Riccardo BenedettiR
Riccardo Benedetti
@Riccardo Benedetti
  • voxl-camera-server failed to set pipe size: Cannot allocate memory
    Riccardo BenedettiR Riccardo Benedetti
    Same issue and same SDK here:
    voxl2:~$ voxl-camera-server
    detected system image 1.8.2
    using new imx412 defaults
    MISP awb str: auto
    Setting MISP AWB to AutoMISP awb str: auto
    Setting MISP AWB to Auto=================================================================
    configuration for 3 cameras:
    cam #0
        sensor type:         imx412
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4056
        large_video_height:  3040
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         1
        snap_width:          4056
        snap_height:         3040
        exif_focal_length:   3.100000
        exif_focal_len_35mm_format:17
        exif_fnumber:        1.240000
        ae_mode:             isp
        msv_exposure_min_us: 20
        msv_exposure_max_us: 33000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    cam #1
        sensor type:         ar0144
        isEnabled:           0
        camId:               2
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           1280
        pre_height:          800
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_misp:             1
        misp_width:          1280
        misp_height:         800
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             lme_msv
        msv_exposure_max_us: 12000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #2
        sensor type:         ar0144
        isEnabled:           0
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           1280
        pre_height:          800
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             1
        misp_width:          1280
        misp_height:         800
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    fsync_en:            1
    fsync_gpio:          109
    connected to mavlink pipe
    Connected to cpu-monitor
    Starting Camera: hires (id #1)
    Skipping Camera: tracking_rear, configuration marked disabled
    Skipping Camera: tracking_down, configuration marked disabled
    ------ voxl-camera-server: Started 1 of 3 cameras
    WARNING failed to set pipe size: Cannot allocate memory
    PIPE NOT CREATED!!
    pipe 5 size achieved: -1 requested: 1048576
    Killed
    voxl2:~$
    voxl2:~$ voxl-version
    kernel:       #1 SMP PREEMPT Mon Nov 11 22:47:44 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    voxl-suite:   1.4.1
    Any insight?
  • Voxl2 camera RAW
    Hi all, I work with Roberto, adding here the voxl-camera-server.conf file we are currently using.
    	"version":	0.1,
    	"fsync_en":	true,
    	"fsync_gpio":	109,
    	"cameras":	[{
    			"type":	"imx412",
    			"name":	"hires",
    			"enabled":	true,
    			"camera_id":	1,
    			"fps":	30,
    			"en_preview":	false,
    			"preview_width":	640,
    			"preview_height":	480,
    			"en_raw_preview":	false,
    			"en_small_video":	true,
    			"small_video_width":	1024,
    			"small_video_height":	768,
    			"small_venc_mode":	"h264",
    			"small_venc_br_ctrl":	"cqp",
    			"small_venc_Qfixed":	30,
    			"small_venc_Qmin":	15,
    			"small_venc_Qmax":	40,
    			"small_venc_nPframes":	9,
    			"small_venc_mbps":	2,
    			"small_venc_osd":	false,
    			"en_large_video":	true,
    			"large_video_width":	4056,
    			"large_video_height":	3040,
    			"large_venc_mode":	"h264",
    			"large_venc_br_ctrl":	"cqp",
    			"large_venc_Qfixed":	40,
    			"large_venc_Qmin":	15,
    			"large_venc_Qmax":	50,
    			"large_venc_nPframes":	29,
    			"large_venc_mbps":	40,
    			"large_venc_osd":	false,
    			"en_snapshot":	true,
    			"en_snapshot_width":	4056,
    			"en_snapshot_height":	3040,
    			"exif_focal_length":	4.5,
    			"exif_focal_length_in_35mm_format":	25,
    			"exif_fnumber":	4.5,
    			"ae_mode":	"off",
    			"gain_min":	54,
    			"gain_max":	8000,
    			"snapshot_jpeg_quality":	100
    We are using the snapshots for one of our projects and we would need to have the most detailed image possible to be processed with an external algo.
    Thanks
  • Stereo cameras not working with 14.5cm extension cable
    Hi @Vinny and @Alex-Kushleyev,
    any update about the config files?
    Thank you
