somehow fixed it! I am not going to question it lol.
                                    Now I'm trying to find out how to install voxl-mapper and I can't find documentation for it. I am flying the drone inside a test lab. Today when I was flying it around the room, the drone was not mapping anything. The 2D/3D map was blank when I went to plan a point. I think it's blank because I am missing voxl-mapper especially since I have camera-server, vision hub, voxl-px4 and qvio enabled/running. All I have seen is that I have to change "offboard_mode": "trajectory", in order to plan a point on the map and have the drone fly to it.
                                    Is there any documentation on getting voxl-mapper and planning a point?
