PIRON PIP
PIRON PI
@PIRON PI
  • How to Build mavsdk_server from new source
    PIRON PIP PIRON PI
    @chaitanya Sorry. My goal is that cell phone can control VOXL flight deck.
    Therefore, I need a MAVSDK library( e.g. libmavsdk.so) at Android. Then I can use the library to send command to control VOXL flight deck.
    PIRON PIP PIRON PI
    @Chad-Sweet Maybe you can offer the right version of mavsdk source. Because I use "git clone https://github.com/mavlink/MAVSDK.git". It's too new to be compatible with VOXL flight Deck.
    PIRON PIP PIRON PI
    @Chad-Sweet I try to upgrade cmake in docker, but it doesn't work.
    PIRON PIP PIRON PI
    @CY-1992 I generate libmavsdk.so from instruction of mavsdk.mavlink.io,
    but it can't be compatible with VOXL.
    Do you know where I can get source to generate libmavsdk.so for VOXL flight Deck?
    PIRON PIP PIRON PI
    @CY-1992 You give me confidence .
    I did it.
    Thanks a lot.
    PIRON PIP PIRON PI
    Hi Eric, the demo code of python can work with mavsdk_server,
    but C++ demo code can't connect with mavsdk_server.
    I read source code of python that assigns udp port for mavsdk_server.
    C++ demo code doesn't assign udp port for mavsdk_server.
    Does this cause C++ demo code doesn't work?
    PIRON PIP PIRON PI
    Hi, I download a new version of mavsdk.
    But New mavsdk needs cmake version 3.13 or later.
    I try to use voxl-emulator or gcr.io/modalai-public/voxl-mavsdk-cpp:v1.0, but their cmake are too old.
    Is there a way to build new version of mavsdk?
  • offboard mode mavsdk example
    PIRON PIP PIRON PI
    @沈-宏澤 Do you solve your problem?
    How to solve it?
  • How to make VOXL Flight DECK fly at offboard?
    PIRON PIP PIRON PI
    Hi, My device is VOXL FLIGHT DECK.
    I can use RC to control my device.
    Now, I'd like to use offboard mode.
    First, I key in "docker run -it --rm --privileged --net=host gcr.io/modalai-public/voxl-mavsdk-cpp:v1.0 /bin/bash"
    Second, Type "./takeoff_and_land udp://:14551"
    And then Show following message.
    At bottom, It keeps saying "Vehicle is getting ready to arm"
    What steps do I miss?
    [11:04:08|Info ] MAVSDK version: 0.28.0 (mavsdk_impl.cpp:26)
    [11:04:08|Debug] New: System ID: 0 Comp ID: 0 (mavsdk_impl.cpp:377)
    [11:04:08|Info ] New system on: 127.0.0.1:46695 (udp_connection.cpp:256)
    Waiting to discover system...
    [11:04:08|Debug] Component Autopilot (1) added. (system_impl.cpp:352)
    [11:04:08|Debug] Discovered 1 component(s) (UUID: 5634091164030415157) (system_impl.cpp:525)
    Discovered system with UUID: 5634091164030415157
    Discovered a component with type 1
    Vehicle is getting ready to arm......
  • Can I use voxl-streamer to see color video
    PIRON PIP PIRON PI
    @Eric-Katzfey I can see color video by using voxl-streamer -c hires-logo.
    Thank you.
    PIRON PIP PIRON PI
    @Eric-Katzfey I use voxl-configure-cameras 8 to select hires camera. And then run voxl-camera-server and voxl-streamer -c hires. But I can't receive any signal.
    If I use voxl-configure-cameras 2 to select tracking camera, then I type voxl-camera-server and voxl-streamer -c tracking. my cell phone can receive black and white video.
    Can you tell me which step I make wrong choice?
    PIRON PIP PIRON PI
    HI, My voxl flight run voxl-streamer and connect with my android phone by rtsp.
    But I can only see black and white video, can I see color video by changing setting?
    And I change camera by voxl-configure-camera, but only tracking camera can show video.
    Is it possible I can use stereo camera to show color video?
