  3. No Depth Data
No Depth Data
2 Posts 1 Posters 611 Views
  • ggiacaloneG Offline
    ggiacaloneG Offline
    ggiacalone
    Hello, I am struggling to access pointcloud data from my newly purchased Sentinel Developer Drone.
    If I go to the Voxl Web Portal and go to pointclouds -> voa_pc_out I see nothing.
    cd34e5b9-0dd3-4802-8ce4-00196a79fc28-Screenshot from 2024-04-02 10-47-14.png /home/speeep/Pictures/Screenshots/Screenshot from 2024-04-02 10-47-14.png
    Same with going to Mapper. Also blank.
    f3fa17cd-d744-403f-88e2-07e343deae54-Screenshot from 2024-04-02 10-48-09.png /home/speeep/Pictures/Screenshots/Screenshot from 2024-04-02 10-48-09.png
    If I ssh into the VOXL2 and run voxl-inspect-points tof_pc I will simply see "waiting for server at /run/mpa/tof_pc/".
    If I do a voxl-inspect-services I see
    2dd14560-1f45-4ae9-861e-5078d55f7d77-Screenshot from 2024-04-02 10-53-36.png file:///home/speeep/Pictures/Screenshots/Screenshot%20from%202024-04-02%2010-53-36.png
    When I run roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch and I try to run a rostopic hz /voa_pc_out it says "Interface voa_pc_out now publishing" but in the terminal when I ran the rostopic hz I see subscribed to [/voa_pc_out] and then "no new messages" printed again and again.
    Do I just need to start a service or something to get pointcloud data?
    It was my understanding that the sentinel drone should be able to produce pointcloud data to ros for mapping or at least be viewable from the Voxl portal so maybe I'm just missing something simple.
    Thanks in advance!
      ggiacaloneG Offline
      ggiacalone
      NEVERMIND! I resolved the issue. Just had to do a systemctl enable voxl-dfs-server and then powercycle the drone. Hope this helps anyone in the future.
