Mohammad GoliM
Mohammad Goli
@Mohammad Goli
  • Batteries charging error
    Mohammad GoliM Mohammad Goli
    @James-Strawson The failed batteries include both types, with a higher occurrence among the Gaoneng packs.
    ESCs, Sensors and Accessories power-module
  • Docker MAVSDK
    @Kiazoa-Joao How did you build it on the target platform? Could you specify the exact commands you used? Did you encounter any errors like those reported by @Gary-Holmgren? Are you using voxl-cross to build it?
  • Docker MAVSDK
    @Gary-Holmgren I have the same issue, same errors both with and without voxl-cross. Any luck with building on parent/host computer?
    We have the Starling Max 2, and the Sentinel drones from ModalAI. However, we’ve been experiencing significant issues with the batteries of Starling Max 2. Initially, 3 batteries failed, so I ordered 4 new sets. Unfortunately, two of these new batteries are no longer charging and display either a short error or a low voltage error on our Dynamite Prophet Sport Quad charger (Picture attached).
    Here’s how we typically operate the drone:
    • When using batteries: We connect both batteries simultaneously to the Starling terminals.
    • When using the wall charger: We use a jumper cable to short one terminal and connect the wall charger to the other terminal.
    Could you please assist with troubleshooting this issue? Should I return the batteries or the drone for diagnostics?
    I’d appreciate your guidance.
    Thanks,
  • Error when lunching voxl_mpa_to_ros.launch
    @Zachary-Lowell-0
    All our robots are currently operating on ROS1, and we haven’t transitioned to ROS2 yet. Any help, advice, or guidance on this would be greatly appreciated. Thank you!
    VOXL SDK and Software ros
    To resolve the issue with the missing shared library, I followed these steps:
    Download the YAML-CPP source code archive:
    wget https://github.com/jbeder/yaml-cpp/archive/refs/tags/yaml-cpp-0.5.3.tar.gz
    Extract the archive:
    tar -xvf yaml-cpp-0.5.3.tar.gz
    Navigate to the extracted directory and create a build directory:
    cd yaml-cpp-0.5.3
    mkdir build
    cd build
    Configure the build with CMake, enabling shared libraries and setting the installation prefix:
    cmake .. -DBUILD_SHARED_LIBS=ON -DCMAKE_BUILD_TYPE=Release -DCMAKE_INSTALL_PREFIX=/usr/local
    Compile the library:
    make -j$(nproc)
    Install the compiled library:
    sudo make install
    Update the shared library cache:
    sudo ldconfig
    After completing these steps, the shared library issue was resolved successfully.
    However, now when I run the launch file I get the following error ( echo: write error: Broken pipe)
    voxl2:/$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    ... logging to /home/root/.ros/log/eb195fbe-b8e2-11ef-b28f-00c0cab3a5da/roslaunch-m0054-6563.log
    Press Ctrl-C to interrupt
    started roslaunch server http://m0054:38143/
    SUMMARY
    PARAMETERS
    • /rosdistro: melodic
    • /rosversion: 1.14.13
    NODES
    auto-starting new master
    process[master]: started with pid [6577]
    setting /run_id to eb195fbe-b8e2-11ef-b28f-00c0cab3a5da
    process[rosout-1]: started with pid [6588]
    process[voxl_mpa_to_ros_node-2]: started with pid [6591]
    MPA to ROS app is now running
    Found new interface: hires_large_color
    Found new interface: hires_large_encoded
    Found new interface: hires_large_grey
    Found new interface: hires_small_color
    Found new interface: hires_small_encoded
    Found new interface: hires_small_grey
    Found new interface: hires_snapshot
    Found new interface: tracking_down_color
    Found new interface: tracking_down_grey
    Found new interface: tracking_down_small_color
    Found new interface: tracking_down_small_encoded
    Found new interface: tracking_down_small_grey
    Found new interface: tracking_front
    /usr/bin/voxl-list-pipes: line 38: echo: write error: Broken pipe
    /usr/bin/voxl-list-pipes: line 32: echo: write error: Broken pipe
    /usr/bin/voxl-list-pipes: line 35: echo: write error: Broken pipe
    [voxl_mpa_to_ros_node-2] process has died [pid 6591, exit code -11, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/eb195fbe-b8e2-11ef-b28f-00c0cab3a5da/voxl_mpa_to_ros_node-2.log].
    log file: /home/root/.ros/log/eb195fbe-b8e2-11ef-b28f-00c0cab3a5da/voxl_mpa_to_ros_node-2
    .log
    I appreciate if someone can provide any help on this.
    Thanks,
    I installed ROS on our VOXL2 machine following this guide:
    https://docs.modalai.com/ros-installation-voxl2/
    when I try to run the voxl_mpa_to_ros node, by running the below command, it runs roscore correctly but gives an error with the actual node:
    voxl2:~/$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    here is the error:
    /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node: error while loading shared libraries: libyaml-cpp.so.0.5: cannot open shared object file: No such file or directory
    failed to start local process: /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/887bafd6-a917-11ef-818d-00c0cab3a5da/voxl_mpa_to_ros_node-2.log
    local launch of voxl_mpa_to_ros/voxl_mpa_to_ros_node failed
    [voxl_mpa_to_ros_node-2] process has died [pid -1, exit code 127, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/887bafd6-a917-11ef-818d-00c0cab3a5da/voxl_mpa_to_ros_node-2.log].
    log file: /home/root/.ros/log/887bafd6-a917-11ef-818d-00c0cab3a5da/voxl_mpa_to_ros_node-2*.log
    I appreciate your advice on how to fix this.
    Thanks
