Shaun CosgroveS
Shaun Cosgrove
@Shaun Cosgrove
  • Does VOXL 2 support the Hadron™ 640R dual Camera?
    Shaun CosgroveS Shaun Cosgrove
    Re: Does VOXL 2 support the Hadron™ 640R dual Camera?
    Essentially I have the same question as the one linked above.
    Does the VOXL2 platform image support the Hadron 640R dual Camera (both the high res and the thermal sources)?
    There was mention from Jan 2023 that the Qualcom RB5 platform supporte was added for the OV64B.
    Has this support been integrated into the latest VOXL2 system images?
  • VOXL2 Mini J10 UART
    Scoping the RX line, there is an 80mV p2p signal on the RX (to VOXL2 Mini) and a 3v3 on the TX.
    Is there a pull-down configured for the RX pin or some other configuration that could explain this? Is it possible to change this during runtime or will it require rebuilding the system image?
    After flashing the latest system image for the VOXL2 Mini (with no subsequent modifications apart from wifi setup), I cannot get the J10 Uart RX (sending to the mini) working. TX (sending from the mini) works as expected. Is there some configuration / parameter that I am missing or any suggested way to debug this? I will try a new mini board in case there is a hardware issue. Thanks!
  • https://developer.modalai.com/ 502 Bad Gateway
    https://developer.modalai.com/ has been down for several hours, any idea when it will be back online?
    Thanks.
