  2. VOXL Compute & Autopilot
  3. VOXL 2
  4. SDK V1.0.1 Beta
SDK V1.0.1 Beta
21 Posts 5 Posters 6.3k Views 3 Watching
  • M Offline
    M Offline
    Mastermind
    @Eric-Katzfey We are trying to expose the USB ports on the MH Carrier board, and I understand that this is solved in V1.0.1. Two questions:
    1. Is this stable enough for us to use a pre-release for testing? If so, how can we get the SDK to flash?
    2. If no to #1, but the code for the MH carrier is ready, is it possible for us to update the 1.0 SDK we are running? As I understand it, it would be a combination of kernel update and source code update for the carrier board.
    Jason
    • M Mastermind
      Jason
      @Mastermind Tagging @modaltb on this
      • ModeratorM Offline
        Referring to this post: https://forum.modalai.com/topic/1582/does-the-microhard-modem-add-on-with-usb-hub-expose-a-viable-uart-to-connect-an-external-flight-controller-to-voxl-2?_=1692808353935
        The feature that will be supported in 1.0.1 is using an external flight controller with the UART on J18. Is there a planned release date for this?
        • modaltbM Offline
          modaltbM Offline
          modaltb
          Hi @Mastermind sorry I'm not following the USB Microhard request, but if we're talking about getting a UART exposed from the applications processor side to support an external flight controller from the J18 connector like Moderator said above, I can get you a pre-release to try out.
          It uses this library that's still in a branch...
          https://gitlab.com/voxl-public/voxl-sdk/core-libs/libqrb5165-io/-/blob/gpio-uart/examples/qrb5165io-slpi-uart-test.c
          This will allow you to open a UART via the DSP, but from the Ubuntu side, so it will appear like a normal UART.
          This response is soupy, so holler if you are confused 😂!
          M 1 Reply Last reply
          • modaltbM modaltb
            M Offline
            M Offline
            Mastermind
            @modaltb Thanks!
            I totally misunderstood. I thought this update was to expose the 2 USB ports on the MH carrier board. As I understand it, they are not usable by the VOXL because the Kernel doesn't support it. We'd like to have them usable for some more sensors we want to carry, having the MH radio carrier board makes it impossible to use any of the USB carriers options.
            That said, having J18 for the flight controller solves the most immediate problem, which is getting that working with the MH carrier board at the same time. Could you give me some pointers to using this library in V1.0.1?
            • M Mastermind
              @modaltb Thanks!
              @Mastermind The USB ports have always been fully functional on the Microhard add-on board.
              • modaltbM Offline
                modaltbM Offline
                modaltb
                @Mastermind let me get a user guide going today (I'm an optimist, I should be able to finish today, if not by EOW) and some test code over and let you give it a go!
                  M Offline
                  M Offline
                  Mastermind
                  @tom If that is true, how come I cannot see those on the VOXL? How do they should up? If I plug the external FC into the MH Carrier board, I should be able to see the FC show up in when doing lsusb right? But it doesn't. Can you tell me what I am doing wrong? If needed I can wire it up and show you the outputs I am seeing.
                  • M Mastermind
                    @Mastermind USB != UART, in order to use an external flight controller you need to plug in to a UART not a USB
                      M Offline
                      M Offline
                      Mastermind
                      @tom Thanks for the clarification. For some crazy reason I was misinformed and thought those two USB's could act as UARTs also.
                      For now I am referring to the pMDDL UART located in this image:
                      • M Mastermind
                        M Offline
                        M Offline
                        Mastermind
                        @Mastermind So this post is really about using the MH Radio with an external FC (in my case the ModalAI external FC), perhaps a title change is needed. Is there no current available UART that can be used for this, or J18 is the only option? If so, what steps would I need to take to make the previously mentioned code work?
                        On a side note, if I added a USB to UART adapter in between the MH Radio's 2 USB ports would that be an option? So MH USB-->UART Adapter-->Modal external FC
                        • M Mastermind
                          wrote on last edited by tom
                          #12
                          @Mastermind There is no solution using the Microhard modem directly but since you're using an external fc we can utilize J18 on VOXL2 and turn it into an accessible UART via. some unreleased software as per @modaltb
                          https://forum.modalai.com/post/12041
                            M Offline
                            M Offline
                            Mastermind
                            @tom Ok I apologize AGAIN. Bare with me, as I am not with the actual hardware. The hardware is at a customer location where english isn't the first language (maybe not even the second).
                            Here is some valuable history and an update:
                            1. The external ModalAI FC was previously connected to the V2 LTE Carrier board USB using a short cable that was made in house. This setup was working for months without any problem using the USB port on the FC to the USB on the V2 Carrier Board.
                            2. V2 board was replaced by the MH pMDDL Carrier board and connected to USB3, however unlike the V2 LTE board, this connection does NOT populate lsusb with anything.
                            I confirmed that the USB on the carrier works, as the Alfa dongle produced a Realtek product listing in lsusb, but the FC does not populate as expected. Microhard made both carrier boards if I am not mistaken, so I would expect the wiring to be the same, and not something else.
                            Finally, to clarify, we aren't looking to use Telem1/2 but the USB instead as we did previously with the V2 LTE board.
                            • modaltbM Offline
                              modaltbM Offline
                              modaltb
                              @Mastermind what are you wanting to use on VOXL2 to talk to the external flight controller SW wise, you own program, or voxl-mavlink-server?
                              I was about to start testing and I failed to realize we need to do some work to get voxl-mavlink-server to use this new interface... so more like EOW
                              • modaltbM modaltb
                                M Offline
                                M Offline
                                Mastermind
                                wrote on last edited by Mastermind
                                #15
                                @modaltb Somehow it's a conundrum for me. These customers somehow "incorrectly" managed to get the V2 LTE Carrier board to work with voxl-mavlink-server with the external flight controller using USB, not telem1/2. I've been asking for information about how they set this up and was told "We used the standard way of setup". I have no idea what that means. Here is what I know right now:
                                DMESG -W on the VOXL2 does show the external FC connected as ttyACM0:
                                [ 5625.761180] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
                                [ 8554.815948] usb 1-1.3: USB disconnect, device number 7
                                [ 8595.208465] usb 1-1.3: new full-speed USB device number 8 using xhci-hcd
                                [ 8595.299614] usb 1-1.3: New USB device found, idVendor=0483, idProduct=a330, bcdDevice= 1.01
                                [ 8595.299629] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                                [ 8595.299640] usb 1-1.3: Product: PX4 FMU ModalAI FCv2
                                [ 8595.299649] usb 1-1.3: Manufacturer: ModalAI
                                [ 8595.299658] usb 1-1.3: SerialNumber: 0
                                However as you know, voxl-mavlink-server only talks on ttyHS0-2, so I am confused about how they had this working with the V2 LTE board. In any event, I tried a few hacks just to see if I could force this to work, I tried a few different ways of symlinking ttyACM0 and ttyHS0, but none of them work,
                                The great news is that it seems we should be able to use the MH Carrier with an external FC but voxl-mavlink-server needs to support this. In our case, the customer needs to use a 6S setup and the current internal VOXL2 FC and ESC only support 4S. Long term it would be nice to be able to carry the ModalAI external FC as a redundant controller (which is my long term goal) with the long range MH radio.
                                modaltbM 1 Reply Last reply
                                • M Mastermind
                                  modaltbM Offline
                                  modaltbM Offline
                                  modaltb
                                  @Mastermind OK I think I'm seeing things a bit more now!
                                  First, let's confirm, when you say LTE v2, you mean this right? https://docs.modalai.com/4G-LTE-Modems/
                                  I ask because Tom brought up, our 5G Modem, has a real UART: https://docs.modalai.com/5G-Modems/
                                  OK back to the question, I think what you are seeing now, if you go directly from a USB port (say LTE board or MH board) to a Flight Core, you will basically be doing what happens when you connect a Flight Core to QGC.
                                  That USB port on FCv1/FCv2 J3 is used for QGC connections and not telemetry like we expect via a UART TELEM. (as far as I know).
                                  So imagine if you had QGC installed on VOXL2 (this won't work!) and then you had the setup of FC straight into USB, you would then have a QGC USB connection like a host PC!
                                  Now, if there is a USB to Serial adapter between the LTE or MH board and a Flight Core's TELEM UART port, then I would expect something similar to enumerate in LSUSB (like /dev/ttyXXX) that COULD act as a UART, and then this would be OK to try with voxl-mavlink-server, but we likely need to modify code as it expects /dev/ttyHSX at this point.
                                  So:
                                  voxl2 --> add on board with USB --> straight to FC J3, not gonna work as we intended
                                  voxl2 --> add on board with USB --> USB to Serial --> to FC TELEM port, should work as intended!
                                  We are still pressing on with the DSP UART path and will get that online anyhow ASAP (but I'm kinda slow lately so bear with me)
                                  • modaltbM modaltb
                                    So:
                                    M Offline
                                    M Offline
                                    Mastermind
                                    @modaltb Thanks so much for the help here. After a lot of testing and translating with Google Translate, I finally understood how they they got it working on the LTE V2 board and how I finally got my setup working with the MH Carrier board.
                                    They used socat to forward ttyACM0 to ttyHS4 and then created a .bashrc line to make socat run on boot. I found this to be messy and instead created a UDEV rule pointing ttyACM0 at ttyHS9 and then refreshed the UDEV rule and boom it works fine. I chose 9 only because I had no idea what ModalAI might want to use the rest of the HS numbers for.
                                    This works really well with voxl-mavlink-server simply changing the conf file to point to UART 9 instead of 1
                                    Thank you so much for all the help. If you need me to add more details to this or if anyone wants to see my actual edits and updates to make this work just let me know.
                                    • M Mastermind
                                      modaltbM Offline
                                      modaltbM Offline
                                      modaltb
                                      @Mastermind holy moly! We haven't heard of this approach before! We'd love to learn more about this, if you could share here or even a google doc or something and we could get this approach into our user guides!
                                      • modaltbM modaltb
                                        M Offline
                                        M Offline
                                        Mastermind
                                        @modaltb Yes absolutely. In fact, I think some simple code update to voxl-mavlink-server would solve this. Essentially, we know the following:
                                        It seems the ModalAI FC will ALWAYS be ttyACM0 when plugged into the MH Carrier board. At least this was true in all of our tests.
                                        We know that ttyACM0 shows up in dmesg -w really fast on boot, well before the MH Radio even gets ttyACM1 (Not sure why that is...)
                                        We have found that VOXL will hold the ttyHSx file in /dev even when the device is not connected and this cannot exist before enabling the UDEV rule or mavlink-server will think the UART is in use. So there needs to be some smart checking to ensure whatever value you have in the conf file DOESN'T exist BEFORE starting the udev rules AND before starting mavlink-server.
                                        Create a file...
                                        sudo nano /etc/udev/rules.d/99-usb-serial.rules
                                        Put this in it for the ModalAI FC detected on the MH Radio USB carrier board
                                        SUBSYSTEM=="tty", ATTRS{idVendor}=="0483", ATTRS{idProduct}=="a330", SYMLINK+="ttyHS9"
                                        Save the file and chmod +x to ensure access
                                        Refresh UDEV with below to enable it
                                        sudo udevadm control --reload-rules
                                        sudo udevadm trigger
                                        In my case I chose ttyHS9. I have been experimenting with a script/service as a workaround, but ideally the above would be programmed into mavlink-server itself to allow access to the FC over USB and not a UART, and even better over the MH Radio USB.
                                        • modaltbM Offline
                                          modaltbM Offline
                                          modaltb
                                          @Mastermind thank you so much for documenting this, we are going give this a go and get it into our docs! Thanks for spending the time (and sticking up for us in the other post 😉 )
