  3. Need help simulating .tflite yolo models on my linux machine.
57 Posts 2 Posters 36.4k Views 1 Watching
  • Ajay BidyarthyA Ajay Bidyarthy
    @thomas
    Okay, So i did run voxl-tflite-server -t alongside voxl-replay command but am still not getting anything.
    For yolov5 I get no output after running voxl replay. it just outputs this:
    For my custom yolov7 nd yolov8 I get these errors:
    I even referred to this thread https://forum.modalai.com/topic/2997/can-anyone-recommend-a-tflite-colab-notebook-for-voxl2-training/3
    and configured the main.cpp file by adding if else statement for custom model to use YOLO model instead of OBJECT_DETECTION as the default one before even running the above commands.
    I'm not sure why am I still not getting any output.
    @Ajay-Bidyarthy I'll look into it today.
    Thomas
    ? 1 Reply Last reply
    • ? A Former User
      Thomas
      @thomas @Ajay-Bidyarthy
      Sadly I won't have time to look at this today and am out of office tomorrow so I can't fully debug this for you. Let's focus just on YOLOv5 right now since that's the one we have onboard by default and it isn't segfaulting. Make sure you're launching tflite-server in a terminal and then in a separate terminal running the voxl-replay command.
      I apologize for this, sorry I didn't have time for it today.
      Thomas
      Ajay BidyarthyA 1 Reply Last reply
      • ? A Former User
        Thomas
        Ajay BidyarthyA Offline
        Ajay Bidyarthy
        @thomas
        No worries. Ok, but even for yolov5 I've been running both voxl replay and tflite server commands in separate windows/terminals but still facing the issue.
        Let me know why is it so and how can we resolve this.
          @thomas
          @Ajay-Bidyarthy
          Hey Ajay, working on it right now. Will let you know when I have an update.
          Thomas
          • ? A Former User
            @Ajay-Bidyarthy
            Thomas
            Okay so I've identified a problem in our timing code and am working on a fix. Here's a short-term solution for you:
            1. Make sure /etc/modalai/voxl-tflite-server.conf has "input_pipe" set to "/run/mpa/tracking"
            2. Get your VOXL's IP address with voxl-my-ip and enter this IP into your web browser to pull up voxl-portal in your browser.
            3. Run voxl-tflite-server on VOXL
            4. Run your voxl-logger log as voxl-logger -p /data/voxl-logger/log0009/ or whatever the path is saved as
            Now in your web browser, from the "Cameras" dropdown click tflite. You may need to refresh the page to get this to pop up. The permalink to this page is <YOUR IP>/video.html?cam=tflite (e.g. http://192.168.0.198/video.html?cam=tflite) so you can optionally just go there. This overlay shows the ML model running and in the upper left of the frame shows a framerate. You can use this to estimate for the time being.
            Am working on the fix now, will let you know when it's released.
            Thomas
            ? 2 Replies Last reply
            • ? A Former User
              Thomas
              Okay, I've pushed up a change for our nightly builds to fix the timing printouts with the -t option. So starting tomorrow you can flash the latest nightly SDK build and have this fix. If you'd like it today let me know and I can push the .deb up to Google Drive so you can flash it directly. Here is the link for the nightly SDK builds.
              Thomas
              • ? A Former User
                Thomas
                Ajay Bidyarthy
                @thomas
                Thanks for this info. So I have tried accessing the portal by running the voxl-my-ip command but found nothing getting printed out when I run that command. I inspected to make sure my voxl-portal service is running perfectly but still cant seem to get the ip for portal.
                Also, can you push the latest SDK as well or share the deb with me.
                99a97d0c-8d77-41b3-9de3-e95e59c78cf6-WhatsApp Image 2024-04-09 at 10.46.27 AM.jpeg file:///home/bhavya/Downloads/WhatsApp%20Image%202024-04-09%20at%2010.46.27%20AM.jpeg
                  @thomas
                  @Ajay-Bidyarthy
                  Make sure you set up WiFi on VOXL! Here's the guide: https://docs.modalai.com/voxl-2-wifi-setup/
                  Thomas
                  • ? A Former User
                    @Ajay-Bidyarthy
                    Thomas
                    Ajay Bidyarthy
                    @thomas
                    Hi thomas,
                    Could you please provide us the latest nightly sdk build for VOXL2 mini if you think we can work with that for now?
                    Regards,
                    OKSI Team
                      @thomas
                      Hi thomas,
                      Regards,
                      OKSI Team
                      @Ajay-Bidyarthy
                      https://console.cloud.google.com/storage/browser/_details/platform-nightlies/voxl2/voxl2_SDK_nightly_20240411.tar.gz;tab=live_object?organizationId=517175400245&project=modalai-core-services
                      Ajay BidyarthyA 2 Replies Last reply
                      • ? A Former User
                        @Ajay-Bidyarthy
                        Ajay Bidyarthy
                        @thomas
                        Hi thomas,
                        Is this package for voxl2min or voxl2?
                        Regards
                          @thomas
                          Hi thomas,
                          Regards
                          Ajay Bidyarthy
                          @thomas
                          Because I think this SDK is meant for M-0054 while our version is M0104. Let me know if we can go ahead and flash this SDK or not?
                          • ? A Former User
                            @Ajay-Bidyarthy
                            Ajay Bidyarthy
                            @thomas
                            Also, Now that I have flashed the SDK onto my chip its showing voxl2 in the shell screen instead of voxl2-mini. And even if I try and go ahead and do the following steps. I still cant get the desired output.
                            2ab88265-965c-4de3-a187-2ecc2d5f3cce-Screenshot from 2024-04-15 14-29-02.png
                            135af24f-36e9-44ce-b42e-5a6ac8041a2d-image.png file:///home/bhavya/Pictures/Screenshots/Screenshot%20from%202024-04-15%2014-29-02.png
                              @thomas
                              @Ajay-Bidyarthy
                              Oh my apologies, here's the link for VOXL2 Mini nightly SDK. I almost never work with these so apologies for the confusion
                              https://console.cloud.google.com/storage/browser/_details/platform-nightlies/voxl2-mini/voxl2-mini_SDK_nightly_20240412.tar.gz;tab=live_object?organizationId=517175400245&project=modalai-core-services
                              Thomas
                              • ? A Former User
                                @Ajay-Bidyarthy
                                Thomas
                                Ajay Bidyarthy
                                @thomas
                                Hey thomas,
                                So I tried with this new sdk. Unfortunately, I still dont see any output here as well
                                • ? A Former User
                                  Thomas
                                  Have you also tried using this method? Or were there issues getting WiFi setup?
                                  @thomas said in Need help simulating .tflite yolo models on my linux machine.:
                                  Thomas
                                  Yeah I'm really not sure what's going on here, on that nightly SDK voxl-tflite-server -t is printing out timing information. I don't have a VOXL2 Mini to test on so if it's a specific issue there I'm really not sure. Let me try some stuff today and I'll get back to you.
                                  Thomas
                                  • ? A Former User
                                    Thomas
                                    Thomas
                                    Ajay Bidyarthy
                                    @thomas
                                    Hi thomas,
                                    Yes so right now we tried figuring out if maybe the issue is with the model not being specific to voxl2mini or maybe the logs are generated based on voxl2. But I dont think thats the case.
                                    The thing which I'm concerned about is:
                                    1. How do we identify or pinpoint the problem ...like are we supposed to see the output after the 'Disconnected from camera server' line or before? And if we are supposed to see it and are not able to... then where exactly is the problem happening in the src/main.cpp file of voxl-tflite-server. Can we debug that somehow?
                                    2. Also did you check running the voxl-replay logger command directly without having any camera setup or camera-server configured.... similar to the way we are currently running on our end.
                                      @thomas
                                      Hi thomas,
                                      @Ajay-Bidyarthy
                                      If voxl-tflite-server was running into an actual error you'd see some sort of an error message printout. We typically debug issues through voxl-portal but if you aren't able to get WiFi set up you won't be able to do so. I again reflashed a nightly SDK to confirm things are working on my end and they are. To reconfirm:
                                      • Flash the latest SDK nightly from the link shared above
                                      • Modify /etc/modalai/voxl-tflite-server.conf to have /run/mpa/tracking as its input. This file gets overwritten on flash so make sure you do this.
                                      • voxl-tflite-server -t in one terminal
                                      • voxl-replay -p /data/voxl-logger/log0009/ in another
                                      I can tell you that replay doesn't care about camera server being configured, it should work regardless.
                                      -Thomas
                                      • ? A Former User
                                        @Ajay-Bidyarthy
                                        -Thomas
                                        Ajay Bidyarthy
                                        wrote on last edited by Ajay Bidyarthy
                                        #50
                                        @thomas
                                        Hi thomas,
                                        So I followed just the 4 steps you shared and its working perfectly fine with the default models.
                                        9cde7d30-94c5-4b41-9fff-179560d17050-Screenshot from 2024-04-17 12-28-53.png
                                        But when i deploy my custom voxl-tflite-server deb package onto the chip it says warning downgrading from voxl-tflite-server 0.3.3 to 0.3.2. So maybe I feel the issue is with the deb package of voxl-tflite-server I'm building with my custom tflite models and building the package out of it and deploying.
                                        Maybe you can update the gitlab repo so that I can build my custom voxl-tflite-server deb package and deploy it.
                                        Let me know if you can do this.
                                        file:///home/bhavya/Pictures/Screenshots/Screenshot%20from%202024-04-17%2012-28-53.png
                                          @thomas
                                          Hi thomas,
                                          @Ajay-Bidyarthy
                                          Hey Ajay,
                                          The Gitlab repo for tflite server actually is updated, just only for the dev branch. We're not quite ready to merge this to master yet. So you can just switch to that branch and branch your changes off of that and you should be fine.
                                          Thomas
