Stefano AccollaS
Stefano Accolla
@Stefano Accolla
  • voxl-mapper setting
    Stefano AccollaS Stefano Accolla
    Good morning,
    I'm trying to use voxl-mapper with a starling 2. When I use it with waypoints in larger rooms it works correctly, while if I use it in hallways or to go through doorways the drone doesn't follow the correct path and slams into walls.
    In some situations the drone goes to the opposite side from the placed waypoint.
    This is the result of "cat etc/modalai/extrinsics.conf"
    This is the result of "voxl-inspect-extrinsics"
    #0:
    parent: imu_apps
    child: tracking_front
    T_child_wrt_parent: 0.037 0.000 0.001
    RPY_parent_to_child: 0.0 90.0 90.0
    R_child_to_parent: 0.000 -0.000 1.000
    1.000 0.000 -0.000
    -0.000 1.000 0.000
    #1:
    parent: imu_apps
    child: tracking_down
    T_child_wrt_parent: -0.088 -0.004 0.003
    RPY_parent_to_child: 0.0 0.0 180.0
    R_child_to_parent: -1.000 -0.000 0.000
    0.000 -1.000 -0.000
    0.000 0.000 1.000
    #2:
    parent: imu_apps
    child: tracking_rear
    T_child_wrt_parent: -0.092 0.016 0.004
    RPY_parent_to_child: 0.0 -90.0 -90.0
    R_child_to_parent: 0.000 0.000 -1.000
    -1.000 0.000 -0.000
    0.000 1.000 0.000
    #3:
    parent: body
    child: imu_apps
    T_child_wrt_parent: 0.029 -0.006 -0.016
    RPY_parent_to_child: 0.0 0.0 0.0
    R_child_to_parent: 1.000 -0.000 0.000
    0.000 1.000 -0.000
    0.000 0.000 1.000
    #4:
    parent: body
    child: imu_px4
    T_child_wrt_parent: 0.004 0.007 -0.016
    0.000 1.000 -0.000
    0.000 0.000 1.000
    #5:
    parent: imu_apps
    child: lepton0_raw
    T_child_wrt_parent: -0.085 0.013 0.024
    RPY_parent_to_child: 0.0 0.0 90.0
    R_child_to_parent: 0.000 -1.000 0.000
    1.000 0.000 -0.000
    0.000 0.000 1.000
    #6:
    parent: body
    child: tof
    T_child_wrt_parent: 0.068 -0.012 -0.017
    RPY_parent_to_child: 0.0 90.0 180.0
    R_child_to_parent: -0.000 -0.000 1.000
    0.000 -1.000 -0.000
    1.000 0.000 0.000
    #7:
    parent: body
    child: ground
    T_child_wrt_parent: 0.000 0.000 0.033
    0.000 1.000 -0.000
    0.000 0.000 1.000
    This is the result of "cat /etc/modalai/voxl-mapper.conf"
    While this is the result of "ls /run/mpa/"
    Maybe there is an error in the sensors used in the mapper configuration? Maybe I need to enter the tracking cams?
    Could you help me solve the problem?
    Thank you!
    Development Drones starling
  • External API to interact with voxl-mapper
    Good morning,
    I would need to interact with voxl-mapper via an external API, is it possible to publish a waypoint via external API?
    Thank you!
  • Plan to a point
    I am using a Starling 2 with one-point navigation functionality with voxl-mapper. Currently I can't get the drone to cross the doors (a ~76cm wide space), is it possible to get it to cross these spaces with this mode? Do I need to correct some parameters to do this?
    thank you!
    Best,
  • Binding of Ghost Atto controller
    we purchased a Starling 2 Drone, How can i bind a Ghost Atto controller with a Starling 2 drone?
    Thank you in advance.
  • check-calibration "Detected Missing Calibration Files"
    Can you also help me to bind the Ghost Atto controller?
    we purchased a Starling 2 Drone, when I run the command "voxl-check-calibration" I get this result:
    How can I solve Missing /data/px4/param/parameters_level.cal ?
