Leon GurevichL
Leon Gurevich
@Leon Gurevich
  • My VOXL 2 will not boot and remains in QDL mode even with SW2 in the OFF position.
    Leon GurevichL Leon Gurevich
    Hello ModalAI team,
    My VOXL 2 will not boot and remains in QDL mode even with SW2 in the OFF position. Could you advise whether there is an approved recovery/diagnostic procedure, or whether the board requires an RMA?
    Confirmed details:
    Chip marking: QRB5165M; recovery image: M0054(154)-1.zip.
    Powered through a ModalAI power module.
    SW2 checked with a multimeter: no continuity when OFF.
    Ubuntu host; modal-qdl repository commit 136f4b7 (2026-03-06).
    Repeated recovery attempts fail at the same point. USB connection and Sahara programmer transfer complete, and Firehose starts, but opening UFS LUN 0 fails.
    The log reports:
    Can't decode attribute slot with value
    Failed to initialize (open whole lun) UFS Device slot 0 partition 0
    Failed to open the device:3 slot:0 partition:0 error:0
    Failed to open device, type:UFS, slot:0, lun:0 error:3
    qdl: firehose operation timed out
    [PROGRAM] failed to setup programming
    Flash flat build failed
    The web interface incorrectly displays a green success message despite these log errors. The full captured log is attached. It reports chip serial 456372656 (0x1b33b1b0); this is the programmer-reported chip identifier, not a confirmed board-label serial number.
    Can this indicate recoverable UFS configuration/provisioning, or should the board be inspected for a storage/power fault? Please advise on the appropriate next diagnostic step or repair/RMA process.
    Thank you,
    Leon GurevichVOXL2-QDL-failure-log.txt
    VOXL 2 and VOXL 2 Mini
