  3. MAVSDK offboard set_velocity_body strange behavior
3 Posts 2 Posters 2.3k Views 2 Watching
  • Pey AstigP Offline
    Pey AstigP Offline
    Pey Astig
    (Firmware 1.10, indoor parameters used)
    These set of MAVSDK code causes the drone to fly up approximately 5 feet and spin
    await drone.action.arm()
    await drone.offboard.set_velocity_body(VelocityBodyYawspeed(0, 0, 0, 0))
    try:
        await drone.offboard.start()
    except OffboardError as error:
        print(f"Starting offboard mode failed with error code: \
              {error._result.result}")
        print("-- Disarming")
        await drone.action.disarm()
        return
    My initial expectation is it would just stay in the ground. I'm just wondering what could be causing the issue, or how i can try to debug this. I'm getting odometry data in QGroundControl.
    Thank you
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi Pey,
      Can you double check that the "offboard_mode" is set to "none" in the voxl-vision-px4 configuration file?
      https://docs.modalai.com/voxl-vision-px4-other-features/
        Pey AstigP Offline
        Pey Astig
        Oh man. , thank you so much that was the issue 😕
