Luca ZanattaL
Luca Zanatta
@Luca Zanatta
  • Compatible ToF sensor setup with VOXL2 Mini
    Luca ZanattaL Luca Zanatta
    Hi @Alex-Kushleyev,
    Now it's working!
    Thank you so much for your help and quick answers.
    Best,
    Luca
    ESCs, Sensors and Accessories
    @Alex-Kushleyev
    Hi, I'm Luca, and I'm currently working on the ModalAI voxl2 mini. Thanks for your help and your quick answers.
    To recap: I ran voxl-camera-server -l, and I got:
    DEBUG:   Attempting to open the hal module
    DEBUG:   SUCCESS: Camera module opened on attempt 0
    DEBUG:   ----------- Number of cameras: 2
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x00E2, Sensor Id: 0x7750
    DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x007A, Sensor Id: 0x2975
    DEBUG:   Note: This list comes from the HAL module and may not be indicative
    DEBUG:          of configurations that have full pipelines
    DEBUG:   Number of cameras: 2
    Stats for camera: 0
    ANDROID_SCALER_AVAILABLE_RAW_SIZES:
    These are likely supported by the sensor
     640 x  480
     640 x  480
     640 x  480
    ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS:
    These are NOT necessarily supported by the sensor
     640 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
     640 x  480 HAL_PIXEL_FORMAT_BLOB
     640 x  400 HAL_PIXEL_FORMAT_YCbCr_420_888
     640 x  400 HAL_PIXEL_FORMAT_BLOB
     640 x  360 HAL_PIXEL_FORMAT_YCbCr_420_888
     640 x  360 HAL_PIXEL_FORMAT_BLOB
     352 x  288 HAL_PIXEL_FORMAT_YCbCr_420_888
     352 x  288 HAL_PIXEL_FORMAT_BLOB
     320 x  240 HAL_PIXEL_FORMAT_YCbCr_420_888
     320 x  240 HAL_PIXEL_FORMAT_BLOB
     240 x  320 HAL_PIXEL_FORMAT_YCbCr_420_888
     240 x  320 HAL_PIXEL_FORMAT_BLOB
     176 x  144 HAL_PIXEL_FORMAT_YCbCr_420_888
     176 x  144 HAL_PIXEL_FORMAT_BLOB
     640 x  480 HAL_PIXEL_FORMAT_RAW10
     640 x  480 HAL_PIXEL_FORMAT_RAW12
     640 x  480 HAL_PIXEL_FORMAT_RAW16
     640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
    ANDROID_SENSOR_INFO_SENSITIVITY_RANGE
            min = 54
            max = 3451
    ANDROID_SENSOR_MAX_ANALOG_SENSITIVITY
            3451
    ANDROID_SENSOR_INFO_EXPOSURE_TIME_RANGE
            min = 0ns
            max = 1266732525ns
    Stats for camera: 1
     240 x 1629
     240 x 1629 HAL_PIXEL_FORMAT_RAW10
     240 x 1629 HAL_PIXEL_FORMAT_RAW12
     240 x 1629 HAL_PIXEL_FORMAT_RAW16
     240 x 1629 HAL_PIXEL_FORMAT_RAW_OPAQUE
            min = 54
            max = 0
            min = 0ns
            max = 0ns
    Number of cameras detected: 2
    Instead of checking the Cam slot, I have to check Cam idx. So I ran the following command: camera-server-config-helper tracking:ov7251:0 tof:pmd-tof:1 and got the following output:
    successfully wrote this camera config to disk:
    configuration for 2 cameras:
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             lme_msv
        msv_exposure_min_us: 20
        msv_exposure_max_us: 33000
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    cam #1
        sensor type:         pmd-tof
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 5
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           5
    fsync_en:            0
    fsync_gpio:          109
    camera_server_config_helper is done
    Finally, I ran voxl-camera-server and got the following error:
    cam #0
        sensor type:         ov7251
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           1
    cam #1
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 5
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           224
        pre_height:          1557
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_misp:             0
        misp_width:          -1
        misp_height:         -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             off
        gain_min           : 54
        gain_max           : 8000
        standby_enabled:     0
        decimator:           5
    fsync_en:            0
    fsync_gpio:          109
    connected to mavlink pipe
    Connected to cpu-monitor
    Starting Camera: tracking (id #0)
    setting ov7251 BLC register for cam id 0
    Starting Camera: tof (id #1)
    ERROR:   Camera 1 failed to find supported preview config: 224x1557
    WARNING: Failed to start cam tof due to invalid resolution
    WARNING: assuming cam is missing and trying to compensate
    ------ voxl-camera-server: Started 1 of 2 cameras
    Do you have any suggestions?
    Thanks for your help,
    Luca
