  3. motor not responding to throttle
17 Posts 3 Posters 2.6k Views 1 Watching
  • K kham
    @Moderatorthank you for the response, however as mentioned before I already followed the guide and both drones are already upgraded and running the latest version of the VOXL SDK released for the RB5 flight.
    @kham , can you please let us know which version of px4 you are using?
    voxl-version | grep voxl-px4
    Also in your plot above, i see the ESC reports temperatures as [0, 4300, 4200, 4300], for some reason the first ESC is not reporting temperature, there may be a configuration error of the ESC.
    Please try the following:
    #stop px4
    systemctl stop voxl-px4
    #scan for ESCs
    ./voxl-esc-scan.py
    And let me know what the ESC scan outputs. Thanks!
    K 1 Reply Last reply
      #stop px4
      #scan for ESCs
      ./voxl-esc-scan.py
      K Offline
      K Offline
      kham
      @Alex-Kushleyev Screenshot from 2024-03-14 14-01-56.png Screenshot from 2024-03-14 13-56-50.png
      I ran the scan and it seems that one of the ESC's is not appearing on the scan.
      • K kham
        @kham , yes i see and the results of the scan are consistent with the lack of status report in PX4 ESC status.
        Let's try two more things:
        • when you power on the vehicle / esc, do you see all 4 ESC channels flash the blue LEDs quickly for 1 second (that is bootloader) and then several slow flashes? Do the motor sounds all sound the same or is one of the ESCs sounds / flashes differently (the ID0)?
        • can you please try to do the same esc scan but use the latest voxl-esc tools from the dev branch : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/dev . the latest tools will scan all baud rates if not all of the ESCs are found. I wonder if the params are out of sync on the 4 ESC channels.
        If you do find the ESC0 is using a different baud rate, you can follow this procedure to bring the ESC to a good state with latest firmware : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/recovery.md
          K Offline
          K Offline
          kham
          @Alex-Kushleyev thank you for the response
          • When powering on the vehicle only 3 ESC channels flash blue and continuously maintain a fast flashing rate ( they do not flash slowly after the boot).
            As you can see , i ran the recent versions of the voxl-esc tools pulled from the gitlab repo and the scan remains the same as before.
          • K kham
            @kham,
            Please check your output, the git clone command did not work because the directory already existed. Also, you did not specify the branch name. Please do the clone in another location.
            The correct command is:
            git clone https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc.git -b dev
            #stop px4 and scan
            cd voxl-esc/voxl-esc-tools
            ./voxl-esc-scan.py
            (essentially, the first few steps of the document i referenced in my previous post: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/recovery.md)
            Now, you said that only three blue LEDs flash on the ESC - does the 4th blue LED every light up?
            Thank you
              @kham,
              #stop px4 and scan
              ./voxl-esc-scan.py
              Thank you
              K Offline
              K Offline
              kham
              @Alex-Kushleyev thank you for the clarification, i ran the code as instructed and the output is still consistent. Screenshot from 2024-03-19 14-54-31.png
              As for the blue LED's the forth one only flashes at the beginning for 1 second with the other LED's (when i plug-in the battery) after that they all turn off and then only 3 LED's continuously flash blue.
              Alex KushleyevA K 2 Replies Last reply
              • K kham
                @kham , thank you for the details.
                The fact that ESC ID0 also flashes at the beginning for 1 second and then the led turns off means that the bootloader starts up, runs for 1 second, verifies the firmware and start executing the firmware. So the last thing that could be wrong on ESC ID0 are the ESC params that have potentially got corrupted. I am not sure why the scan does not detect it though.
                Has the ESC worked fine in the past with all 4 channels working? Perhaps something happened during an SDK upgrade when ESC firmware and params were updated? (sometimes an error happens during this process, causing ESC params to fail to upload)
                Can you please try again and run this several times just to make sure.. forcing the baud rate to 57600 which is the fallback baud rate if the params on ESC are not valid (the baud rate is part of params, so if params are corrupt, ESC will default to 57600 baud rate).
                ./voxl-esc-scan.py --device /dev/slpi-uart-2 --baud-rate 57600
                you can also try forcing to install params this way:
                ./voxl-esc-upload-params.py --params-file <path_to_esc_params_file.xml> --device /dev/slpi-uart-2 --baud-rate 57600
                thank you
                • K kham
                  K Offline
                  K Offline
                  kham
                  @kham thank you for the reply, i ran the scan multiple times and was met with the same output. I ran the baud update but still got the same output. I tried to force install but it didn't work.Screenshot from 2024-03-19 16-10-40.png Screenshot from 2024-03-19 16-10-43.png
                  • K kham
                    @kham OK, thank you. can you please let me know if ID0 used to work (meaning, all 4 motors working / spinning) and something happened or it never worked on this ESC board?
                      K Offline
                      K Offline
                      kham
                        K Offline
                        K Offline
                        kham
                        @Alex-Kushleyev I was the first to use the drones after they were bought and after updating the drone and setting up the SDK the motor didn't work, so no there was no time were all the motors were working. Also we do not have a radio controller so all testing is done through Qgroundcontrol.
                        • K kham
                          #16
                          @kham , thank you for the information. Since the ESC originally cam in a drone, then it was originally working, so at least that is good.
                          Do you think you would be able to take a short video of the 4 blue LEDs on the ESC for several seconds after you apply the power to the ESC and until the LEDs just shut off. No need to run PX4.
                            If we are not able to resolve this soon, i would recommend replacing the ESC, you could then submit RMA form : https://www.modalai.com/pages/rma .
                            In majority of cases, the scanning script should find the ESC even if it is missing firmware or params, so I am slightly confused why this is happening. It could be a hardware issue on the ESC.
                            The ESC you have now is board version M0049, which is older than the current version of the ESC and is no longer in production. If you are going to request a replacement of the ESC, you will most likely receive M0134-1 which is just a newer revision (not really better or worse, the functionality is the same). https://www.modalai.com/products/voxl-esc
                            In order to rule our the RB5 UART issues, if you are open to continuing to debug, i would recommend making an adapter using a USB-to-serial adapter and Hirose DF13 6-pin connector, then you could use voxl-esc tools on a PC and there is more flexibility in debugging. Please let me know if you would like to explore this option.
