Pey AstigP
Pey Astig
@Pey Astig
  • MAVSDK offboard set_velocity_body strange behavior
    Pey AstigP Pey Astig
    Oh man. , thank you so much that was the issue 😕
    (Firmware 1.10, indoor parameters used)
    These set of MAVSDK code causes the drone to fly up approximately 5 feet and spin
    await drone.action.arm()
    await drone.offboard.set_velocity_body(VelocityBodyYawspeed(0, 0, 0, 0))
    try:
        await drone.offboard.start()
    except OffboardError as error:
        print(f"Starting offboard mode failed with error code: \
              {error._result.result}")
        print("-- Disarming")
        await drone.action.disarm()
        return
    My initial expectation is it would just stay in the ground. I'm just wondering what could be causing the issue, or how i can try to debug this. I'm getting odometry data in QGroundControl.
    Thank you
  • take off in position flight mode causes the drone to fly a bit tilted forward instead of up
    (Firmware 1.10)I have the indoor PX4 parameters uploaded to the drone in QGroundControl.
    One possible source could be that the sensor calibration I did wasn't
    perfect. But I believe that since I'm using indoor PX4 parameters, position flight mode depends only on the Tracking Camera (external vision) and not the sensors ?
  • Is HITL (hardware in the loop) supported in VOXL-m500?
    Thank you, this helped a lot.
  • How does voxl-vision-configuration parameters relate to PX4 parameters?
    For example, does having VIO to True, simply set PX4 parameters to use External Vision for EKF2? Do I have to change VIO and VOA to false if I'm doing an outdoor flight test?
    The reason for the question is it would be helpful to test software command API's on the VOXL-m500 such as MAVSDK more intensively without risking accidents
