Recommended ROS2 Installation flow for VOXL2
I'm having issues installing ros2 and running voxl_mpa_to_ros2 on VOXL2. I'm running a fresh flash of SDK1.1.2 on VOXL2 and installing viaapt install voxl-ros2-foxy apt install voxl-mpa-to-ros2 apt install voxl-microdds-agentsourcing ROS2 & running voxl-configure-microdds to enable the systemctl service. after reboot, command
ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_nodeyields
/opt/ros/foxy/mpa_to_ros2/install/voxl_mpa_to_ros2/lib/voxl_mpa_to_ros2/voxl_mpa_to_ros2_node: error while loading shared libraries: libtinyxml2.so.6: cannot open shared object file: No such file or directorychecking ROS topics, as
ros2 topicyields
Failed to load entry point 'list': No module named 'yaml' Traceback (most recent call last): File "/opt/ros/foxy/bin/ros2", line 33, in <module> sys.exit(load_entry_point('ros2cli==0.9.13', 'console_scripts', 'ros2')()) File "/opt/ros/foxy/lib/python3.6/site-packages/ros2cli/cli.py", line 43, in main required=False, argv=argv) File "/opt/ros/foxy/lib/python3.6/site-packages/ros2cli/command/__init__.py", line 251, in add_subparsers_on_demand command_parser, f'{cli_name} {name}', **kwargs) File "/opt/ros/foxy/lib/python3.6/site-packages/ros2topic/command/topic.py", line 30, in add_arguments parser, cli_name, '_verb', 'ros2topic.verb', required=False) File "/opt/ros/foxy/lib/python3.6/site-packages/ros2cli/command/__init__.py", line 237, in add_subparsers_on_demand extension = command_extensions[name] KeyError: 'list'VOXL-Version outputs as below:
-------------------------------------------------------------------------------- system-image: 1.7.1-M0054-14.1a-perf-nightly-20231025 kernel: #1 SMP PREEMPT Thu Oct 26 03:25:38 UTC 2023 4.19.125 -------------------------------------------------------------------------------- hw version: M0054 -------------------------------------------------------------------------------- voxl-suite: 1.1.2 -------------------------------------------------------------------------------- Packages: Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/ Last Updated: 2024-01-05 19:10:23 List: libmodal-cv 0.4.0 libmodal-exposure 0.1.0 libmodal-journal 0.2.2 libmodal-json 0.4.3 libmodal-pipe 2.9.2 libqrb5165-io 0.4.2 libvoxl-cci-direct 0.2.1 libvoxl-cutils 0.1.1 mv-voxl 0.1-r0 qrb5165-bind 0.1-r0 qrb5165-dfs-server 0.2.0 qrb5165-imu-server 1.0.1 qrb5165-rangefinder-server 0.1.1 qrb5165-slpi-test-sig 01-r0 qrb5165-system-tweaks 0.2.3 qrb5165-tflite 2.8.0-2 voxl-bind-spektrum 0.1.0 voxl-camera-calibration 0.5.3 voxl-camera-server 1.8.9 voxl-configurator 0.4.8 voxl-cpu-monitor 0.4.7 voxl-docker-support 1.3.0 voxl-elrs 0.1.3 voxl-esc 1.3.7 voxl-feature-tracker 0.3.2 voxl-flow-server 0.3.3 voxl-gphoto2-server 0.0.10 voxl-jpeg-turbo 2.1.3-5 voxl-lepton-server 1.2.0 voxl-libgphoto2 0.0.4 voxl-libuvc 1.0.7 voxl-logger 0.3.5 voxl-mavcam-manager 0.5.3 voxl-mavlink 0.1.1 voxl-mavlink-server 1.3.2 voxl-microdds-agent 2.4.1-0 voxl-modem 1.0.8 voxl-mongoose 7.7.0-1 voxl-mpa-to-ros 0.3.7 voxl-mpa-to-ros2 0.0.2 voxl-mpa-tools 1.1.3 voxl-neopixel-manager 0.0.3 voxl-opencv 4.5.5-2 voxl-portal 0.6.3 voxl-px4 1.14.0-2.0.63 voxl-px4-imu-server 0.1.2 voxl-px4-params 0.3.3 voxl-qvio-server 1.0.0 voxl-remote-id 0.0.9 voxl-ros2-foxy 0.0.1 voxl-streamer 0.7.4 voxl-suite 1.1.2 voxl-tag-detector 0.0.4 voxl-tflite-server 0.3.1 voxl-utils 1.3.3 voxl-uvc-server 0.1.6 voxl-vision-hub 1.7.3 voxl2-system-image 1.7.1-r0 voxl2-wlan 1.0-r0 --------------------------------------------------------------------------------Any suggestions for running voxl-mpa-to-ros2? is there a python dependency script that the installation needs above the apt install?
-c
