J
Jordyn Heil
@Jordyn Heil
  • AR0144 RGB output on VOXL2
    J Jordyn Heil
    @Alex-Kushleyev,
    Yes, what you have described for the client application is what I am trying to design. Ideally, I would have time synchronization so that frames always line up, but if latency isn't too big of an issue, this should work fine. I was planning on working with the RGB image, but I'm open to using YUV if it offers a noticeable reduction in latency. Also, to clarify my current setup, I have 4 AR0144 cameras placed at 90-degree angles to one another, so there is plenty of overlap between adjacent cameras for stitching.
    A simple example would be extremely useful! Thanks for your help!
    J Jordyn Heil
    @Alex-Kushleyev, were you able to update the dev build of voxl-camera-server to encode the ar0144 color streams?
    J Jordyn Heil
    @Alex-Kushleyev, no worries! I appreciate your help on this!
    In the meantime, would you be able to share the CAD file for the M0173 breakout board? I was not able to find it anywhere.
    J Jordyn Heil
    @Alex-Kushleyev, great, thanks for doing that!
    OpenCL should work just fine!
    J Jordyn Heil
    @Alex-Kushleyev, thank you! That solved my issue!
    I can successfully stream the grey MISP streams over RTSP from my color AR0144s, but I am unable to stream colored frames over RTSP. Is the processing pipeline to do this implemented, and if so, what modifications need to be made to send and access these streams over RTSP?
    Also, I believe you mentioned earlier that the VOXL GPU can handle panoramic stitching between camera streams? I am currently using the CPU to do panoramic stitching, but there is too much lag for my application, so I would like to try and use a compute shader to offload the work to the GPU. What is the best way to do this on the VOXL2?
    J Jordyn Heil
    After adding in some extra debug statements in the voxl-camera-server codebase, these are my findings:
    The mpa_ion_buf_pool_alloc_bufs function is allocating 16 buffers but only properly initializing 1 buffer out of 16. The remaining 15 buffers contain corrupted or invalid data, as evidenced by the debug output showing mostly NULL pointers, invalid file descriptors, and bad memory addresses.
    [DEBUG] Buffer[0]: vaddress=0x5588128d50, fd=-2010712080, size=85, width=85, height=-2013126160, stride=85, slice=-2011714000
    [DEBUG] Buffer[1]: vaddress=(nil), fd=-1, size=0, width=0, height=0, stride=0, slice=0
    [DEBUG] Buffer[2]: vaddress=(nil), fd=-1, size=0, width=0, height=0, stride=0, slice=0
    [DEBUG] Buffer[3]: vaddress=(nil), fd=-1, size=0, width=127, height=-2044747776, stride=127, slice=0
    [DEBUG] Buffer[4]: vaddress=(nil), fd=800, size=127, width=127, height=0, stride=0, slice=102
    [DEBUG] Buffer[5]: vaddress=0x24000000000000, fd=1024, size=127, width=0, height=104, stride=0, slice=0
    [DEBUG] Buffer[6]: vaddress=0x50000000000, fd=-2014735536, size=0, width=0, height=0, stride=0, slice=0
    [DEBUG] Buffer[7]: vaddress=0x60000000320, fd=0, size=0, width=0, height=0, stride=0, slice=0
    [DEBUG] Buffer[8]: vaddress=0x400, fd=0, size=0, width=0, height=0, stride=0, slice=0
    [DEBUG] Buffer[9]: vaddress=0x5587d77ba0, fd=0, size=0, width=0, height=0, stride=0, slice=0
    [DEBUG] Buffer[10]: vaddress=(nil), fd=-2079350784, size=0, width=0, height=0, stride=0, slice=0
    [DEBUG] Buffer[11]: vaddress=(nil), fd=-2082496512, size=0, width=0, height=0, stride=2359296, slice=0
    [DEBUG] Buffer[12]: vaddress=0x900000000, fd=-1, size=0, width=2359296, height=0, stride=1280, slice=800
    [DEBUG] Buffer[13]: vaddress=0x7f8337a000, fd=120, size=2359296, width=1280, height=800, stride=1536, slice=1024
    [DEBUG] Buffer[14]: vaddress=0x7f8307a000, fd=0, size=1280, width=1536, height=1024, stride=0, slice=-2012890624
    [DEBUG] Buffer[15]: vaddress=(nil), fd=-1, size=1536, width=0, height=-2014372240, stride=85, slice=0
    [DEBUG] Found 1 valid buffers out of 16 allocated
    The debug output shows that only Buffer[13] has valid data with proper values: vaddress=0x7f8337a000, fd=120, size=2359296, width=1280, height=800. The library reports success but returns mostly unusable buffers, which causes the OMX encoder to fail during initialization since it expects a minimum number of valid buffers, of which, it only found 1 before (hence, the message, WARNING: Encoder expecting(16) more buffers than module allocated(1)).
    I implemented a temporary workaround that identifies the single valid buffer from the corrupted pool and duplicates its metadata to create 8 usable buffers (I was able to decrease the expected to 8 from 16, but I couldn't get any lower). This involves moving valid buffers to the front of the pool and zeroing out remaining buffers to prevent crashes. The workaround allows the OMX encoder to initialize with the minimum required buffers instead of failing with only 1 valid buffer.
    This is clearly a temporary solution and not a permanent fix. The root cause lies in the mpa_ion_buf_pool_alloc_bufs function, which appears to have a memory management issue. I was unable to find the implementation of that function, so I was unable to debug any further.
    I'm not sure if something else regarding the configuration on my Voxl was causing that issue. I was unable to find anything, but let me know if I'm missing something very obvious.
    J Jordyn Heil
    @Alex-Kushleyev, I've done some more digging, and I think I found the issue.
    I have confirmed that all 5 cameras are seen properly and stream to the Voxl Web Portal when I disable venc on all cameras and just enable preview.
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0030, Sensor Id: 0x0356
    DEBUG:   Cam idx: 1, Cam slot: 1, Slave Address: 0x0034, Sensor Id: 0x0577
    DEBUG:   Cam idx: 2, Cam slot: 2, Slave Address: 0x0030, Sensor Id: 0x0356
    DEBUG:   Cam idx: 3, Cam slot: 4, Slave Address: 0x0020, Sensor Id: 0x0356
    DEBUG:   Cam idx: 4, Cam slot: 6, Slave Address: 0x0030, Sensor Id: 0x0356
    However, when I enable venc, I get this error:
    DEBUG:   Buffer Count Expected: 16
    DEBUG:   Buffer Count Actual: 16
    DEBUG:   Port Def 0:
    	Count Min: 8
    	Count Actual: 16
    	Buffers Contiguous: Yes
    	Buffer Alignment: 0
    DEBUG:   Port Def 1:
    	Count Min: 4
    	Count Actual: 16
    	Buffers Contiguous: No
    	Buffer Alignment: 0
    DEBUG:   OMX_EventCmdComplete
    ERROR:   OMX Set config failed!
    ERROR:   Failed to initialize encoder for camera: hires
    ERROR:   Failed to start camera: hires
    My Voxl is running the most recent voxl-camera-server dev branch, and in hal3_camera_mgr.cpp, the following are all defined:
    #define NUM_PREVIEW_BUFFERS  16 // used to be 32, really shouldnt need to be more than 7
    #define NUM_SNAPSHOT_BUFFERS 16 // used to be 8, just making it consistent with the rest that are now 16
    #define NUM_MISP_BUFFERS     16
    #define NUM_STREAM_BUFFERS   16 // shouldn't need more than 10, if the buffer pool is empty then OMX should be dropping more frames
    #define NUM_RECORD_BUFFERS   16 // shouldn't need more than 10, if the buffer pool is empty then OMX should be dropping more frames
    All of these are set to 16, so why is my Voxl saying that it doesn't have 16 buffers available? It's also not competing for resources since I tested this out with just one camera having venc enabled.
    J Jordyn Heil
    @Alex-Kushleyev, I am still unable to see anything from the IMX412 or the extra AR0144 that has the new slave address of 0x20.
    I have the 0x30 address AR0144s and the IMX412 connected exactly as shown in this photo (minus the TOF sensor).
    The additional AR0144 with the resistor change is connected to J8 via the M0155.
    I downloaded the given sensormodule drivers, and this is my setup in /usr/lib/camera/:
    com.qti.sensormodule.ar0144_combo_0.bin
    com.qti.sensormodule.ar0144_combo_6.bin
    com.qti.sensormodule.ar0144_fsin_0x20_4.bin
    com.qti.sensormodule.ar0144_fsin_2.bin
    com.qti.sensormodule.imx412_fpv_1.bin
    com.qti.sensormodule.irs2975c_3.bin
    com.qti.tuned.cmk_imx577.bin
    com.qti.tuned.cmk_ov9282.bin
    com.qti.tuned.default.bin
    com.qti.tuned.imx412_fpv.bin
    com.qti.tuned.ov9782.bin
    com.qti.tuned.sony_imx335.bin
    I am on kernel variant 1.01, and when I select C27, the only things I change are "type" (switch from ar0144 to ar0144-color), misp_venc_enable (set false), delete the entry for the TOF sensor, and add an identical entry for the additional ar0144-color but with "camera_id" = 5.
    When I run voxl-camera-server -l, I am not able to see the DEBUG: lines. This is my output:
    Number of cameras detected: 5
    J Jordyn Heil
    @Alex-Kushleyev, I recently got the M0173, so I can finally test all cameras running concurrently. I made the resistor swap for the AR0144 plugged into J8, but could you walk me through the camera driver modification I need to make for the new slave id?
    I have voxl-camera-server v2.2.4 of the dev build, but I am only able to view my streams in color (through the VOXL Web Portal) when I set misp_venc_enable to false in the configuration file. Otherwise, I get errors for each AR0144 camera that say the following:
    "MISP Initializing for camera tracking_front
    Got unsupported format in getUVStartFromFmt, returning nullptr"
    Also, I am unable to view the IMX412 stream when it is connected to the M0173 in the C27 config. What additional modifications need to be made to solve these issues?
    J Jordyn Heil
    @Alex-Kushleyev, building from the dev branch worked great, thanks!
    On a separate note, for my application, I will need the coax cables connecting the cameras to be slightly longer. Do you all make longer cables, or are you aware of any other suppliers that make longer versions of these cables?
    J Jordyn Heil
    @Alex-Kushleyev, I just got the color AR0144s and was wondering what changes I need to make to the config file to get the RGB output from the AR0144s. I chose configuration 27, but when I open the stream in the VOXL web portal, I only get monochrome streams from the AR0144.
    J Jordyn Heil
    @Alex-Kushleyev, thanks for the photos! Yes, global shutter and small size are requirements, so I think the color AR0144s are my best option, but I'll wait to order until you confirm 4x concurrency.
    Also, if you can help me get started with using the VOXL2 GPU for panoramic stitching, that would be awesome! Thanks for all your help!
    J Jordyn Heil
    @Alex-Kushleyev, great! If there are no conflicts in communication, I'd still like to move forward with buying them as soon as possible, so just let me know what I need to do to purchase them.
    If I'm trying to do full 360 panoramic stitching with four of these sensors, will the fisheye lens distortion drastically impact the efficacy of doing a seamless stitch (particularly with the discoloration from lack of an RGB LSC)?
    J Jordyn Heil
    @Alex-Kushleyev, any update on whether I can buy 4 of these RGB AR0144s?
    J Jordyn Heil
    @Alex-Kushleyev, with the smaller number of cameras I can connect to the VOXL2, I’d like to increase the field of view of each AR0144 to maximize coverage. From my research, I understand the AR0144 sensor modules use a 1/4" optical format and are compatible with M12 lenses. Can you confirm if that’s correct?
    Also, how well do the AR0144-based camera modules (like the M0166) perform with large field-of-view M12 fisheye lenses (e.g., >190°)? Are there any known issues with image quality, distortion correction, or sensor limitations when using those types of lenses?
    J Jordyn Heil
    @Alex-Kushleyev, let me know how the test goes, that would be super helpful to know. It would also be nice to see the sample images comparing the mono and color AR0144. I really appreciate your help with this!
    J Jordyn Heil
    @Alex-Kushleyev, thank you for your help!
    On second thought, 5 cameras should work for my application. I am thinking about using 4 of these RGB M0166 variants, connected to the VOXL2 via the M0173 connector module, and then having a single high-res M0161 camera attached to the VOXL2 through a separate camera group (via the M0155 adaptor). In this case, since I am using a separate camera module for the 5th camera, this should solve the same slave ID conflict without having to make an external change to the camera PCB, correct? Would I still need to modify the camera driver or kernel in a particular way to support this?
    I'd like to move forward with buying 4 of these RGB M0166 variants if that's possible. Do these modules have an IR-cut filter?
    J Jordyn Heil
    @Alex-Kushleyev, that would be amazing! Will the VOXL 2 be able to support 6 of these simultaneously, like it can with the M0149? Also, do you know where I can find a CAD model for the M0166? I can't find it on the datasheet you have for it.
    J Jordyn Heil
    @Alex-Kushleyev, thanks for the response! Will the new colored version have the same dimensions as the M0149? Also, would it be feasible to buy a pre-release version of this colored variant of the AR0144? Would love to help with testing if that's possible.
    J Jordyn Heil
    I have been using the MSU-M0149-1 module with my VOXL2 and have only been getting either a monochrome output or a distorted, purple-tinted output. I could not find the exact model of the AR0144 camera that is being used in the M0149, but I am aware that there are both monochrome and RGB variants of the AR0144. What is the exact variant of the AR0144 being used in the M0149? If this camera is color-capable, what do I need to add to my configuration file to enable RGB output?
