    voxl-tflite-server crashes after 5-10 minutes
    VOXL
    • C
      colerose
      After running:
      roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
      on the VOXL with the latest stable version of voxl-tflite-server running (v0.1.6), I noticed that the tflite pipe would disconnect and reconnect after about 5-10 minutes.
      Here is an output of that occuring:
      Found new interface: tflite
      Found new interface: tracking
      Found new interface: cpu_monitor
      Found new interface: imu0
      Found new interface: imu1
      Found new interface: vvpx4_gps_raw_int
      Found new interface: vvpx4_mavlink_io
      Found new interface: vvpx4_sys_status
      Found new interface: vvpx4_vehicle_gps
      Found new interface: vvpx4_body_wrt_fixed
      Found new interface: vvpx4_body_wrt_local
      Found new interface: qvio_extended
      Found new interface: vvpx4_shell
      Interface: tflite's data pipe disconnected, closing until it returns
      Found pipe for interface: tflite, now advertising
      When this happens all of the cameras on voxl-portal are no longer viewable. I can select them but no image shows up. Even if I restart voxl-portal or the voxl-tflite server the cameras don't show up in voxl-portal. The only fix to this is to restart the voxl entirely.
      I then tested to see if this happened without voxl-mpa-to-ros running. Unfortunately, the same error still occurs. After about 5-10 minutes the cameras are no longer viewable in voxl-portal with the only fix being to reboot the voxl.
        @colerose please see the latest version v0.1.8 on dev or stable. This version also includes a new output pipe (tflite_data) by default that will publish metadata about detections, in the form of:
        typedef struct object_detection_msg {
            int64_t timestamp_ns;
            uint32_t class_id;
            char class_name[64];
            float class_confidence;
            float detection_confidence;
            float x_min;
            float y_min;
            float x_max;
            float y_max;
        } __attribute__((packed)) object_detection_msg;
        typedef struct detections_array {
            int32_t num_detections;
            object_detection_msg detections[64];
        } __attribute__((packed)) detections_array;
        • C
          colerose
          @Matt-Turi thanks for letting me know! Does this new version crash less often? Also, will the output pipe work with voxl_mpa_to_ros?
            @colerose Yes, the new version fixes this issue and should no longer be a problem.
            The new output pipe is not compatible with voxl_mpa_to_ros yet, but it will be added in very soon!
            W 1 Reply Last reply Reply Quote 0
            • W
              Wei Cui @Guest
              @Matt-Turi Can you please let us know if voxl_mpa_to_ros is compatible with the new output pipe? Thanks.
                @Wei-Cui @colerose The dev latest version of voxl_mpa_to_ros is now compatible with the new output pipe. See the latest package on our opkg repo titled voxl-nodes_0.2.2_202112212238.ipk or public gitlab.
                • H
                  hedd
                  hello @colerose how do u get all these topics by launching just roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch because when i launch it i get just these topics :
                  MPA to ROS app is now running
                  Found new interface: hires
                  Found new interface: qvio_overlay
                  Found new interface: stereo
                  Found new interface: voa_pc_out
                  Thank u in advance for your reply
