    no data while querying /run/mpa/tflight_data/request using Python
    2506
    • S
      sansoy
      I'm not getting any data or errors except for the one error when i restart voxl-tflight-server which seems logical.
      the metadata format is
      // struct containing all relevant metadata to a tflite object detection
      typedef struct ai_detection_t {
      uint32_t magic_number;
      int64_t timestamp_ns;
      uint32_t class_id;
      int32_t frame_id;
      char class_name[BUF_LEN];
      char cam[BUF_LEN];
      float class_confidence;
      float detection_confidence;
      float x_min;
      float y_min;
      float x_max;
      float y_max;
      } attribute((packed)) ai_detection_t;
      here's my code:
      import struct
      import os
      Define the format strings for the structures
      Note: This assumes a specific byte order, size, and alignment which might need adjustment
      object_detection_msg_format = 'qI64sfff4f'
      detections_array_format = 'i'
      Size of the object_detection_msg structure
      object_detection_msg_size = struct.calcsize(object_detection_msg_format)
      Function to unpack a single object_detection_msg
      def unpack_object_detection_msg(data):
      unpacked_data = struct.unpack(object_detection_msg_format, data)
      return {
      'timestamp_ns': unpacked_data[0],
      'class_id': unpacked_data[1],
      'class_name': unpacked_data[2].decode('utf-8').rstrip('\x00'),
      'class_confidence': unpacked_data[3],
      'detection_confidence': unpacked_data[4],
      'x_min': unpacked_data[5],
      'y_min': unpacked_data[6],
      'x_max': unpacked_data[7],
      'y_max': unpacked_data[8]
      Function to read and unpack the data from the pipe
      def read_detections(pipe_fd):
      # Read the number of detections
      num_detections_data = os.read(pipe_fd, struct.calcsize(detections_array_format))
      if len(num_detections_data) != struct.calcsize(detections_array_format):
          raise ValueError("Did not read the expected number of bytes for num_detections")
      num_detections = struct.unpack(detections_array_format, num_detections_data)[0]
      # Read and unpack each detection
      detections = []
      for _ in range(num_detections):
          detection_data = os.read(pipe_fd, object_detection_msg_size)
          detection = unpack_object_detection_msg(detection_data)
          detections.append(detection)
      return detections
      pipe = open('/run/mpa/tflite_data/request', 'rb')
      pipe_fd = pipe.fileno()
      try:
      detections = read_detections(pipe_fd)
      print(detections)
      finally:
      pipe.close()
      Any suggestions/solutions/help would be awesomely appreciated!
      • S
        sansoy @sansoy
        The following is a python script generated by bard.google.com which also runs but is not printing any data.
        import ctypes
        import os
        Define structures with packing
        class ObjectDetectionMsg(ctypes.Structure):
        fields = [
        ("timestamp_ns", ctypes.c_int64),
        ("class_id", ctypes.c_uint32),
        ("class_name", ctypes.c_char * 64),
        ("class_confidence", ctypes.c_float),
        ("detection_confidence", ctypes.c_float),
        ("x_min", ctypes.c_float),
        ("y_min", ctypes.c_float),
        ("x_max", ctypes.c_float),
        ("y_max", ctypes.c_float),
        pack = 1
        class DetectionsArray(ctypes.Structure):
        fields = [
        ("num_detections", ctypes.c_int32),
        ("detections", ObjectDetectionMsg * 64),
        pack = 1
        Open the pipe for reading
        pipe_path = "/run/mpa/tflite_data/request"
        pipe_fd = os.open(pipe_path, os.O_RDONLY)
        Read data continuously
        while True:
        # Read a detections_array structure from the pipe
        data = os.read(pipe_fd, ctypes.sizeof(DetectionsArray))
        # Parse the data into a DetectionsArray object
        detections_array = DetectionsArray.from_buffer_copy(data)
        # Process the detections
        for i in range(detections_array.num_detections):
            detection = detections_array.detections[i]
            # Access detection fields as needed, e.g.,
            print(f"Timestamp: {detection.timestamp_ns}")
            print(f"Class ID: {detection.class_id}")
            print(f"Class name: {detection.class_name.decode()}")
            print(f"Class confidence: {detection.class_confidence}")
            print(f"Detection confidence: {detection.detection_confidence}")
            print(f"Bounding box: ({detection.x_min}, {detection.y_min}) - ({detection.x_max}, {detection.y_max})")
        ? 1 Reply Last reply Reply Quote 0
          A Former User @sansoy
          @sansoy
          Hey, happy to try and help with this!
          I would really advise you to use libmodal-pipe which is a library we developed just for reading to and from pipes quickly, you can take a look at the documentation here and the source code here. I'm not an expert on the library but I believe it's needed in order to actually get data from a pipe. On a call to pipe_client_open(), the server pipe actually opens up a request to have data published as READONLY to the client pipe. This isn't to say the code you've written is wrong, but I do think you actually have to make this function call in order to "open up the pipe" and receive data on the other side.
          It would be most ideal to do all of your coding in C/C++ as this is what libmodal-pipe is written in. In that case, you could just open up a client pipe and on each callback have the function print out the detection data you're looking to print out. If you want to retain your Python script, though, you might write a very small helper script in C/C++ to open up that client pipe using libmodal-pipe and then use a a more general format or method to pass the data to your Python script.
          Hope this helps!!
          Thomas Patton
          thomas.patton@modalai.com
          S 2 Replies Last reply Reply Quote 0
          • S
            sansoy @Guest
            @thomas Thanks Thomas! will get back to you....i'm sure!!
            • S
              sansoy @Guest
              @thomas ok massive confusion.
              i was able to download the example hello scripts and compile them and they work fine.
              modal-hello-client.c
              modal-hello-pause.c
              modal-hello-server.c
              modal-hello-sink.c
              modal-kill-pipe.c
              modal-pipe-ping.c
              i then made copies of these and replaced hello with tflite_data and compiled successfuly
              however, i cant seem to tie into tflite_data.
              so when i'm running voxl-tflite-server two pipes show up, ie tflite and tflite_data
              Doesnt that mean these pipes open already?
              i tried my modal-tflite_data-client and got the following error
              channel 0 connected to server
              sending tflite_data to server control pipe
              failed to send control command to server
              ERROR: control pipe not available
              ERROR, pipe is not of type "text"
              closing
              i just want to get the box coordinates from the pipe. Help me Obi Wan Kenobi!
                @sansoy
                I appreciate that you think I've ascended to the Jedi level... I don't know if I agree but I'll keep trying to help you out!
                You're getting the error because of the line that has the pipe_is_type() function. That function is, for example purposes, checking that a pipe has type "text" which is the type the pipe is publishing in the example code.
                But you're modifying the example code to read from a different pipe and so the type might not be text. To check what type was being published to the pipe, I ran:
                voxl2:/$ cat /run/mpa/tflite_data/info
                	"name":	"tflite_data",
                	"location":	"/run/mpa/tflite_data/",
                	"type":	"ai_detection_t",
                	"server_name":	"voxl-tflite-server",
                	"size_bytes":	16384,
                	"server_pid":	2910
                Okay, so we can see here "type" : "ai_detection_t" which you may remember as the ai_detection_t struct from voxl-tflite-server. So instead, you need to modify that pipe_is_type() function to have it check for "ai_detection_t" instead of "text". You could, also, just delete the line as it's just a safety check. But better to be safe!!
                Now that should fix your immediate issue. The final piece of the puzzle, here, will be creating a callback function and registering your client to it. I'm not a libmodal-pipe expert but I think the way we do it in the example code will work for you. The simple callback that's defined there just passes raw bytes of data as a char* and so what I think you'll want to do is typecast that data to type ai_detection_t*. I'm going to double check this sometime today. But then you'll have a struct of type ai_detection_t and you can access the member variables to get what you're looking for. For right now, you should just copy-paste the ai_detection_t struct definition in your code so that your module will know what an ai_detection_t is. In the future we'll expose this header in /usr/include.
                Hope this helps!!
                Thomas Patton
                • S
                  sansoy @sansoy
                  @sansoy so i updated my copy named modal-tflite_data-client.c with fields listed in tflite_data/info
                  "server_pid": 25994
                  Recompiled the script and ran
                  voxl2:/run/mpa/tflite_data$ modal-tflite_data-client
                  but when i put a picture in front of it and the object detection is working i'm getting!
                  received 172 bytes on channel 0: LXOV��O6
                  received 172 bytes on channel 0: LXOV��F[6
                  received 172 bytes on channel 0: LXOV7?_�6
                  received 172 bytes on channel 0: LXOV! ��6
                  ���6
                  received 172 bytes on channel 0: LXOV����6
                    @sansoy
                    Sweet, you should be able then to cast the char* data coming into your callback function into type ai_detection_t* and then access the member variables for x/y min/max for the boxes.
                    Thomas Patton
                    S 3 Replies Last reply Reply Quote 0
                    • S
                      sansoy @Guest
                      @thomas so i included ai_detection.h and cast the char* data variable and compiled successfully and several of my services died ...lol
                      modallink-relink | Disabled | Not Running |
                      voxl-camera-server | Enabled | Not Running |
                      voxl-cpu-monitor | Enabled | Not Running |
                      voxl-feature-tracker | Disabled | Not Running |
                      voxl-flow-server | Disabled | Not Running |
                      I've tried everything to restart both camera server and cpu monitor and no luck. Rebooted, Cycled Power,
                      Any thoughts on how to recover from this?
                      • S
                        sansoy @Guest
                        @thomas from my syslog
                        Jan 23 00:46:51 m0054 voxl-camera-server[4202]: /usr/bin/voxl-camera-server: symbol lookup error: /usr/bin/voxl-camera-server: undefined symbol: pipe_validate_mavlin
                        k_message_t
                        Jan 23 00:46:51 m0054 systemd[1]: voxl-camera-server.service: Main process exited, code=exited, status=127/n/a
                        Jan 23 00:46:51 m0054 systemd[1]: voxl-camera-server.service: Failed with result 'exit-code'.
                        Jan 23 00:46:51 m0054 voxl-px4[1656]: ERROR [muorb] SLPI: Failed to parse version request response packet!
                        Jan 23 00:46:53 m0054 voxl-px4[1656]: message repeated 534 times: [ ERROR [muorb] SLPI: Failed to parse version request response packet!]
                        Jan 23 00:46:53 m0054 systemd[1]: voxl-camera-server.service: Service hold-off time over, scheduling restart.
                        Jan 23 00:46:53 m0054 systemd[1]: voxl-camera-server.service: Scheduled restart job, restart counter is at 1.
                        Jan 23 00:46:53 m0054 systemd[1]: Stopped voxl-camera-server.
                        Jan 23 00:46:53 m0054 systemd[1]: Started voxl-camera-server.
                        Jan 23 00:46:53 m0054 voxl-camera-server[4226]: /usr/bin/voxl-camera-server: symbol lookup error: /usr/bin/voxl-camera-server: undefined symbol: pipe_validate_mavlin
                        k_message_t
                        Jan 23 00:46:53 m0054 systemd[1]: voxl-camera-server.service: Main process exited, code=exited, status=127/n/a
                        Jan 23 00:46:53 m0054 systemd[1]: voxl-camera-server.service: Failed with result 'exit-code'.
                        Jan 23 00:46:53 m0054 voxl-px4[1656]: ERROR [muorb] SLPI: Failed to parse version request response packet!
                        Actually several enabled services wont restart
                        voxl-imu-server | Enabled | Running | 0.0%
                        voxl-lepton-server | Enabled | Not Running |
                        voxl-mavcam-manager | Disabled | Not Running |
                        voxl-mavlink-server | Enabled | Not Running |
                        voxl-modem | Disabled | Not Running |
                        voxl-neopixel-manager | Disabled | Not Running |
                        voxl-portal | Enabled | Not Running |
                        voxl-px4 | Enabled | Running | 32.9%
                        voxl-qvio-server | Disabled | Not Running |
                        voxl-rangefinder-server | Disabled | Not Running |
                        voxl-remote-id | Disabled | Not Running |
                        voxl-softap | Disabled | Not Running |
                        voxl-stitcher | Disabled | Not Running |
                        voxl-streamer | Disabled | Not Running |
                        voxl-tflite-server | Enabled | Running | 0.8%
                        voxl-uvc-server | Disabled | Not Running |
                        voxl-vision-hub | Enabled | Not Running |
                        voxl-wfb-rx-video | Disabled | Not Running |
                        voxl-wfb-rx | Disabled | Not Running |
                        voxl-wfb-tx-video | Disabled | Not Running |
                        voxl-wfb-tx | Disabled | Not Running |
                        voxl2:/$
                        all i did was compile and make install my modal-tflite_data-client.c file
                        • S
                          sansoy @Guest
                          @thomas its all working now.
                          had to reinstall the latest sdk. I'm guessing make install is a no-no. so just did a make and ran the executable.
                          voxl2:/libmodal-pipe/build/examples(master)$ ./modal-tflite_data-client
                          Bounding Box Coordinates:
                          score: 0.558105, x_min: 406.000000, y_min: 417.000000, x_max: 535.000000, y_max: 472.000000
                          score: 0.429199, x_min: 427.000000, y_min: 370.000000, x_max: 573.000000, y_max: 426.000000
                          score: 0.617676, x_min: 498.000000, y_min: 300.000000, x_max: 655.000000, y_max: 358.000000
                          score: 0.416748, x_min: 505.000000, y_min: 302.000000, x_max: 659.000000, y_max: 359.000000
                          score: 0.739258, x_min: 506.000000, y_min: 304.000000, x_max: 667.000000, y_max: 364.000000
                          score: 0.493652, x_min: 4.000000, y_min: -1.000000, x_max: 781.000000, y_max: 109.000000
                          score: 0.547852, x_min: 509.000000, y_min: 306.000000, x_max: 664.000000, y_max: 363.000000
                          score: 0.640625, x_min: 505.000000, y_min: 310.000000, x_max: 660.000000, y_max: 369.000000
                            @sansoy
                            Amazing, glad you got it working!!
                            Thomas
                            • S
                              sansoy @Guest
                              @thomas Hey thomas, we've got the handshaking between your C helper program and our python script working well. i successfully loaded Yolov8 on the voxl and it works really well on images. Was wondering if we could open the camera pipe the same as the tflite_data pipe to run inference on the frames in realtime. i noticed in your /data/web_root/index.html that you are using websockets for serving the videos in the browsers. is this the better route?
                                @sansoy
                                When you say "open the camera pipe" I'm not fully sure I understand what you mean. voxl-tflite-server in its current state already opens up a camera pipe for input images and then publishes its predictions out in that tflite_data pipe and so if you're asking if that's possible then absolutely. Or are you trying to make an output image pipe or something with the predictions overlayed or something?
                                Sorry, just not fully sure what you're asking.
                                Thomas Patton
                                • S
                                  sansoy @Guest
                                  @thomas i'm not using voxl-tflite-server. On my voxl2 i installed the latest version of YOLOv8 from Ultralytics https://docs.ultralytics.com/ and it works well when i run inference on local images. i wanted to test just using a local python script that streams video frames from the hires_small_color camera and runs inference.
                                    @sansoy
                                    Oh ok I see what you're going for then. However we don't currently have an API for doing streaming video in Python, only C++ through libmodal-pipe like we do in modules like voxl-tflite-server.
                                    If you really want to use Python, you could write a small C++ helper program to take in images from the camera and then use some sort of event-driven framework to pass those images to your Python script. Perhaps you could do something clever with just writing them to a temporary directory and setting up a callback-based interface in Python to detect when new files are present.
                                    Sorry for the indirect answer, hope this at least helps some!!
                                    Thomas Patton
                                    • S
                                      sansoy @Guest
                                      @thomas I already wrote a c helper function that uses libmodal-pipe to pipe tflite_data that my python script reads in realtime. it works well
                                      per your message " small C++ helper program to take in images from the camera". how would i modify my c helper to use libmodal-pipe to stream data from one of the cameras?
                                        @sansoy
                                        Oh great, if you already have a function that works with libmodal-pipe then you shouldn't have much trouble writing one for the cameras. Take a look at these lines for the initial code to register the callback function to the camera pipe, this sets up _camera_helper_cb to receive images on callback. For an example of parsing that data, maybe check out these lines in a different module. There's a bit of extra info here but this shows the gist of casting the raw char* bytes into something like an OpenCV image. Definitely modify as needed to fit your use case!
                                        Keep me posted, happy to help however I can!
                                        Thomas Patton
