  3. 5G Modem - Voxl-modem ERROR can not ready GPIOs
cellular
16 Posts 3 Posters 3.7k Views 2 Watching
    @DanielHviid The voxl-modem python script itself is not used for the 5G modem at all, nor is it meant to be run manually from the command line.
    The modem should enumerate on boot regardless of any other voxl-modem processes running, check this with ifconfig wwan0
    I recommend running voxl-configure-modem and selecting quectel from the options. It will then ask if you're connecting to ModalLink, choose no. Lastly it'll ask for the APN of your SIM card, choose from the list or enter a custom one.
    Once this is complete, the voxl-modem systemd service will startup and attempt to connect to your 5G network, the status of this service can be monitored with systemctl status voxl-modem
    • D Offline
      D Offline
      DanielHviid
      I did a fresh system install to ensure there wasn't any lingering issues, but I still get the following error:
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:755] qmidevice_detect failed
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:756] Quectel_QConnectManager_Linux_V1.5.9
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:756] network interface '' or qmidev '' is not exist
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:756] qmidevice_detect failed
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:757] Quectel_QConnectManager_Linux_V1.5.9
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:758] network interface '' or qmidev '' is not exist
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:758] qmidevice_detect failed
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:759] Quectel_QConnectManager_Linux_V1.5.9
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:760] network interface '' or qmidev '' is not exist
      Sep 06 03:18:11 m0054 voxl-modem-start.sh[1629]: [09-06_03:18:11:760] qmidevice_detect failed
        Can you share a picture of your setup? Is the Quectel RM502Q-AE installed?
        • D Offline
          D Offline
          DanielHviid
          I have tried two separate 5G modules, same issue.
            @DanielHviid Ensure that both black board to board connectors (left side in pic) are fully seated, the board looks a little crooked. Also double check that the Quectel module itself is fully seated in the pci slot.
            What software version are you running on your voxl2? You can check this with: voxl-version
            • D Offline
              D Offline
              DanielHviid
              The board is fully connected and the voxl2 can find 4 USB connections through it. It looks crooked from the perspective of the image, but is completely parallel with the voxl2 and does not wiggle when pressed. The Quectel module is also tightly connected to the board with the screw that it came with, and I have neither loosened it nor removed it since we received it, with both 5g modem boards we have tested.
              We are running this on a clean install of the VOXL2 Platform 0.9 image.
              kernel:       #1 SMP PREEMPT Thu Oct 13 17:48:16 UTC 2022 4.19.125
              hw version:   M0054
              voxl-suite:   0.9.4
              Packages:
              Last Updated: 2022-09-06 03:18:29
              List:
              	libmodal-cv              0.2.3
              	libmodal-exposure        0.0.7
              	libmodal-journal         0.2.1
              	libmodal-json            0.4.3
              	libmodal-pipe            2.6.0
              	libqrb5165-io            0.1.0
              	libvoxl-cci-direct       0.1.5
              	libvoxl-cutils           0.1.1
              	mv-voxl                  0.1-r0
              	qrb5165-bind             0.1-r0
              	qrb5165-dfs-server       0.1.0
              	qrb5165-imu-server       0.5.0
              	qrb5165-slpi-test-sig    01-r0
              	qrb5165-system-tweaks    0.1.5
              	qrb5165-tflite           2.8.0-2
              	voxl-bind                0.0.1
              	voxl-camera-calibration  0.2.3
              	voxl-camera-server       1.3.5
              	voxl-cpu-monitor         0.3.0
              	voxl-docker-support      1.2.4
              	voxl-gphoto2-server      0.0.10
              	voxl-jpeg-turbo          2.1.3-4
              	voxl-libgphoto2          0.0.4
              	voxl-libuvc              1.0.7
              	voxl-logger              0.3.4
              	voxl-mavlink             0.1.0
              	voxl-mavlink-server      0.2.0
              	voxl-modem               0.16.1
              	voxl-mongoose            7.7.0-1
              	voxl-mpa-to-ros          0.3.6
              	voxl-mpa-tools           0.7.6
              	voxl-opencv              4.5.5-1
              	voxl-portal              0.4.2
              	voxl-px4                 1.12.31
              	voxl-px4-imu-server      0.1.2
              	voxl-qvio-server         0.8.2
              	voxl-remote-id           0.0.5
              	voxl-streamer            0.4.1
              	voxl-suite               0.9.4
              	voxl-tag-detector        0.0.4
              	voxl-tflite-server       0.3.1
              	voxl-utils               1.2.2
              	voxl-uvc-server          0.1.3
              	voxl-vision-px4          1.4.0
              	voxl2-system-image       1.4.1-r0
              	voxl2-wlan               1.0-r0
              We have just tried it on the 0.9.5 image as well, with no change.
                @DanielHviid What do you see with the following commands:
                ifconfig
                ls /dev | grep ttyUSB
                ls /dev | grep cdc
                • D Offline
                  D Offline
                  DanielHviid
                  ifconfig
                  bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST>  mtu 1500
                          ether 56:04:23:be:49:16  txqueuelen 1000  (Ethernet)
                          RX packets 0  bytes 0 (0.0 B)
                          TX packets 0  bytes 0 (0.0 B)
                  dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP>  mtu 1500
                          inet6 fe80::63f1:e926:6645:ed3a  prefixlen 64  scopeid 0x20<link>
                          ether 12:88:76:22:4a:2c  txqueuelen 1000  (Ethernet)
                          TX packets 5  bytes 894 (894.0 B)
                          RX packets 80  bytes 5680 (5.6 KB)
                          TX packets 80  bytes 5680 (5.6 KB)
                  wwan0: flags=4291<UP,BROADCAST,RUNNING,NOARP,MULTICAST>  mtu 1500
                          inet6 fe80::ae85:f75c:c008:10c7  prefixlen 64  scopeid 0x20<link>
                          ether c6:79:d7:12:6a:d4  txqueuelen 1000  (Ethernet)
                  ttyUSB0
                  ttyUSB1
                  ttyUSB2
                  ttyUSB3
                  ls /dev | grep cdc
                  cdc-wdm0
                    @DanielHviid That all looks as expected, what about if you run the quectel connection manager program manually: quectel-CM -s $APN where $APN is your SIM card's APN
                    • D Offline
                      D Offline
                      DanielHviid
                      • D Offline
                        D Offline
                        DanielHviid
                        quectel-CM -s ###APN###
                        [03-02_12:59:25:085] Quectel_QConnectManager_Linux_V1.5.9
                        [03-02_12:59:25:088] Find /sys/bus/usb/devices/2-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x002, dev=0x003
                        [03-02_12:59:25:088] Auto find qmichannel = /dev/cdc-wdm0
                        [03-02_12:59:25:089] Auto find usbnet_adapter = wwan0
                        [03-02_12:59:25:089] netcard driver = qmi_wwan, driver version = 22-Aug-2005
                        [03-02_12:59:25:090] Modem works in QMI mode
                        [03-02_12:59:25:114] /proc/4755/fd/7 -> /dev/cdc-wdm0
                        [03-02_12:59:25:114] /proc/4755/exe -> /usr/bin/quectel-CM
                        [03-02_12:59:27:116] cdc_wdm_fd = 7
                        [03-02_12:59:27:213] Get clientWDS = 2
                        [03-02_12:59:27:244] Get clientDMS = 1
                        [03-02_12:59:27:276] Get clientNAS = 4
                        [03-02_12:59:27:308] Get clientUIM = 1
                        [03-02_12:59:27:340] Get clientWDA = 1
                        [03-02_12:59:27:372] requestBaseBandVersion RM502QAEAAR11A04M4G
                        [03-02_12:59:40:876] QmiWwanThread read=-1 errno: 2 (No such file or directory)
                        [03-02_12:59:57:373] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
                        [03-02_12:59:57:373] requestSetEthMode err = 110
                        [03-02_12:59:57:388] requestGetSIMStatus SIMStatus: SIM_PIN
                        [03-02_12:59:57:388] requestSetProfile[1] ###APN###///0
                        [03-02_13:00:27:389] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
                        [03-02_13:00:27:389] requestSetProfile err = 110
                        [03-02_13:00:57:389] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
                        [03-02_13:00:57:390] requestGetProfile err = 110
                        [03-02_13:00:57:420] QmiWwanThread read=-1 errno: 2 (No such file or directory)
                        [03-02_13:01:27:390] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
                        [03-02_13:01:27:390] requestRegistrationState2 err = 110
                        [03-02_13:01:27:404] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
                        [03-02_13:01:27:405] ifconfig wwan0 down
                        [03-02_13:01:27:451] ifconfig wwan0 0.0.0.0
                        [03-02_13:01:27:467] requestRegistrationState2 MCC: 238, MNC: 20, PS: Detached, DataCap: UNKNOW
                        [03-02_13:04:27:453] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
                        [03-02_13:04:27:453] requestQueryDataCall err = 110
                        [03-02_13:04:57:548] QmiWwanThread read=-1 errno: 2 (No such file or directory)
                        [03-02_13:05:27:517] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
                        [03-02_13:05:27:517] requestQueryDataCall err = 110
                        [03-02_13:06:12:524] QmiThreadSendQMITimeout pthread_cond_timeout_np timeout
                        [03-02_13:06:12:524] requestQueryDataCall err = 110
                          wrote on last edited by tom
                          #13
                          @DanielHviid Can you try installing a newer version of voxl-modem?: http://voxl-packages.modalai.com/dists/qrb5165/staging/binary-arm64/voxl-modem_1.0.3_arm64.deb
                          adb push voxl-modem_1.0.3_arm64.deb .
                          adb shell
                          dpkg -i voxl-modem_1.0.3_arm64.deb
                          This new package includes a newer quectel-CM source
                          • D Offline
                            D Offline
                            DanielHviid
                            @tom Definite improvement, but it seems to be stuck in initialization. This is the output of manually running it it.
                            [03-02_13:08:35:594] Quectel_QConnectManager_Linux_V1.6.0.24
                            [03-02_13:08:35:598] Find /sys/bus/usb/devices/2-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x002, dev=0x003
                            [03-02_13:08:35:599] Auto find qmichannel = /dev/cdc-wdm0
                            [03-02_13:08:35:599] Auto find usbnet_adapter = wwan0
                            [03-02_13:08:35:600] netcard driver = qmi_wwan, driver version = 22-Aug-2005
                            [03-02_13:08:35:600] Modem works in QMI mode
                            [03-02_13:08:35:621] cdc_wdm_fd = 7
                            [03-02_13:08:35:708] Get clientWDS = 15
                            [03-02_13:08:35:739] Get clientDMS = 1
                            [03-02_13:08:35:771] Get clientNAS = 4
                            [03-02_13:08:35:803] Get clientUIM = 1
                            [03-02_13:08:35:835] Get clientWDA = 1
                            [03-02_13:08:35:867] requestBaseBandVersion RM502QAEAAR11A04M4G
                            [03-02_13:08:35:995] requestGetSIMStatus SIMStatus: SIM_PIN
                            [03-02_13:08:35:995] requestSetProfile[1] ###APN###///0
                            [03-02_13:08:36:059] requestGetProfile[1] ###APN###///0
                            [03-02_13:08:36:091] requestRegistrationState2 MCC: 238, MNC: 20, PS: Detached, DataCap: UNKNOW
                            [03-02_13:08:36:123] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
                            [03-02_13:08:36:123] ifconfig wwan0 0.0.0.0
                            [03-02_13:08:36:146] ifconfig wwan0 down
                              @DanielHviid I haven't seen this before with SIM status: requestGetSIMStatus SIMStatus: SIM_PIN, I'm wondering if the SIM card is locked and is expecting a pin number? quectel-CM allows you to pass in a pincode with -p:
                              voxl2:/$ quectel-CM -h
                              Usage: quectel-CM [options]
                              -s [apn [user password auth]]          Set apn/user/password/auth get from your network provider. auth: 1~pap, 2~chap
                               -p pincode                             Verify sim card pin if sim card is locked
                              -p [quectel-][qmi|mbim]-proxy          Request to use proxy
                              -f logfilename                         Save log message of this program to file
                              -u usbmonlog filename                  Save usbmon log to file
                              -i interface                           Specify which network interface to setup data call when multi-modems exits
                              -4                                     Setup IPv4 data call (default)
                              -6                                     Setup IPv6 data call
                               -n pdn                                 Specify which pdn to setup data call (default 1 for QMI, 0 for MBIM)
                              -k pdn                                 Specify which pdn to hangup data call (by send SIGINT to 'quectel-CM -n pdn')
                              -m iface-idx                           Bind QMI data call to wwan0_<iface idx> when QMAP used. E.g '-n 7 -m 1' bind pdn-7 data call to wwan0_1
                              -b                                     Enable network interface bridge function (default 0)
                              -v                                     Verbose log mode, for debug purpose.
                              [Examples]
                              Example 1: quectel-CM
                              Example 2: quectel-CM -s 3gnet
                              Example 3: quectel-CM -s 3gnet carl 1234 1 -p 1234 -f gobinet_log.txt
                              • D Offline
                                D Offline
                                DanielHviid
                                @tom Curriously, it does not seem to accept -p 0000, which was our pin. We changed it to 1234, which is accepted, but that didn't help with the issue, and it acted identically to providing the wrong pin.
                                quectel-CM -p 0000
                                [03-02_13:02:16:064] Quectel_QConnectManager_Linux_V1.6.0.24
                                [03-02_13:02:16:064] unknow -p '0000'
                                quectel-CM -p 1234
                                [03-02_13:02:39:300] Quectel_QConnectManager_Linux_V1.6.0.24
                                [03-02_13:02:39:305] Find /sys/bus/usb/devices/2-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x002, dev=0x003
                                [03-02_13:02:39:307] Auto find qmichannel = /dev/cdc-wdm0
                                [03-02_13:02:39:307] Auto find usbnet_adapter = wwan0
                                [03-02_13:02:39:307] netcard driver = qmi_wwan, driver version = 22-Aug-2005
                                [03-02_13:02:39:308] Modem works in QMI mode
                                [03-02_13:02:39:325] cdc_wdm_fd = 7
                                [03-02_13:02:39:399] Get clientWDS = 15
                                [03-02_13:02:39:430] Get clientDMS = 1
                                [03-02_13:02:39:462] Get clientNAS = 4
                                [03-02_13:02:39:494] Get clientUIM = 1
                                [03-02_13:02:39:526] Get clientWDA = 1
                                [03-02_13:02:39:557] requestBaseBandVersion RM502QAEAAR11A04M4G
                                [03-02_13:02:39:686] requestGetSIMStatus SIMStatus: SIM_PIN
                                [03-02_13:02:39:718] requestGetProfile[1] 3gnet/carl/1234/1
                                [03-02_13:02:39:749] requestRegistrationState2 MCC: 238, MNC: 20, PS: Detached, DataCap: UNKNOW
                                [03-02_13:02:39:781] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
                                [03-02_13:02:39:781] ifconfig wwan0 0.0.0.0
                                [03-02_13:02:39:803] ifconfig wwan0 down
