Yufei JiangY
Yufei Jiang
@Yufei Jiang
  • Low MAVLINK Message Frequency
    Yufei JiangY Yufei Jiang
    I found most of my Mavlink messages are in low frequency. How to increase this frequency (especially the frequency of it's LocalPosition)? I need to use this data for my offboard program. Thank you!
  • Open-vins keeps diverging and re-initializing.
    @Yufei-Jiang And I used voxl-configure-cameras and voxl-configure-extrinsics D0006_Sentinel to generate the camera config.
    @zauberflote1 Hi, I recalibrated the imu and checked it using voxl-inspect-imu. The imu data looks good. In voxl-inspect-cam it can detect all the cameras. However, it's still diverging really fast once I moved the VOXL2. If I disabled the auto-reset of vins, it will keep drifting.
    I'm using VOXL2 with flight deck and trying to test the open-vins. Currently I'm only using one camera (tracking) and the output will diverge quickly once I slightly move the VOXL2. Is there any clue about why and how I can solve this?
    Below is my system:
    voxl2:/$ voxl-version
    kernel: #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
    hw platform: M0054
    mach.var: 1.0.0
    SKU: MDK-F0006-4-V2-C11-E1
    voxl-suite: 1.4.5
    Packages:
    Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
    Last Updated: 2025-06-05 19:03:39
    List:
    kernel-module-voxl-fsync-mod-4.19.125 1.0-r0
    kernel-module-voxl-gpio-mod-4.19.125 1.0-r0
    kernel-module-voxl-platform-mod-4.19.125 1.0-r0
    libfc-sensor 1.0.7
    libmodal-cv 0.5.18
    libmodal-exposure 0.1.4
    libmodal-journal 0.2.5
    libmodal-json 0.4.7
    libmodal-pipe 2.13.1
    libqrb5165-io 0.5.0
    libvoxl-cci-direct 0.3.2
    libvoxl-cutils 0.1.5
    modalai-slpi 1.1.20
    mv-voxl 0.1-r0
    qrb5165-bind 0.1-r0
    qrb5165-dfs-server 0.2.0
    qrb5165-imu-server 1.1.3
    qrb5165-rangefinder-server 0.1.5
    qrb5165-slpi-test-sig 01-r0
    qrb5165-system-tweaks 0.3.5
    qrb5165-tflite 2.8.0-2
    voxl-bind-spektrum 0.1.1
    voxl-camera-calibration 0.5.9
    voxl-camera-server 2.2.1
    voxl-ceres-solver 2:1.14.0-10
    voxl-configurator 1.0.1
    voxl-cpu-monitor 0.6.0
    voxl-docker-support 1.3.1
    voxl-elrs 0.4.7
    voxl-esc 1.5.2
    voxl-feature-tracker 0.5.2
    voxl-flow-server 0.3.6
    voxl-fsync-mod 1.0-r0
    voxl-gphoto2-server 0.0.10
    voxl-gpio-mod 1.0-r0
    voxl-io-server 0.0.5
    voxl-jpeg-turbo 2.1.3-7
    voxl-lepton-server 1.3.3
    voxl-lepton-tracker 0.0.4
    voxl-libgphoto2 0.0.4
    voxl-libuvc 1.0.7
    voxl-logger 0.5.3
    voxl-mavcam-manager 0.5.8
    voxl-mavlink 0.1.5
    voxl-mavlink-server 1.4.7
    voxl-modem 1.1.6
    voxl-mongoose 7.7.0-2
    voxl-mpa-to-ros 0.3.9
    voxl-mpa-tools 1.4.0
    voxl-open-vins 0.4.19
    voxl-open-vins-server 0.3.12
    voxl-opencv 4.5.5-3
    voxl-osd 0.1.7
    voxl-platform-mod 1.0-r0
    voxl-portal 0.7.10
    voxl-px4 1.14.0-2.0.98
    voxl-px4-imu-server 0.1.2
    voxl-px4-params 0.7.3
    voxl-qvio-server 1.2.0
    voxl-remote-id 0.0.9
    voxl-reset-slpi 0.0.1
    voxl-state-estimator 0.0.5
    voxl-streamer 0.7.5
    voxl-suite 1.4.5
    voxl-tag-detector 0.0.4
    voxl-tflite-server 0.4.1
    voxl-utils 1.4.8
    voxl-uvc-server 0.1.7
    voxl-vision-hub 1.8.21
    voxl-vtx 1.3.14
    voxl-wavemux 0.0.1
    voxl2-io 0.0.3
    voxl2-system-image 1.8.02-r0
    voxl2-wlan 1.0-r0
    voxl-open-vins-server.conf:
    "en_auto_reset": true,
    "auto_reset_max_velocity": 20,
    "auto_reset_max_v_cov_instant": 0.10000000149011612,
    "auto_reset_max_v_cov": 0.10000000149011612,
    "auto_reset_max_v_cov_timeout_s": 0.5,
    "auto_reset_min_features": 1,
    "auto_reset_min_feature_timeout_s": 3,
    "auto_fallback_timeout_s": 3,
    "auto_fallback_min_v": 0.600000023841858,
    "en_cont_yaw_checks": false,
    "fast_yaw_thresh": 5,
    "fast_yaw_timeout_s": 1.75,
    "do_fej": true,
    "imu_avg": true,
    "use_rk4_integration": true,
    "cam_to_imu_refinement": true,
    "cam_intrins_refinement": true,
    "cam_imu_ts_refinement": true,
    "max_clone_size": 8,
    "max_slam_features": 35,
    "max_slam_in_update": 10,
    "max_msckf_in_update": 10,
    "feat_rep_msckf": 4,
    "feat_rep_slam": 4,
    "cam_imu_time_offset": 0,
    "slam_delay": 1,
    "gravity_mag": 9.80665,
    "init_window_time": 0.5,
    "init_imu_thresh": 2,
    "imu_sigma_w": 0.00013990944749616306,
    "imu_sigma_wb": 4.1189724174615527e-07,
    "imu_sigma_a": 0.0038947538150776763,
    "imu_sigma_ab": 5.538346201712153e-05,
    "msckf_chi2_multiplier": 1,
    "slam_chi2_multiplier": 40,
    "zupt_chi2_multiplier": 1,
    "refine_features": true,
    "pyr_levels": 6,
    "grid_x": 5,
    "grid_y": 5,
    "msckf_sigma_px": 1,
    "slam_sigma_px": 1.8,
    "zupt_sigma_px": 1,
    "try_zupt": true,
    "zupt_max_velocity": 0.03,
    "zupt_only_at_beginning": true,
    "zupt_noise_multiplier": 1,
    "zupt_max_disparity": 8,
    "init_dyn_use": false,
    "triangulate_1d": false,
    "max_runs": 5,
    "init_lamda": 0.001,
    "max_lamda": 10000000000,
    "min_dx": 1e-06,
    "min_dcost": 1e-06,
    "lam_mult": 10,
    "min_dist": 0.1,
    "max_dist": 60,
    "max_baseline": 40,
    "max_cond_number": 600000,
    "use_mask": false,
    "use_stereo": false,
    "use_baro": false,
    "num_opencv_threads": 4,
    "fast_threshold": 15,
    "histogram_method": 1,
    "knn_ratio": 0.7,
    "takeoff_accel_threshold": 0.5,
    "takeoff_threshold": -0.1,
    "use_stats": false,
    "max_allowable_cep": 1,
    "en_force_init": false,
    "en_force_ned_2_flu": false,
    "en_imu_frame_output": true,
    "track_frequency": 15,
    "publish_frequency": 5,
    "en_vio_always_on": true,
    "en_ext_feature_tracker": false,
    "en_gpu_for_tracking": true,
    "num_features_to_track": 10,
    "raansac_gn": false,
    "raansac_tri": true,
    "en_thermal_enhance": false,
    "en_overlay_landscape": false,
    "thermal_brightness": 1,
    "thermal_brightness_bos": 1
    Output of open-vins-server:
    voxl2:/etc/modalai$ voxl-open-vins-server
    Setting printing level to: SILENT
    =========================AUTO RESET==============================
    en_auto_reset: 1
    auto_reset_max_velocity: 20.000
    auto_reset_max_v_cov_instant: 0.100
    auto_reset_max_v_cov: 0.100
    auto_reset_max_v_cov_timeout_s: 0.500
    auto_reset_min_features: 1
    auto_reset_min_feature_timeout_s: 3.000
    auto_fallback_timeout_s: 3.000
    auto_fallback_min_v: 0.600
    en_cont_yaw_checks: false
    fast_yaw_thresh: 5.000
    fast_yaw_timeout_s: 1.750
    ===========================STATE=================================
    do fej: true
    imu avg: true
    use rk4 integration: true
    cam to imu refinement: true
    cam intrins refinement: true
    cam imu ts refinement: true
    max clone size: 8
    max slam features: 35
    max slam in update: 10
    max msckf in update: 10
    feat rep msckf: ANCHORED_MSCKF_INVERSE_DEPTH
    feat rep slam: ANCHORED_MSCKF_INVERSE_DEPTH
    cam imu time offset: 0.00000
    slam delay: 1.00000
    pyr levels: 6
    grid x: 5
    grid y: 5
    =====================INERTIAL INITIALIZER========================
    gravity mag: 9.80665
    init window time: 0.50000
    init imu thresh: 2.00000
    init dyn use: false
    ==========================IMU NOISE==============================
    imu sigma w: 0.00014
    imu sigma wb: 0.00000
    imu sigma a: 0.00389
    imu sigma ab: 0.00006
    ========================FEATURE NOISE============================
    msckf chi^2 multiplier: 1.00000
    msckf sigma px: 1.00000
    slam chi^2 multiplier: 40.00000
    slam sigma px: 1.80000
    zupt chi^2 multiplier: 1.00000
    zupt sigma px: 1.00000
    =============================ZUPT================================
    refine features: true
    max runs: 5
    try zupt: true
    en_ext_feature_tracker: 0
    en_gpu_for_tracking: 1
    raansac_gn: false
    raansac_tri: true
    zupt max velocity: 0.03000
    zupt only at beginning: true
    zupt noise multiplier: 1.00000
    zupt max disparity: 8.00000
    use mask: false
    use stereo: false
    use baro: false
    ========================FEATURE INITIALIZER======================
    triangulate 1d: false
    init lamda: 0.00100
    max lamda: 10000000000.00000
    min dx: 0.00000
    min dcost: 0.00000
    lam mult: 10.00000
    min dist: 0.10000
    max dist: 60.00000
    max baseline: 40.00000
    num_opencv_threads: 4
    fast_threshold: 15
    histogram_method: HISTOGRAM
    knn_ratio: 0.70000
    track_frequency: 15.00000
    publish_frequency: 5
    imu takeoff accel thresh: 0.50000
    force init on takeoff: false
    takeoff_threshold(m): -0.100000
    publish stats: false
    max_allowable_cep: 1.00000
    force FLU to NED transform: false
    publish IMU frame: true
    VIO always on (for bench testing): true
    num_features_to_track: 10
    Enable Thermal Enhance: false
    Enable Overlay Landscape: false
    Thermal Brightness: 1.00000
    Thermal Brightness BOSON: 1.00000
    vio_cam config:
    cam 0:
    enable: 1
    pipe_for_preview: tracking
    pipe_for_tracking: tracking
    is_occluded_on_ground: 0
    imu: imu_apps
    is_extrinsic_present: 1
    extrinsic cam wrt imu:
    parent: imu_apps
    child: tracking
    T_cam_wrt_imu: 0.027 0.007 0.018
    RPY_imu_to_cam: 0.0 45.0 90.0
    R_cam_to_imu: 0.000 -0.707 0.707
    1.000 0.000 -0.000
    -0.000 0.707 0.707
    cal file: opencv_tracking_intrinsics.yml
    is_cal_present: 1
    cam cal intrinsics:
    width: 640
    height: 480
    fx: 277.659
    fy: 277.763
    cx: 349.269
    cy: 219.049
    n_coeffs: 4
    is_fisheye: 1
    😧 -0.0240 0.0390 -0.0284 0.0077
    vio cam: 0 is occluded: 0
    [INFO] Camera: 0 -- converted extrinsics in FLU are: Roll: -0.000000, Pitch 135.000000, Yaw -90.000000 (-1.570796)
    WORLD QUATERNION: -0.000000 0.000000 -0.000000 1.000000
    OpenVINS using fisheye camera
    OpenVINS FINAL Cam extrinsics to IMU for tracking: 7
    -0.653281
    0.653281
    -0.270598
    0.270598
    0.0273
    -0.0067
    -0.0182
    OpenVINS reports number of cameras being used, regardless of delivery method (pipe, merge, etc...): 1
    Set camera intrinsics and extrinsics
    ====> Using Internal KLT feature tracker (w/ GPU) <====
    initialized ocl manager
    Current reference counts:
    trackDB: 1
    trackFEATS: 1
    propagator: 2
    updaterMSCKF: 1
    updaterSLAM: 1
    active_tracks_initializer: 1
    initializer: 1
    create_server_pipes
    connecting client pipes
    imu pipe name: imu_apps
    Number of Cameras active: 1
    Camera merge --- > ch: 1 to cam id: 0
    Opening camera pipe: tracking
    tmp_camera_pipe_names.push_back(): tracking
    client "voxl-portal66662777" connected to overlay
    [WARN] (0.005064 and 0.235771) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
    [WARN] (0.004868 and 0.241071) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
    [WARN] (0.003866 and 0.231757) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
    [INFO] world : 1.000000 1.000000 (2)
    [WARN] (0.003118 and 0.237088) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
    [WARN] (0.005283 and 0.226763) Cannot initialize FRD to IMU transform--too much drift: your IMU may need to be recalibrated or is OVERHEATED!
    FAILED TO FETCH IMG RINGBUF at time 0 -2 -2 -2 -2 -2
    [INFO] FRD to IMU NED configuration done. g direction: -1
    [INFO] gravity direction (2) : -1
    [INFO] *** FRD to IMU transform READY! ***
    waiting for enough clone states (1 of 5)....
    [WARN] Motion detected, going to full processing
    waiting for enough clone states (2 of 5)....
    waiting for enough clone states (3 of 5)....
    waiting for enough clone states (4 of 5)....
    [VIO_BAD_STATE] Quality less than 1.
    WARNING auto-resetting, Bad VIO, State: true Q: -1 Vel: 0.043736 Uncert: 0.949216 State: 0(1)
    [INFO] restarting managers STATELESS
    trackDB: 1
    trackFEATS: 1
    propagator: 2
    updaterMSCKF: 1
    updaterSLAM: 1
    initializer: 1
    Camera queue size after reset: 0
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1959.206927 - 1958.867053 (0.339874)
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1959.237218 - 1958.867053 (0.370165)
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1959.282138 - 1958.867053 (0.415084)
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1959.311426 - 1958.867053 (0.444373)
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1959.336785 - 1958.867053 (0.469732)
    [INFO] TAKEOFF: DISPARITY disturbed, possible motion detected. Avg: 434.788239 (8.000000) # feats: 2 (20).
    [INFO] TAKEOFF: DISPARITY disturbed, possible motion detected. Avg: 0.000000 (8.000000) # feats: 2 (20).
    WARNING auto-resetting, Bad VIO, State: true Q: -1 Vel: 7.194683 Uncert: 0.586549 State: 0(1)
    trackDB: 1
    trackFEATS: 1
    propagator: 2
    updaterMSCKF: 1
    updaterSLAM: 1
    initializer: 1
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1965.271825 - 1964.916372 (0.355453)
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1965.311861 - 1964.916372 (0.395488)
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1965.342133 - 1964.916372 (0.425761)
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1965.376322 - 1964.916372 (0.459950)
    IMU samples too small, make your window smaller (params.init_window_time), can't initalize 1965.411513 - 1964.916372 (0.495141)
