Need help simulating .tflite yolo models on my linux machine.
Here's the docs section on custom models, give it a try and let me know how I can help.
https://docs.modalai.com/voxl-tflite-server/#custom-models
Thomas
@thomas
Thanks for this,
If you dont mind can we connect personally for few minutes? Also I wanted to ask that will we be able to simulate and benhcmark the yolo models without having camera sensor attached to the chip? If needed is there any way to test it using my macbook's camera?Regards
@thomas
Thanks for this,
You actually may be able to benchmark voxl-tflite-server without an image sensor attached. The way we do this is with a tool called voxl-logger which lets us fully capture the inputs from the all the pipes over a given time period. If you had a log created by voxl-logger, you could then use voxl-replay to replay the log and then measure the performance of voxl-tflite-server over that interval. It would be much easier to simply use you VOXL with an image sensor though. If you want to go down the logger path, though, I can try to get a log together for you that you can replay. You definitely cannot test it with your Macbook camera.
Thomas -
@thomas
Yes, thanks fro this,
I would appreicate if you can share the voxl-logger tool usage. Because right now when I just launch the tflite server by doing the configuration with my custom tflite model. it just says=================================================================
skip_n_frames: 0model: /usr/bin/dnn/yolov8n_model.tflite
input_pipe: /run/mpa/tracking/
delegate: gpu
allow_multiple: false
output_pipe_prefix: mobilenet
existing instance of voxl-tflite-server found, attempting to stop it
WARNING: Unknown model type provided! Defaulting post-process to object detection.
INFO: Created TensorFlow Lite delegate for GPU.
INFO: Initialized OpenCL-based API.
INFO: Created 1 GPU delegate kernels.------VOXL TFLite Server------
Camera processing thread is now locked to the following cores: 4 5 6
And nothing afterwards. so i believe its running but I actually want to see the numbers. or the benchmark performances of the model. How do I do that.
Thanks a lot again,
Bhavya -
@thomas
delegate: gpu
Thanks a lot again,
BhavyaWith all services on VOXL you should always run with the
-hoption if you're curious for more information on ways to use the service. In the case ofvoxl-tflite-server, we have both debug and timing options that can be specified to see printed outputs or timing benchmarks respectively.Thomas
@thomas
Hi thomas,
Okay, so I actually did do those steps. And using that info I got to know that to benchmark the model I need to runvoxl-tflite-server
and then in another terminal I did:
voxl-logger -i imu1 -s 5000 --note "primary imu test"
but then i get this error:
@thomas
Hi thomas,
Really strange that you don't have the
/data/modalai/dir as that's where we store thesku.txtand other important info. Maybe try calibrating the IMU?https://docs.modalai.com/calibrate-imu/
Thomas
Thomas
@thomas
Yes, so we have the directory present, but it only has the sku.txt file there. I think its because of some .yml file being missing we get error. So what should we do to load that file successfully in the dir -
@thomas
@thomas
Hi thomas,
So I did try calibrating the imu sensor using voxl-calibrate-imu. But I still dont see the .yml file in the data/modalai directory.
So I'll just share the brief overview on what steps I followed to get to the current point:- I connected VOXL (with only the default sensors, I did not attach any sensor seperately) to my computer.
- I created a deb package to deploy to VOXL by loading my custom tflite files in the misc_files/usr/bin/dnn directory of the voxl-tflite-server with correspodning changs in the voxl-configure-tflite file present in the scripts/ qrb5165 folder. And then following the build and deploy commands to deploy the package to voxl
- I then did adb shell to load into my VOXL and do see all the tflite files present there. I then ran voxl-configure-tflite command to load my custom tflite model.
- Following that I simply executed voxl-tflite-server command
- In another similar terminal I then tried benchmarking by doing voxl-logger command as shown and am now getting the error.
file:///home/bhavya/Downloads/screen1.jpeg
file:///home/bhavya/Downloads/screen2.jpegThanks
@thomas
Hi thomas,
Okay yeah I think I figured it out. Take a look at these lines from the
voxl-loggercode:
You can see that
voxl-loggeris just trying to copy over anything that matches *.yml . So while I work on a fix for this, could you just do inside your VOXLtouch /data/modalai/something.yml. ? This should remove that error.Keep me posted,
Thomas -
voxl-loggercode:
You can see that
Thomas@thomas
I attempted to use the voxl-logger by creating an empty something.yml file in the directory and executing the command. Despite encountering no errors during the execution, I did not receive any output beyond the line "connected to imu 0 sensor." My goal is to obtain benchmarking output similar to the tables shown in the ModalAI documentation: Benchmarks Documentation.Could you kindly assist with this issue? I believe it would be more efficient if we could schedule a time for a discussion when you are available. This would allow us to address any questions or concerns promptly without the need for multiple back-and-forth messages.
Thank you for your time and assistance.
voxl-loggercode:
You can see that
Thomas@thomas
Hi thomas,
Did you get a chance to check this issue? I am trying to benchmark the my models but I dont see any output or number I could use to summarize my benchmark or something. -
@thomas
Hi thomas,
Did you get a chance to check this issue? I am trying to benchmark the my models but I dont see any output or number I could use to summarize my benchmark or something.Yeah so when you run voxl-logger with -s 5000 you're running it for that many samples and it isn't going to have any printouts. I'm not sure what tables you're talking about with respect to the benchmarks documentation, maybe you could give me a link?
If you just want to collect a voxl-logger log, your commands above should work fine. You can see that it's creating logs in the /data/voxl-logger/ directory which you can replay with the voxl-logger command.
I help with the forum in addition to my work and so I don't have time for calls. If you're interested in setting up a bigger support effort, you can send an email to sales@modalai.com .
Hope this helps!
Thomas
Hope this helps!
Thomas
@thomas
Hi thomas,
Yes, so the table I'm referring to is under the benchmark section here: https://docs.modalai.com/voxl-tflite-server-0_9/#benchmarks
So the thing is when I run the voxl-looger with -s 5000 I also expect the code to run for that many samples and output some log, but as you see from my screenshot, it just outputs ... ' samples: 0'And no worries thomas, I do appreciate your time and help here
Regards
@thomas
Hi thomas,
Regards
Okay yeah let's back up here - why are we even trying to get a log with IMU samples in it? If you want to benchmark
voxl-tflite-server, you don't need IMU samples to do so. What I had meant by all of this was: you don't have a camera attached to your VOXL if I remember correctly and so instead of attaching one, we could use avoxl-loggerlog which had camera data in it for replaying. This is because when you replay avoxl-loggerlog, it writes over all of the pipes. If we had a log which had camera data in it, you could replay it and your VOXL would "think" it had a camera attached and so then when you runvoxl-tflite-serverit could use the data coming from those pipes.In this case, I probably need to provide you with a log that has camera data in it. No worries though, I have lots of logs and can upload one here. Do you have any preferences of what's in the log? I was just going to take my drone and wave it around for a few seconds but if you'd like something more we can do that. I'll also verify that this log can be used by tflite-server and what steps need to be taken.
If that seems reasonable let me know and I'll get started.
-Thomas
-Thomas
@thomas
Oh I understand now. So using your camera data voxl logs. We can simly use those logs(camera data) to benchmark tfliteserver and get the benchmark stats like shown here:
https://docs.modalai.com/voxl-tflite-server-0_9/#benchmarksI would appreciate a lot if you could share them. Since it would be good to use those logs/same camera data to compare stats from diff custom tflite models
Thanks a lot
@thomas
Thanks a lot
Yep exactly! Let me get working on a log right now for you to use and then I'll upload it here and give you instructions on how to use it.
Thomas
Thomas
Here's a link to a .tar with a voxl-logger log that I recorded! https://drive.google.com/file/d/1c-snBLT6mmrwGpKE2WhVR-YQgumN0s6o/view?usp=sharing
You should use ADB to push this file onto VOXL and then use
tar -xvf customlog.tarto unzip the file, it should unpack into/data/voxl-logger/log0009/. Then you should be able tovoxl-replay -p /data/voxl-logger/log0009/. The only other important thing you need to do is editvoxl-tflite-serverto predict from thetrackingcamera in/etc/modalai/voxl-tflite-server.conf.Thomas
@thomas
Hey thomas,
So I have followed your steps and loaded the log0009 data and then ran voxl-replay command while running voxl-tflite-server correctly configured with tracking option. But nothing happens after that it seems.
So the output I'm expecting at the end is to be able to have something like
Model Task Avg Cpu Inference(ms) Avg Gpu Inference(ms) Avg NNAPI Inference(ms) Max Frames Per Second(fps) Input Dimensions Source
custom-tflite-model Object Detection 33.89ms 24.68ms 34.42ms 34.86750349 [1,300,300,3]Where can I get such output after running the voxl-replay command. I think I'm missing some steps after that.
Please let me know what I'm missing here.
Thanks -
@thomas
Hey thomas,
ThanksYeah, so my default all of our services don't print anything out when run. Do
voxl-tflite-server -tfor timing printouts.This won't give you a super organized printout like what you are writing. But it will give you out data on the per-iteration callback times and the breakdown per function. You'll then need to modify
/etc/modalai/voxl-tflite-server.confin different ways to get different timing printouts in order to build up a table of benchmarks.Thomas
