Madelyne RossmannM
Madelyne Rossmann
@Madelyne Rossmann
  • Enabling Hires Camera for AprilTag Detection
    Madelyne RossmannM Madelyne Rossmann
    @Alex-Kushleyev Thank you! That worked! I ended up using hires_small_grey since the large stream would not calibrate for me, and the reduced-size did not seem to cause any issues with detection in my code. I was able to confirm tag detection using the hires camera after calibration and all is good. I appreciate the help!
    Autonomy: VIO, Mapping and Navigation apriltag
    I am using the VOXL 2 Flight Deck (Config: 2.4/5ghz WiFi, SKU: MDK-F0006-2-03) and am interested in utilizing the included hires sensor (IMX214) for AprilTag detection and localization. It seems that I could enable this in the /etc/modalai/voxl-tag-detector.conf file, but this requires having a calibration file available. I haven't had success in using the voxl-calibrate-camera package to calibrate the hires, but I believe there is a workaround using ROS 2 that I can try. For reference, this was the command I used for attempting to calibrate the hires:
    voxl2:~$ voxl-calibrate-camera hires -s 6x8 -l 0.0223
    Waiting for valid pipe...
    It gets stuck here and does not open a calibration stream on the VOXL portal. I can confirm that the hires sensor does stream to the portal and QGC, so it is being recognized by the system. The AprilTag detection package does work with the tracking camera, but I need to run it with a more powerful sensor for my intended use case.
    Here is a printout of my system information:
    voxl2:~$ voxl-version
    system-image: 1.7.10-M0054-14.1a-perf
    kernel:   	#1 SMP PREEMPT Fri Sep 27 21:18:59 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var: 	1.0.0
    voxl-suite:   1.3.5
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.3/binary-arm64/
    Last Updated: 2025-01-08 16:56:37
    List:
    kernel-module-voxl-fsync-mod-4.19.125 	1.0-r0
    kernel-module-voxl-gpio-mod-4.19.125  	1.0-r0
    libfc-sensor                          	1.0.7
    libmodal-cv                           	0.5.11
    libmodal-exposure                     	0.1.1
    libmodal-journal                      	0.2.2
    libmodal-json                         	0.4.3
    libmodal-pipe                         	2.10.2
    libqrb5165-io                         	0.4.6
    libvoxl-cci-direct                    	0.2.3
    libvoxl-cutils                        	0.1.1
    modalai-slpi                          	1.1.19
    mv-voxl                               	0.1-r0
    qrb5165-bind                          	0.1-r0
    qrb5165-dfs-server                    	0.2.0
    qrb5165-imu-server                    	1.0.1
    qrb5165-rangefinder-server            	0.1.3
    qrb5165-slpi-test-sig                 	01-r0
    qrb5165-system-tweaks                 	0.3.0
    qrb5165-tflite                        	2.8.0-2
    voxl-bind-spektrum                    	0.1.1
    voxl-camera-calibration               	0.5.7
    voxl-camera-server                    	2.0.1
    voxl-ceres-solver                     	2:1.14.0-10
    voxl-configurator                     	0.8.5
    voxl-cpu-monitor                      	0.4.8
    voxl-docker-support                   	1.3.1
    voxl-elrs                             	0.2.2
    voxl-esc                              	1.4.7
    voxl-feature-tracker                  	0.4.1
    voxl-flow-server                      	0.3.6
    voxl-fsync-mod                        	1.0-r0
    voxl-gphoto2-server                   	0.0.10
    voxl-gpio-mod                         	1.0-r0
    voxl-jpeg-turbo                       	2.1.3-5
    voxl-lepton-server                    	1.2.3
    voxl-lepton-tracker                   	0.0.2
    voxl-libgphoto2                       	0.0.4
    voxl-libuvc                           	1.0.7
    voxl-logger                           	0.4.7
    voxl-mavcam-manager                   	0.5.7
    voxl-mavlink                          	0.1.1
    voxl-mavlink-server                   	1.4.2
    voxl-microdds-agent                   	2.4.1-0
    voxl-modem                            	1.1.3
    voxl-mongoose                         	7.7.0-1
    voxl-mpa-to-ros                       	0.3.9
    voxl-mpa-to-ros2                      	0.0.2
    voxl-mpa-tools                        	1.2.3
    voxl-neopixel-manager                 	0.0.3
    voxl-open-vins                        	0.4.14
    voxl-open-vins-server                 	0.2.75
    voxl-opencv                           	4.5.5-2
    voxl-osd                              	0.0.1
    voxl-platform-mod                     	1.0-r0
    voxl-portal                           	0.7.0
    voxl-px4                              	1.14.0-2.0.84
    voxl-px4-imu-server                   	0.1.2
    voxl-px4-params                       	0.5.3
    voxl-qvio-server                      	1.0.4
    voxl-remote-id                        	0.0.9
    voxl-reset-slpi                       	0.0.1
    voxl-ros2-foxy                        	0.0.1
    voxl-state-estimator                  	0.0.2
    voxl-streamer                         	0.7.4
    voxl-suite                            	1.3.5
    voxl-tag-detector                     	0.0.4
    voxl-tflite-server                    	0.3.4
    voxl-utils                            	1.4.3
    voxl-uvc-server                       	0.1.7
    voxl-vision-hub                       	1.8.9
    voxl-vtx                              	1.1.0
    voxl2-io                              	0.0.3
    voxl2-system-image                    	1.7.10-r0
    voxl2-wlan                            	1.0-r0
    Here is my /etc/modalai/voxl-camera-server.conf file:
     * voxl-camera-server Configuration File
     * Each camera has configurations for up to 4 HAL3 streams:
     *	- `preview` stream for raw unprocessed images from CV cameras
     *	- `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
     *	- `large_video` 4k (ish) h264/h265 for onboard video recording to disk
     *	- `snapshot` ISP-processed JPG snapshots that get saved to disk
     * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
     * This file is generated from default values by voxl-configure-cameras.
     * Do not expect arbitrary resolutions to work, the ISP and video compression
     * pipelines only support very specific resolutions.
     * The default video compression mode is cqp or Constant Quantization Parameter
    	"version":	0.1,
    	"fsync_en":	false,
    	"fsync_gpio":	109,
    	"cameras":	[{
            	"type":	"ov7251",
            	"name":	"stereo_front",
            	"enabled":	true,
            	"camera_id":	0,
            	"camera_id_second":	1,
            	"independent_exposure":	false,
            	"fps":	30,
            	"en_rotate":	true,
            	"en_rotate_second":	true,
            	"en_preview":	true,
            	"preview_width":	640,
            	"preview_height":	480,
            	"en_raw_preview":	true,
            	"ae_mode":	"lme_msv",
            	"ae_desired_msv":	60,
            	"exposure_min_us":	20,
            	"exposure_max_us":	33000,
            	"gain_min":	54,
            	"gain_max":	8000,
            	"exposure_soft_min_us":	5000,
            	"ae_filter_alpha":	0.600000023841858,
            	"ae_ignore_fraction":	0.20000000298023224,
            	"ae_slope":	0.05000000074505806,
            	"ae_exposure_period":	1,
            	"ae_gain_period":	1
            	"type":	"ov7251",
            	"name":	"tracking",
            	"enabled":	true,
            	"camera_id":	2,
            	"fps":	30,
            	"en_rotate":	false,
            	"en_preview":	true,
            	"gain_min":	54,
            	"gain_max":	8000,
            	"ae_gain_period":	1
            	"type":	"imx214",
            	"name":	"hires",
            	"enabled":	true,
            	"camera_id":	3,
            	"fps":	30,
            	"en_preview":	false,
            	"en_raw_preview":	false,
            	"en_small_video":	true,
            	"small_video_width":	1024,
            	"small_video_height":	768,
            	"small_venc_mode":	"h265",
            	"small_venc_br_ctrl":	"cqp",
            	"small_venc_Qfixed":	30,
            	"small_venc_Qmin":	15,
            	"small_venc_Qmax":	40,
            	"small_venc_nPframes":	9,
            	"small_venc_mbps":	2,
            	"en_large_video":	true,
            	"large_video_width":	4208,
            	"large_video_height":	3120,
            	"large_venc_mode":	"h265",
            	"large_venc_br_ctrl":	"cqp",
            	"large_venc_Qfixed":	38,
            	"large_venc_Qmin":	15,
            	"large_venc_Qmax":	50,
            	"large_venc_nPframes":	29,
            	"large_venc_mbps":	30,
            	"en_snapshot":	true,
            	"en_snapshot_width":	4208,
            	"en_snapshot_height":	3120,
            	"exif_focal_length":	0,
            	"exif_focal_length_in_35mm_format":	0,
            	"exif_fnumber":	0,
            	"ae_mode":	"isp"
            	"type":	"ov7251",
            	"name":	"stereo_rear",
            	"enabled":	true,
            	"camera_id":	5,
            	"camera_id_second":	4,
            	"fps":	30,
            	"en_rotate":	false,
            	"en_rotate_second":	false,
            	"en_preview":	true,
            	"gain_min":	54,
            	"gain_max":	8000,
            	"ae_gain_period":	1
    Additionally, here is my /etc/modalai/voxl-tag-detector.conf file contents:
     * This file contains configuration parameters for voxl-tag-detector.
     * You can specify up to 3 cameras to do detection on simultaneously.
     * For the stereo camera pair, only the left camera is used.
    	"detector_0":	{
        	"enable":	true,
        	"input_pipe":	"tracking",
        	"en_fast_mode":	true,
        	"n_threads":	1,
        	"en_undistortion":	true,
        	"undistort_scale":	0.600000023841858,
        	"overlay_name":	"tracking_tag_overlay",
        	"lens_cal_file":	"/data/modalai/opencv_tracking_intrinsics.yml",
        	"skip_n_frames":	5
    	"detector_1":	{
        	"enable":	false,
        	"input_pipe":	"stereo",
        	"n_threads":	1,
        	"undistort_scale":	0.899999976158142,
        	"overlay_name":	"stereo_tag_overlay",
        	"lens_cal_file":	"/data/modalai/opencv_stereo_intrinsics.yml",
        	"skip_n_frames":	5
    	"detector_2":	{
        	"enable":	false,
        	"input_pipe":	"extra",
        	"n_threads":	1,
        	"en_undistortion":	false,
        	"undistort_scale":	1,
        	"overlay_name":	"extra_tag_overlay",
        	"lens_cal_file":	"/data/modalai/opencv_extra_intrinsics.yml",
        	"skip_n_frames":	5
    If able to utilize the hires sensor for AprilTag detection, I do plan to modify its position and orientation on the flight deck to more closely resemble that of the tracking camera’s. It seems that would necessitate an update to the /etc/modalai/extrinsics.conf file. Are there any other files that would need to be modified to reflect a change in position/orientation of the sensor?
    Please let me know if any more information about my setup is needed and I am happy to provide it. Any help is greatly appreciated, thank you!
