M
matt-1
@matt-1
  • UK Operations Manual Info
    M matt-1
    Need to input all the following details for a UK Operations Manual, i know some of these details are online which i can fill in, but not all. Do you have a document that answers all of the below?
    1. UAS General Description
      Please confirm or provide the following details for the ModalAI PX4:
      1.1 Aircraft Identification
    • Make
    • Model
    • Variant / Configuration (if applicable)
    • Type of Aircraft (e.g. multirotor, quadcopter)
    • Serial Number Format
    • Date of Manufacture
    • Intended Operational Category (if defined by manufacturer)
      1.2 Aircraft Specifications
    • Official Aircraft Specification Weblink
    • Maximum Take-off Mass (MTOM) (grams)
    • Maximum Payload Mass (grams)
    • Empty Weight (without battery & payload)
      1.3 Dimensions
      Please confirm all dimensions with propellers installed:
    • Length (mm)
    • Width (mm)
    • Height (mm)
    • Diagonal Motor-to-Motor Distance (mm) (if applicable)
      1.4 Propulsion Configuration
    • Propeller Configuration (e.g. quadcopter, X-configuration)
    • Motor Orientation (pusher / puller / mixed)
    • Number of Motors
    1. UA Performance Characteristics (Flight Envelope)
      Please confirm the following performance limits:
      2.1 Mass & Speed
    • Maximum Take-off Mass (MTOM) (g)
    • Maximum Airspeed (m/s or km/h)
    • Minimum Airspeed to Maintain Safe Flight
☐ N/A (multirotor – hover capable) ☐ Value (if applicable)
      2.2 Manoeuvring Limits
    • Maximum Bank Angle (degrees)
    • Maximum Pitch Angle (degrees)
    • Maximum Yaw Rate (deg/s or rad/s)
    2.3 Altitude & Endurance
    • Normal Operating Height (AGL) (m)
    • Maximum Operating Height (Service Ceiling) (AMSL, m)
    • Maximum Flight Time (minutes – hover, no wind, standard battery)
    • Maximum Operating Range (km)
    • Maximum Command & Control (C2) Range (km)
      2.4 Failure & Recovery
    • Glide Distance (if applicable)
    • Failsafe Behaviours (e.g. RTH, land, hover)
    • Loss of GNSS Behaviour
    • Loss of C2 Behaviour
      2.5 Other Performance Information
    • Any Additional Performance Limitations or Notes
    1. UAS Environmental Limitations
      Please confirm environmental operating limits:
      3.1 Wind
    • Maximum Wind Speed for Take-off & Landing (steady + gusts, m/s)
    • Maximum Wind Speed for Sustained Flight (steady + gusts, m/s)
      3.2 Weather & Exposure
    • Ingress Protection (IP) Rating
    • Precipitation Limitations (rain, drizzle, snow – if any)
    • In-flight Icing Tolerance (Yes / No / N/A)
      3.3 Temperature
    • Maximum Operating Air Temperature (°C)
    • Minimum Operating Air Temperature (°C)
      3.4 Other Environmental Factors
    • Space Weather / GNSS Interference Limitations
    • Any Other Environmental Restrictions
    1. Fuel / Energy Source (General)
      4.1 Energy Type
    • Energy Source Type (e.g. batteries)
    • Number of Energy Sources Installed
    • Means of Identifying Energy State (LEDs, app, telemetry)
    • Fuel / Energy Status Indicators
    • Fuel / Energy Alert Messages
      4.2 Hazardous Substances
    • Hazardous Substances Carried
    • Hazard Classification (e.g. flammable, corrosive)
    • Any Additional Safety Notes
    1. Batteries (Primary Energy Storage)
      Please confirm full battery specifications:
      5.1 Battery Identification
    • Battery Type
    • Manufacturer
    • Model / Part Number
    • Chemistry
      5.2 Electrical Characteristics
    • Nominal Voltage (V)
    • Maximum Voltage (V)
    • Capacity (mAh)
    • Energy Rating (Wh)
    • Number of Cells
    • Cell Configuration (series / parallel)
      5.3 Installation & Use
    • Minimum Quantity Required for Flight
    • Maximum Quantity Permitted
    • Battery Arrangement
    • Connector Type
    • Physical Restraint Method
    • Hot-Swap Capability (Yes / No)
      5.4 Battery Protection
    • Over-discharge Protection
    • Over-temperature Protection
    • Battery Health Monitoring
    • Any Other Battery-Related Information
    1. Engines and Propellers
      6.1 Engines / Motors
    • Type of Engine (electric)
    • Number of Motors
    • Motor Manufacturer
    • Motor Model
    • Maximum Motor Power (W)
    • Cooling Method
    • Any Other Engine Information
      6.2 Propellers
    • Propeller Type (fixed / folding)
    • Number of Blades per Propeller
    • Blade Length / Diameter
    • Propeller Material
    • Propeller Fixing Mechanism
    • Direction of Rotation
    • Any Propeller-Related Notes
    1. Navigation & Flight Control
      7.1 Navigation System
    • Navigation Type (GNSS, visual, inertial)
    • GNSS Constellations Supported
    • Number of GNSS Receivers
    • GNSS Antenna Location
      7.2 Automatic Flight Controls
    • Autonomous Flight Modes Available
    • Return-to-Home Function
    • Automatic Landing Function
    • Hover Stability Aids
      7.3 Geo-awareness & Geo-fencing
    • Geo-awareness Capability
    • Altitude Geo-fencing (user-settable / fixed)
    • Horizontal Geo-fencing (user-settable / fixed)
    • Pilot Alerts for Geo-fence Breach
      7.4 Redundancy
    • Backup Navigation Systems
    • Fallback Modes in Case of Sensor Failure
      7.5 Human-Machine Interface (HMI)
    • Information Displayed to Remote Pilot
    • Warning & Alert Messages
    • Audible / Visual Alerts
    1. Command & Control (C2) Link
      Please confirm communications characteristics:
      8.1 C2 Performance
    • Maximum C2 Range
    • Latency (if specified)
      8.2 Radio Characteristics
    • Operating Frequencies Used
    • Transmit Power Levels
    • Receiver Sensitivity
    • Antenna Type
      8.3 Reliability & Security
    • Link Redundancy
    • Encryption Type
    • Failsafe on Link Loss
    • Any Other C2 Information
    1. Additional Manufacturer Notes
    • Operational Limitations Not Listed Above
    • Maintenance Intervals
    • Firmware Dependencies
    • Regulatory Compliance Statements
    • Any Information Relevant to Operations Manuals
