Jon BrookshireJ
Jon Brookshire
@Jon Brookshire
  • Wifi Card - Intermittent Connection
    Jon BrookshireJ Jon Brookshire
    @Alex-Kushleyev Thanks. On the both drones, we used them exactly out of the box, no modifications. The issues we experienced before installing the ALFA adapter on the first drone.
    For example for the 5/8 message, the model MRB-D0012-4-V4-C28-M36-T8-K2 is using the daughter board with the BOTS chip (I think it's board MDK-M0213-1-00).
    Hi Alex,
    Thanks - As @Adnaan-Yunus mentioned, we switched over to the ALFA wifi and moved forward with that drone. But, we just received a new drone (model MRB-D0012-4-V4-C28-M36-T8-K2) and are experiencing similar issues. I managed to catch some log messages when the wifi went down. TLDR: it looks like the USB disconnected unexpectedly; the drone was stationary on a table top when this happened.
    Some additional context: the only configuration changes we made since unboxing was via voxl-wifi and we altered the RTSP address in voxl-mavcam-manager.conf. QGC was running when the USB disconnected with RTSP video displayed. The drone was not armed.
    Here's the configuration (everything looks as we expect).
    $ voxl-wifi
    WiFi is currently set up as follows:
    	Mode: station
    	Hardware: Concurrent STA+AP capable (AP:uap0, STA:mlan0)
    	Station: Active on mlan0 - "WAVLINK"
    	SoftAP: Disabled
    $ iwconfig
    ip6tnl0   no wireless extensions.
    sit0      no wireless extensions.
    ip_vti0   no wireless extensions.
    mlan0     IEEE 802.11-DS  ESSID:"WAVLINK" [11]
              Mode:Managed  Frequency=5.6 GHz  Access Point: *********************
              Bit Rate:175.5 Mb/s   Tx-Power=24 dBm
              Retry limit:9   RTS thr=2347 B   Fragment thr=2346 B
              Encryption key:****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****-****   Security mode:open
              Power Management:off
              Link Quality=5/5  Signal level=-43 dBm  Noise level=-93 dBm
              Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:462
              Tx excessive retries:12  Invalid misc:24   Missed beacon:0
    dummy0    no wireless extensions.
    ip6_vti0  no wireless extensions.
    lo        no wireless extensions.
    bond0     no wireless extensions.
    uap0      IEEE 802.11-DS  ESSID:""
              Mode:Master  Frequency:2.437 GHz  Access Point: Not-Associated
              Encryption key:off
              Link Quality:0  Signal level:0  Noise level:0
              Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
              Tx excessive retries:0  Invalid misc:0   Missed beacon:0
    $ ifconfig
    bond0: flags=5123<UP,BROADCAST,MASTER,MULTICAST>  mtu 1500
            ether e6:71:39:a5:83:a1  txqueuelen 1000  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            TX packets 0  bytes 0 (0.0 B)
    dummy0: flags=195<UP,BROADCAST,RUNNING,NOARP>  mtu 1500
            inet6 fe80::1f3:bbc4:ab69:16bf  prefixlen 64  scopeid 0x20<link>
            ether 6a:c1:84:76:8c:1c  txqueuelen 1000  (Ethernet)
            TX packets 12  bytes 3016 (3.0 KB)
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1000  (Local Loopback)
            RX packets 104854  bytes 11086017 (11.0 MB)
            TX packets 104854  bytes 11086017 (11.0 MB)
    mlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 192.168.30.104  netmask 255.255.255.0  broadcast 192.168.30.255
            inet6 fe80::a637:6051:853a:6d93  prefixlen 64  scopeid 0x20<link>
            ether 8c:1f:64:69:da:d2  txqueuelen 1000  (Ethernet)
            RX packets 302  bytes 23251 (23.2 KB)
            TX packets 3784  bytes 1942045 (1.9 MB)
    On another machine, we can ping and access to the web frontend http://192.168.30.104 looks good.
    64 bytes from 192.168.30.104: icmp_seq=280 ttl=64 time=114 ms
    64 bytes from 192.168.30.104: icmp_seq=281 ttl=64 time=126 ms
    64 bytes from 192.168.30.104: icmp_seq=282 ttl=64 time=123 ms
    64 bytes from 192.168.30.104: icmp_seq=283 ttl=64 time=123 ms
    64 bytes from 192.168.30.104: icmp_seq=284 ttl=64 time=114 ms
    64 bytes from 192.168.30.104: icmp_seq=285 ttl=64 time=118 ms
    64 bytes from 192.168.30.104: icmp_seq=286 ttl=64 time=107 ms
    64 bytes from 192.168.30.104: icmp_seq=287 ttl=64 time=108 ms
    64 bytes from 192.168.30.104: icmp_seq=288 ttl=64 time=104 ms
    However, with a few minutes the ping's stopped. I monitored dmesg -w and here's what was output when the wifi went down:
    [  433.066912] usb 2-1: USB disconnect, device number 3
    [  433.068450] Card is removed: -108
    [  433.068644] EP 2 Tx URB status failure: -108
    [  433.068701] EP 2 Tx URB status failure: -108
    [  433.068748] EP 2 Tx URB status failure: -108
    [  433.068794] EP 2 Tx URB status failure: -108
    [  433.068839] EP 2 Tx URB status failure: -108
    [  433.068885] EP 2 Tx URB status failure: -108
    [  433.068937] EP 2 Tx URB status failure: -108
    [  433.068985] EP 2 Tx URB status failure: -108
    [  433.069031] EP 2 Tx URB status failure: -108
    [  433.069085] EP 2 Tx URB status failure: -108
    [  433.069140] EP 2 Tx URB status failure: -108
    [  433.069190] EP 2 Tx URB status failure: -108
    [  433.069317] Card is removed: -108
    [  433.069344] Card is removed: -108
    [  433.069369] Card is removed: -108
    [  433.069393] Card is removed: -108
    [  433.069419] Card is removed: -108
    [  433.069446] Card is removed: -108
    [  433.070472] Block woal_cfg80211_deauthenticate in abnormal driver state
    [  433.083826] Error deleting the crypto keys
    [  433.083851] Error deleting the crypto keys
    [  433.083863] Error deleting the crypto keys
    [  433.083874] Error deleting the crypto keys
    [  433.083884] Error deleting the crypto keys
    [  433.083895] Error deleting the crypto keys
    [  433.356084] USB: unregister device
    [  433.357228] Free module params
    [  433.704223] usb 2-1: new SuperSpeed Gen 1 USB device number 4 using xhci-hcd
    [  433.722038] usb 2-1: New USB device found, idVendor=1286, idProduct=2052, bcdDevice=31.17
    [  433.722048] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [  433.722053] usb 2-1: Product: Marvell Wireless Device
    [  433.722057] usb 2-1: Manufacturer: Marvell
    [  433.722062] usb 2-1: SerialNumber: 0000000000000000
    [  433.725632] USB probe: idVendor=1286 idProduct=2052 bInterfaceNumber=0
    [  433.725665] VID/PID = 1286/2052, Boot2 version = 3117
    [  433.725694] Attach moal handle ops, card interface type: 0x404
    [  433.725721] rps set to 0 from module param
    [  433.725733] No module param cfg file specified
    [  433.725756] rx_work=1 cpu_num=8
    [  433.725771] Enable moal_recv_amsdu_packet
    [  433.725807] Attach mlan adapter operations.card_type is 0x404.
    [  433.727974] Request firmware: nxp/usbusb8997_combo_v4.bin
    [  434.220193] fw_dnld: 597712 bytes downloaded
    [  434.996176] USB: unregister device
    [  434.996231] Free module params
    [  434.996608] usb 2-1: Disable of device-initiated U1 failed.
    [  434.996691] usb 2-1: Disable of device-initiated U2 failed.
    [  435.180482] usb 2-1: reset SuperSpeed Gen 1 USB device number 4 using xhci-hcd
    [  435.197429] usb 2-1: device firmware changed
    [  435.205171] usb 2-1: USB disconnect, device number 4
    [  435.388251] usb 2-1: new SuperSpeed Gen 1 USB device number 5 using xhci-hcd
    [  435.409284] usb 2-1: New USB device found, idVendor=1286, idProduct=204e, bcdDevice=32.01
    [  435.409293] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [  435.409299] usb 2-1: Product: Bluetooth and Wireless LAN Composite Device
    [  435.409303] usb 2-1: Manufacturer: Marvell
    [  435.409308] usb 2-1: SerialNumber: 8C1F6469DAD2
    [  435.421408] USB probe: idVendor=1286 idProduct=204e bInterfaceNumber=0
    [  435.421523] VID/PID = 1286/204E, Boot2 version = 3201
    [  435.421537] woal_usb_probe: invalid endpoint assignment
    [  435.421972] USB probe: idVendor=1286 idProduct=204e bInterfaceNumber=0
    [  435.422025] VID/PID = 1286/204E, Boot2 version = 3201
    [  435.422038] woal_usb_probe: invalid endpoint assignment
    [  435.423075] USB probe: idVendor=1286 idProduct=204e bInterfaceNumber=0
    [  435.423095] VID/PID = 1286/204E, Boot2 version = 3201
    [  435.423123] Attach moal handle ops, card interface type: 0x404
    [  435.423145] rps set to 0 from module param
    [  435.423157] No module param cfg file specified
    [  435.423179] rx_work=1 cpu_num=8
    [  435.423193] Enable moal_recv_amsdu_packet
    [  435.423228] Attach mlan adapter operations.card_type is 0x404.
    [  435.425589] WLAN FW is active
    [  435.425712] Download txpwrlimit_cfg=nxp/sparrow_power.bin
    [  435.425916] Request firmware: nxp/WlanCalData_ext_sparrow_default.conf
    [  435.593367] fw_cap_info=0x185cbfa3, dev_cap_mask=0xffffffff
    [  435.593393] max_p2p_conn = 8, max_sta_conn = 10
    [  435.619603] Register NXP 802.11 Adapter mlan0
    [  435.619695] wlan: uap%d set max_mtu 2000
    [  435.622776] Register NXP 802.11 Adapter uap0
    [  435.623087] wlan: version = USB8997---16.197.121.p2-MX5X16505.p7.2-(FP197)
    [  435.641209] IPv6: ADDRCONF(NETDEV_UP): mlan0: link is not ready
    [  435.743762] wlan: mlan0 START SCAN
    [  438.940152] wlan: SCAN COMPLETED: scanned AP count=21
    [  438.948662] wlan: HostMlme mlan0 send auth to bssid 82:XX:XX:XX:1e:03
    [  438.957472] mlan0:
    [  438.957479] wlan: HostMlme Auth received from 82:XX:XX:XX:1e:03
    [  438.998547] wlan: HostMlme mlan0 Connected to bssid 82:XX:XX:XX:1e:03 successfully
    [  439.105657] mlan0:
    [  439.105663] wlan: Send EAPOL pkt to 82:XX:XX:XX:1e:03
    [  439.118805] mlan0:
    [  439.118811] wlan: Send EAPOL pkt to 82:XX:XX:XX:1e:03
    [  439.122028] IPv6: ADDRCONF(NETDEV_CHANGE): mlan0: link becomes ready
    [  450.142651] CAM_INFO: CAM-CRM: __cam_req_mgr_find_dev_name: 209 Skip Frame: req: 13272 not ready on link: 0x1e0117 for pd: 2 dev: cam-sensor open_req count: 2
    [  452.679713] CAM_INFO: CAM-CRM: __cam_req_mgr_find_dev_name: 209 Skip Frame: req: 13347 not ready on link: 0x1e0117 for pd: 2 dev: cam-sensor open_req count: 3
    [  454.406150] msm_vidc:   err : ffffffff: .....: DBLP Set: status 0
    [  454.415602] CAM_INFO: CAM-CRM: __cam_req_mgr_find_dev_name: 209 Skip Frame: req: 13398 not ready on link: 0x1e0117 for pd: 2 dev: cam-sensor open_req count: 2
    [  455.350340] CAM_INFO: CAM-CRM: __cam_req_mgr_find_dev_name: 209 Skip Frame: req: 13425 not ready on link: 0x1e0117 for pd: 2 dev: cam-sensor open_req count: 2
    If I now run voxl-wifi and enter the same settings, the wifi will come back online. I was able to reproduce this issue several times.
  • 3D step files for Starling Max v3
    Hello, I see the CAD/STEP files for the Starling Max v2 here: https://developer.modalai.com/asset/6
    Is there a model for v3 (with the elevated GPS mount)?
    Design Reviews and 3D Models 3d-model
