Starling fan attachment and optimization
Also, it is very typical for software on drones to operate in "idle" mode while not flying to avoid overheating due to cpu load and lack of air flow from propellers. There is usually no need to run the full processing stack at max power while the drone is just sitting on the ground. And if you need to test on bench while not flying (during development), just use external fan.
@Alex-Kushleyev Ok I have tested it with a desktopfan it does make a dent in the rise in temperature, I still want to install the Voxl Fan on the drone before flying, I saw the drawings the hole near the J2 connector has 33.5 mm diameter. Is it safe to remove that bolt to install a flat head bolt and what size should it be in inches/mm?
@Darshit-Desai , do you mean the hole has 3.5mm (not 33.5 mm)?
i will check if we have a recommended screw for this.
The guidance regarding the fan connector J2 being close to the mounting hole on VOXL2 is the following:
we recommend plugging the fan connector into J2 prior to inserting the mounting screw into the VOXL2 mounting hole. After the fan has been connected to J2, the fan wire can be carefully manipulated around the mounting screw during the screw installation to avoid pinching of the wire. The thickness of the fan wire permits a tight bend. Please try it out!
@Alex-Kushleyev That worked after some effort,(almost broke the connector)
I seem to now have a good grasp because with the fan and the flight propellers running the temperatures seem to still reach 75 deg C and there is also throttling happening at some 100-500 millisecond differences, the only other way seems to be to cannibalise mpa-to-ros package and profile my own code
@Darshit-Desai 75C is normal, the CPU will not start throttling itself until about 95C.
If you look at output of
voxl-inspect-cpu
, it will tell you what frequency each core is running at. If you set the cpu into performance mode usingvoxl-set-cpu-mode perf
, all cores will be fixed to max frequency and will stay at max unless the temperature is too high (above 95C) and the thermal management will kick in.If CPU is in auto mode, the core frequencies will jump up and down depending on the required load.
@Alex-Kushleyev Yes I have been checking using that command. The fact is that the moment the core temperatures hit more then 75C the position mode starts to turn off automatically showing it isn't ready to fly even when the starling is in flight, this also gives the rest of the algorithm a throttling effect like the ros messages which are delivered to the algorithm are slower
@Alex-Kushleyev Here are some screenshots of the QGC, CPU Monitor and my code running in parallel in the terminal,
The following services were running:
1)Modified MPAtoROS launch node, with topics like /tof_pc, /voa_pc and /tflite_data only being published
2)Tflite server
3)Couple of ros nodes which use the data from above services to find the position of objects in the environmentFirst photo when my code starts up and the cpu core temperature is low:
https://drive.google.com/file/d/1AS1crU9FcIAUmhwG3nD1MG9CElVbwTiu/view?usp=sharingSecond screenshot is when the core temperature crosses >70 deg C, note how the position mode turns to red showing not ready
https://drive.google.com/file/d/1fzKAZKkbLDWjiuCCvKxyHo7UnE8GWeNK/view?usp=sharingThird screenshot: Here I found a peculiar warning which was not being sent to QGC in the voxl portal where it showed high accelerometer bias warning? Could that be the cause, can higher CPU core temperature cause that?
https://drive.google.com/file/d/1E8s7nQja1ijlcgFzkGI80TtRCWk703D7/view?usp=sharingThis led me to believe that my fan placement might be wrong so I am putting a photo of my starling drone with the fan placement, Is it correct or am I facing some other issues?
Here are the photos of the fan on the starling drone:
https://drive.google.com/file/d/1ApMiFDQItF9ZbxI8yD-_GXnhKaqCu3yo/view?usp=sharing,
https://drive.google.com/file/d/1Axz_itT0f9L1AVpDvHCaoIwfVr3JRWFt/view?usp=sharing,
https://drive.google.com/file/d/1B0UbtqbfJIjkOFo1PaPIW3eRHECIo5d1/view?usp=sharing,
https://drive.google.com/file/d/1B141Pc6Q6DCoFynJykV3PbuiFIsjCvco/view?usp=sharing -
Please avoid mounting the cpu fan in a way that adds stress to the board. In your particular case, it seems the fan is wedged between the wifi dongle and the actual CPU, which will actually put pressure and can bend the board. IMU is very sensitive to stresses inside the PCB and slight bending can affect the IMU bias. Additionally, direct contact of the fan to the VOXL2 PCB can add some small vibrations (which can potentially throw off any detector in PX4 that is looking for a perfectly still IMU for initialization).
To confirm the IMU bias issue, you can inspect the IMU data using QGC (mavlink inspector) and see if the XYZ accelerometer (while sitting still) changes significantly as the board warms up. Then you can remove the wedged fan (and hold it close to the board) and test again and see if the unusual accel bias is gone (when warmed up).
My strong recommendation is to remove the fan from its current location. You may want to design + 3D print an plastic mount, perhaps integrated with the GPS mount, but also having extra attachment points so that it does not oscillate / vibrate due to being cantilevered. If you want to go that route, i can see if we can share the GPS mount CAD file with you.
@Alex-Kushleyev said in Starling fan attachment and optimization:
Which parameter would it be? Position NED?
@Alex-Kushleyev Also I have consistently observed that cpu0-cpu3 have 1.8-2.0 GHz frequency and on an average 45-65% utilization even when the ros nodes are not running while, cpu7 when the ros nodes are running has 1.9-2.8 Ghz average frequency with 70-85% utilization while cpu4-6 are relatively lighter with only 0.6-0.7 Ghz frequency and ~20% utilization at maximum even when I run my complete code stack, is there a specific reason for such a scenario?
@Alex-Kushleyev I tried this recommendation by removing the fan and holding it up and running my code it didn't make any difference as soon as the temperatures go above 75 the accelerometer bias flag is active. Also I don't think fan placement is an issue because the fan is placed right above the heat sink of the cpus and not anywhere near the imus, there is sufficient space between the wifi dongle and the board to move around a little.
The bias issues only come when I run the object detection and my own sensor fusion module, without that code running and the fan installed the drone is able to fly in position mode. This is more of a cpu heating and load distribution issue, somehow I think cpu0-3 are pinned for some MPA services and pipes and the rest of the 4 cpus are not being utilized equally, I am looking into multi threading for load distribution in my code, let me know if there are any more recommendations
@Darshit-Desai , it is not a good idea to have any external components touching any components of the VOXL2 board. The reason is that if there is even a minor crash, the movement of the external components (fan in this case), can put mechanical stress on the processor itself and cause internal damage.
There are some exceptions, such as if you put VOXL2 inside a metal enclosure, you could have a metal heatsink make contact with the cpu or something like that. In your case, the fan is touching the CPU and the wifi dongle, which puts mechanical constraints such that if there is impact, the fan can be jammed between the cpu and wifi dongle, potentially causing damage to VOXL2 components.
Here is how a fan was integrated into VOXL1/2 flight deck:
- https://www.modalai.com/products/voxl-flight-deck
- https://www.modalai.com/products/voxl-2-flight-deck
Although it is harder to see it on voxl2 flight dec, but voxl1 flight deck pictures clearly show a FR4 material that is used to separate the fan from main board and is also used for mounting.
Back to the accelerometer, you can use the following command to print out the raw accel data:
px4-listener sensor_accel TOPIC: sensor_accel sensor_accel timestamp: 306076285 (0.437680 seconds ago) timestamp_sample: 306076069 (216 us before timestamp) device_id: 2490378 (Type: 0x26, SPI:1 (0x00)) x: -0.27078 y: 7.87261 z: 5.88561 temperature: 24.30556 error_count: 1 clip_counter: [0, 0, 0] samples: 10
So you should make sure the board is level and check this message periodically as you are running processing as the board heats up. (in my case the board is not flat, so you are not seeing (0,0,9.8). I am curious what the accel reading is at the start and then when you get the accel bias warning.
Worth taking a look at px4 imu calibration. I have not done this myself, but it looks like this is the right resource : https://docs.px4.io/main/en/advanced_config/sensor_thermal_calibration.html
Regarding CPU frequencies, when cpu governor is in auto mode, it will try to scale down cpu frequencies to save power. but if you want maximum performance, you can set to to performance mode:
Note that this does not persist after reboot, if you want permanent change, you can change
more /etc/modalai/voxl-cpu-monitor.conf
and set normal cpu mode toperf
Note that this does not persist after reboot, if you want permanent change, you can change more /etc/modalai/voxl-cpu-monitor.conf and set normal cpu mode to perf
This is definitely useful, but is it right that cpu0-3 are pinned for MPA services, if that is the case I can explicitly assign cpu's for my ros nodes to run cpu 4-7?
@Darshit-Desai I do not think that cpu0-3 are pinned for MPA services. The cpu governor typically assigns task to slower cores when possible (0-3 are slowest, 4-6 are medium, and core 7 is the fastest one) in auto / powersave mode. In performance mode, the distribution of load will probably look different.
max frequencies for the cores:
0-3: 1800Mhz
4-6: 2420Mhz
7: 2840Mhz -
Hi @Alex-Kushleyev, I wanted to ask one more question regarding cpu utilization while running the tflite server. It shows that it uses cores 4, 5 and 6 for processing and connects itself to the camera server. What is the tflite server using cpu for? Publishing images to libmodal-pipe? like bbox drawn on images? What if I want to disable that and zero out any utilization of cpus by the tflite server?
By that I mean this line here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tflite-server/-/blob/master/src/main.cpp?ref_type=heads#L247
What else is the tflite server using on cpus which can be removed? As in my system I am only concerned with the bbox detection message.
Yeah, tflite-server uses the CPU to load in images, draw frames, and other things like the link you posted. If you want some part of tflite-server to run more efficiently, you should fork the repository and make changes. We have an in-depth README in the repository showing how to build and create a custom fork of tflite-server.
Let me know if you have any questions!
Thomas
@thomas Thank you, actually the purpose of the question was to identify all components which use CPU in the tflite server. So if it's just image publishing and drawing of bboxes or seg maps on images then I can just comment out the relevant function calls to publishing the image with bbox and the part where it actual makes an image with bbox and writes parameters on the image like fps and other details.
Is there any other part which is being done on the CPU other then the ones highlighted?
I mean, there's really only one line of tfliter-server that isn't on the CPU and it's this one which actually does the inference (assuming GPU or NPU delegate was selected). Everything else uses the CPU.
Thomas
